99 Ram 4x4 steering wander...... - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 07-18-2012, 03:02 PM Thread Starter
diy_darryl
Yes, I know this has been beat to death but I have read so many threads I don't even know anymore how to proceed.
All parts replaced so far were faulty. New Track Bar, Tie-rod end driver side, Upper and lower ball joints both sides and Tires with a front end alignment. Oh..... and brake pads, calipers, hoses (unrelated).
Steering is better but still unsatisfactory!
Attempted the Bearing pre-load adjustment on the steering box but was unable to move the adjuster either direction with my homemade spanner wrench even after soaking in WD40. I will note that I could not feel any end play in stub shaft although not sure that I would.
Turned the over center adjustment on steering box one-half turn clockwise which helped some.
Everything feels tight in the steering shaft u-joints although there is some slop where it comes out of the firewall. (Not convinced that the Rock Solid Ram fix will address wandering issues, advice appreciated here)
Everything seems tight underneath also and I really cannot nail down any slop in the steering response in the garage at least.
The steering damper has leaked fluid and unsure of its condition but don't think that would cause wandering?????
What next? Am about to pull my hair out.
diy_darryl is offline
post #2 of 8 Old 07-18-2012, 03:10 PM
JackedDak03
JackedDak03's Avatar
Quoted: 1 Post(s)
How are the is the tie rod on the pitman arm? How about the one that attaches to the cross over (Not sure how to explain it)- its the one that attachs to the adjusting sleeve with the other tie rod that goes to the pitman arm?
If those are tight I'd put it on the steering box. On the ones I removed from my truck-new reman's or used - the input shaft moved a lot before it would move the pitman arm output shaft. Meaning it would allow the pitman arm and everything its attached to, to move before transmiting anything to the steering shaft/steering wheel.
BMW X5 & Chevy 2500 HD POS
Gone:
2002 Ford F350 Crew Cab Diesel
1999 Dodge Ram 2500 Quad Cab 4x4 Sport V10
1998.5 Dodge Ram 2500 Quad Cab 4x4 24V Cummins
2004 Dodge Ram 2500 Quad Cab 4x4 HEMI
2003 Dodge Dakota Quad Cab 4x4 4.7
2002 Dodge Ram 1500 Quad Cab 4x4 4.7
2001 Dodge Ram 1500 Quad Cab 4x4 5.9 V8
1999 Dodge Ram 2500 Quad Cab 4x4 5.9 V8
1997 Dodge Ram 1500 RegCab ShortBed Sport 5.9 V8
Past -92 Daytona R/T, 94 3000GT, 91 TransAm, 88 RX7 TII, 89 YJ, 92 Bronco, 88 YJ, 94 F150, 96 Rodeo, 88,89,90,91 5.0 Mustang's, 03 Mustang GT, 04 SRT4
JackedDak03 is offline
post #3 of 8 Old 07-18-2012, 03:23 PM Thread Starter
diy_darryl
I have not seen any movement in the tie-rods mentioned but will look it over again.
I am pretty sure there is an immediate response of the steering box output when the input shaft is turned but will look more closely.
It's my son's truck so I only drive it when it's broken or road testing after repairs.
post #4 of 8 Old 07-18-2012, 05:47 PM
Moparite
Moparite's Avatar
Quoted: 322 Post(s)
I think you mean drag link.
Moparite is offline
post #5 of 8 Old 07-18-2012, 07:14 PM
JackedDak03
Quoted: 1 Post(s)
YES thank you, major brain fart .
Gone:
post #6 of 8 Old 07-18-2012, 10:39 PM
BigGreenV10
Big Green
BigGreenV10's Avatar
Allot of things can cause it hubs, tie rods, ball joint, track bar.
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #7 of 8 Old 07-19-2012, 09:34 PM Thread Starter
diy_darryl
After having another look by slowly turning the steering wheel left to right there is in fact play in the input shaft before the output responds. When turned rapidly back and forth you can hear the steering gear box clunking.
As stated before I was unable to budge the spanner nut to make the preload adjustment on the truck.
I am assuming at this point I just need to remove the gear box and get it in the vise so I can get enough torque on it to adjust the preload and the over-center?
And if that doesn't remove the slop then it's time for a new one?
Is gear box removal and reinstallation pretty straight forward?
post #8 of 8 Old 07-21-2012, 06:50 PM Thread Starter
diy_darryl
Decided just to go ahead and replace the steering gear box. Truck is now behaving quite nicely on the road.
    Steering play/wander RWKIII 3G Dodge RAM - General Talk 12 10-05-2011 09:55 PM
    2nd gen steering wander fix on craigslist frazier 2G Dodge RAM - 4X4 Talk 26 04-25-2011 10:02 PM
    Dodge 2500 steering wander dm33 2G Dodge RAM - General Talk 0 02-11-2010 03:17 PM
    Removing Steering Shaft from 1992 B250 Steering Column gman69440 Dodge Ram Truck 1st Gen (88 - 93) Forum 1 03-23-2008 09:37 PM
    steering wander 04 2500hd hemi curtb 3G Dodge RAM - 4X4 Talk 11 05-11-2007 11:18 PM
