body control module questions - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 05-29-2012, 10:45 AM Thread Starter
james832
On my 2002 caravan, the turn signals have quit but the turn signal lights on the insterment panel work. all lights and fuses and switches have been checked. A mechanic traced it down to the body control module. I was told that a used module must have the same part number and be reprogramed to work properly. If I install a used module with the same part number and same options, will the van start and run until I vsn get it reprogramed?
james832 is offline
post #2 of 7 Old 06-02-2012, 11:45 AM
stupendousman
If you obtain a replacement computer from the wrecking yard or used elsewhere, it must be from the same make and model of vehicle, with the same engine.
Once you have it, it will need to be reprogrammed for your particular vehicle by someone who has a tool to do so. This will almost certainly be the dealership. When I did this, it cost me 18 bucks for a used computer, but 120 for the program. The key for the vehicle has a chip inside it that the computer reads and determines if it is the correct key for the vehicle. If not, once you start it, it will shut off after a few seconds. After three tries, it won't even turn over. The reprogramming fixes this too and makes the new computer work with your keys.
stupendousman is offline
post #3 of 7 Old 06-03-2012, 05:09 PM
no_common_sense
Quoted: 11 Post(s)
Are you sure it's not just the combo flasher under the dash? It looks like a really long relay with 9 pins on it and it's got a logic chip inside it. It goes for about 35 bucks on rockauto.com. You can do a part number search for EFL15 or 1R2187 for the two brands they're offering.
No matter how much technology changes, there still isn't much that can't be solved with the sensible and practical application of a bigger hammer.
no_common_sense is offline
post #4 of 7 Old 06-04-2012, 07:01 PM Thread Starter
james832
My van does not have the security option, does mean that it will run until I get it reprogramed?
james832 is offline
post #5 of 7 Old 06-04-2012, 07:07 PM Thread Starter
james832
Will have to check out the combo flasher.
james832 is offline
post #6 of 7 Old 06-06-2012, 12:54 PM Thread Starter
james832
common sense= are you sure the flasher is under the dash I was told it was in the left rear quarter panel.
james832 is offline
post #7 of 7 Old 06-06-2012, 07:22 PM
no_common_sense
Quoted: 11 Post(s)
I don't know for sure, I've worked on a 96 and a 97 in the recent past. Both had their flasher under the dash. Just have a look for yourself. Go down and just left of the steering wheel and that's where a fuse and relay block should be. Like I said before, it looks like an oversize relay. About twice as tall as a normal relay with 9 pins on it.
    need some radio and body control module help fobxgpr 3G Dodge RAM - General Talk 2 11-19-2009 10:14 AM
    What does the Body Control Module do? Brieninsac 3G Dodge RAM - Interior/Exterior Talk 0 07-21-2009 09:12 PM
    Body Control Module Lukeboop 2G Dodge Stratus - General Talk 0 03-07-2007 02:32 PM
    Body Control Module question 97GCES Dodge Caravan General Talk 3 02-25-2007 08:05 PM
    91 GC LE Body Control Module je7275 Dodge Caravan General Talk 5 09-15-2006 12:07 PM
