1998 Dodge 1500 transmission noise - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 07-14-2012, 10:50 AM Thread Starter
kinkypuppy
This "sounds" like a torque converter issue. If it was a manual I would say its a throwout bearing.
Start truck, get LOUD grinding noise. (almost like a starter gear grinding crank up, no its not that)put in any gear, noise stops vehicle runs good. Same noise in neutral.
Am getting ready to pull pan.
Noise is definitely from rear of engine.
The transmission might be a 46RE and I am unfamiliar with electronic solenoids.
Thoughts?
I am 35 miles away from nearest shop and money is non-existent.
Its got 100k and on its 2nd transmission.
Fuel economy has been dismal for sometime.
kinkypuppy is offline
post #2 of 9 Old 07-14-2012, 09:02 PM
spun360
spun360's Avatar
Quoted: 161 Post(s)
any auto parts store could sell you a standard new replacement. dont believe in the rebuilt tqs.
parts for sale
ask about my treadwright retread experience
$150: 210lb double and dampener valve springs .550 lift
$pay shipping: new, dana/ spicer (1)greasable upper & (1)lower ball joint for dana 44
$pay shipping: new, standard oil pump
$pay shipping: new, super strength moog #377 frt axle hub universal w/ grease fitting
prices (for residence of the US)
cheep
shoot PMs my way
spun360 is offline
post #3 of 9 Old 07-15-2012, 08:18 AM
Moparite
Moparite's Avatar
Quoted: 322 Post(s)
If the bendix sticks it will sound like that.
Moparite is offline
post #4 of 9 Old 07-15-2012, 11:30 AM Thread Starter
kinkypuppy
Once pan is pulled i will inspect residue, if its clean then can i "assume" its not the t. converter tearing itself apart.
Don't think it is the bendix on the starter as once its driven a bit if it goes back into part or neutral the noise reoccurs.
The Bendix would show obvious signs of damage once the starter is removed or would it?
There are no "codes" or error lights when this is happening. I have truck jacked up and will start disassembily this week. The noise is so bad that driving it to a trans shop may just aggravate the problem and it may not make it the 35 miles. Besides once there i may not get it home. and giving the local "shop" 500.-1000. that I do not have is not an option. We live in a fairly remote valley that has more than its share of "garage" mechanix however we do not know anyone here after 3 years, so I am forced to repair it myself. (Before you say "this charactor is an idiot" I have pulled a few times and rebuilt once a Race prepped C-6 on my '70 Ford Bronco by myself and converted a 1970 Bronco into a Baja-1000 racer so I am not totally foolish) I just lack the experiance to diagnose a noise.
post #5 of 9 Old 07-18-2012, 09:37 PM Thread Starter
kinkypuppy
Pulled access cover off flexplate. The 4 bolts that attach the Drive plate to the flex plate are so loose that two turns remove them.
Question #1 the holes on the drive plate are not too bad but are a bit egg shaped. They should be ok if I torque them back down.
Question #2 the bolts did not have washers or lock washers on them. is this normal?
Question #3 should I go with aftermarket t converter bolts?
post #6 of 9 Old 07-19-2012, 10:22 AM
Moparite
Moparite's Avatar
Quoted: 322 Post(s)
I'm not sure what you mean by"Drive plate"? There should be 6 bolts that attach the flexplate to the crank and 4 to attach the flexplate to the torque converter. What do the bolts look like as far as damage. Wear on the threads head etc..Picks? If they do need to be replaced it is specialty hardware and not something you are going to get a home depot.
Moparite is offline
post #7 of 9 Old 07-19-2012, 10:54 AM Thread Starter
kinkypuppy
Flexplate to torque converter.
They do not have lock washers
All 4 are two turns from coming off
I beleave torque speck on them are only 10 lbs.
The transmission was rebuilt by a local trans shop 2 yrs ago ( less then 1000 miles) I am finding wrong header bolts as well.
My ford has *ftermarket bolts with lock washers
post #8 of 9 Old 07-19-2012, 12:00 PM
JackedDak03
JackedDak03's Avatar
Quoted: 1 Post(s)
I can't remember 100% from when I removed mine but I don't think mine had lockwashers either. But they weren't easily removed, took some convincing to get them out. I'd throw some loctite on them and put them on to the correct torque specs, or really tight with a wrench.
BMW X5 & Chevy 2500 HD POS
Gone:
2002 Ford F350 Crew Cab Diesel
1999 Dodge Ram 2500 Quad Cab 4x4 Sport V10
1998.5 Dodge Ram 2500 Quad Cab 4x4 24V Cummins
2004 Dodge Ram 2500 Quad Cab 4x4 HEMI
2003 Dodge Dakota Quad Cab 4x4 4.7
2002 Dodge Ram 1500 Quad Cab 4x4 4.7
2001 Dodge Ram 1500 Quad Cab 4x4 5.9 V8
1999 Dodge Ram 2500 Quad Cab 4x4 5.9 V8
1997 Dodge Ram 1500 RegCab ShortBed Sport 5.9 V8
Past -92 Daytona R/T, 94 3000GT, 91 TransAm, 88 RX7 TII, 89 YJ, 92 Bronco, 88 YJ, 94 F150, 96 Rodeo, 88,89,90,91 5.0 Mustang's, 03 Mustang GT, 04 SRT4
JackedDak03 is offline
post #9 of 9 Old 07-19-2012, 03:28 PM
ozplanet
Just Call Me Oz
ozplanet's Avatar
Yep no lock washers and tighten as tight as you can they are in a tight area and if you try to over tighten the engine will rotate. They are also fine thread your lucky you checked the bolts are not that easy to find fine thread and just the right length to give you enough room to install.
94 SLT 1500
Flat Black 2wd
Mods: M1 / Comp Cams / 4.10 / 20" 3rd Gen Rims / 4/6 Drop / Flow Master 40's / All New Skins /
2010 Sport Crew Cab Black 4x4 5.7 3.92 Sport hood 10 Speaker Alpine w/nav
Mods: Diablo 91 Canned Tune / Billet Tech Oil Catch Can / Vararam Intake / Magnaflow Muffler / All Interior|Exterior Bulbs LED White / Recon Smoked 3rd Brake Light / Recon LED Light Bar / Orange Striping / Lockpick / Debaged|Murdered / 2 12" Foxbox / 2 Alpine SWR-12D4 Subs / NVX JAD1200.1 1200w amp / Flat Black VIP Wheels VP2 / Black & Orange Leather / Orange Interior Accents with Gloss Black /
Soon: Race Rotors / EBC Yellow Stuff /
ozplanet is offline
    1998 Ram Van 1500 rear end noise when turning rjs123 Dodge B-Series Vans 1971 - 2003 5 03-13-2012 07:56 PM
    1998 dodge durango transmission problem tremasthasav253 1G Dodge Durango - Drivetrain Talk 1 02-04-2011 10:53 PM
    FS: 1998 Dodge Ram 1500 samuelrclark For Sale - Dodge Trucks 2 01-15-2011 09:41 AM
    1998 Dodge Ram 1500 5.9 WHAT TO DO? Ramtough924 2G Dodge Ram Performance Talk 16 03-27-2004 07:30 AM
