Rear brakes sticking/locking up - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 05-28-2012, 04:32 PM Thread Starter
98hemi-ram
98hemi-ram's Avatar
Quoted: 41 Post(s)
So ive noticed my rear brakes seem to be locking the tires and sliding to a stop lately and im not really sure what might be causing this.
I put all new brakes in the rear (drums, shoes and springs) 2 years ago and they've only got around 11,000 miles on them. I'm just starting to get sick of my tires locking up on me like i am slamming on the brakes when im really just rolling to a stop.
98 Ram 1500 RCSB 2wd
5.7 Hemi swapped, Lowered and some shiny new paint!!
14.63 @ 93.20mph
98hemi-ram is offline
post #2 of 11 Old 05-28-2012, 07:04 PM
mad 1
mad 1's Avatar
check if the top of the shoe is resting on the pin at the top ,,, if not and gap the brake cables frozen and will cause this
2011 Ram Power Wagon
1997 Ram 1500 5.2 auto 4x4 ext
SCT tune by Hemifever, Fastman 50mm,14x3 open air cleaner, Magnaflow,4:11,, 265/75/16
1993 Jeep YJ4.6 Stroker,, 5 speed,
Alum. head, roller rocker, Duel header, Magnaflow,,4:56,, 33" MTRS,, 2"' lift, Warn Wench, Nates Bumpers
2007 700 Yahama Grizzly ATV
Maxis Bighorns, Power tip,, Play Ground SE Kentucky
2009 Blast 150 Toybox F/S
mad 1 is offline
post #3 of 11 Old 05-28-2012, 09:08 PM
BigGreenV10
Big Green
BigGreenV10's Avatar
Is your truck rear ABS the controller might also be sticking.
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #4 of 11 Old 05-28-2012, 09:19 PM Thread Starter
98hemi-ram
98hemi-ram's Avatar
Quoted: 41 Post(s)
yea its got rear ABS and my ABS light has not come on on my dash. I wont actually be able to pull my truck apart at all at least until i get home on the weekend Im just looking for any ideas before i pull it apart again
14.63 @ 93.20mph
post #5 of 11 Old 05-29-2012, 03:46 PM
BigGreenV10
Big Green
Well the ABS light will not necsssary come on for this problem coul also be a wheel cylender leaking an causing the pads to grab as they have fluid in there. Could be a few things.
post #6 of 11 Old 05-29-2012, 03:55 PM Thread Starter
98hemi-ram
98hemi-ram's Avatar
Quoted: 41 Post(s)
hmm im actually wondering if it could be the wheel cylinder now after talking to another friend of mine. Whatever it is doesnt happen everytime and is seems to be kind of intermittent.
Hopefully ill have time to pull the wheels off this weekend and take a look.
14.63 @ 93.20mph
post #7 of 11 Old 05-29-2012, 11:48 PM
little_yellow
audio is my game
little_yellow's Avatar
Quoted: 123 Post(s)
good luck. i had a massive problem with my brakes locking up. got worse the warmer they got. would get to the point it was like a e-brake with the brake pedal.
check axle seals and wheel cylinders first. go from there.
my problem was with new parts tho so since your dealing with old hardware, seals first
96 short box regular cab
323, 42lb cobra injectors, MSD 6-BTM, 52mm TB, mopar air gap intake, custom made turbo headers, fully forged bottom end, h-beam rods, bullet cams custom grind cam, edelbrock heads, 78/75mm turbo, snow water meth
tuned by flyin ryan!
5/7 drop
blow through with 4 fi bl 10's, crescendo BC5500 amp, double din ,big 3, 3 monster batteries, 220 amp alt
3rd gen steering wheel and auto window conversion
little_yellow is offline
post #8 of 11 Old 06-01-2012, 08:02 AM
dodgensince74
Quoted: 11 Post(s)
If both backs are locking up I would check the porportioning valve, abs unit or master cyl, if it is only one wheel then I would check the wheel cyl. If you take the rear drums off put just a dab of grease on all the metal to metal contact areas for smooth operation, just a dab. You might also try flushing the brake system since the fluid may have crap in it that could be causing issues.
01 1500 5.9, Q/C, L/B, 4X4
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
BFG LT285/75r16 A/T's
dodgensince74 is offline
post #9 of 11 Old 06-01-2012, 08:07 AM Thread Starter
98hemi-ram
98hemi-ram's Avatar
Quoted: 41 Post(s)
I'm pretty sure it's just the passenger side. Im going to try and pull the wheels off this weekend if I have time when I get home tomorrow.
14.63 @ 93.20mph
post #10 of 11 Old 06-01-2012, 09:34 AM
AC130Ghostrider
AC130Ghostrider's Avatar
I had this problem and mine was the control module. I know you said your drums were new, but if they are out of spec it will cause this. I had some drums turned on one of mine and they did too much causing them to lock up.
2013 Ram 2500 4x4 Crew Cab, 6.7L CTD, 285 BFGs
2006 Ram 1500 4x4 Crew Cab, 5.7L Hemi
2001 Ram 1500 4x4 "Off Road" Sport 5.9L QC, 3" PA BL, 2" TGC level, TGC CAs, BFG 315/70/17, SCT by Hemifever, Hughes plenum, Magnaflow hi flow cat/Y pipe, 1 ton steering
1999 Ram 2500 4x4 QC, 305 Nitto Extreme mud grapplers
AC130Ghostrider is offline
post #11 of 11 Old 06-01-2012, 02:09 PM
Zach571
Have you adjusted your brakes at all in that 11000 miles?? You don't even have to remove the wheels to do this, on most vehicles anyways, most of the rams never had the hole punched out...If the shoes are adjusted too loosely then they will be grabby because they go from loose on the drum to tight quickly, the shoes should always have just a little bit of drag on the drum. Good idea to take apart the auto adjusters (which never work automatically...) and clean up the threads and a little lube, make sure they turn easily. They only work in reverse so you could try backing up and hitting the brakes hard a few times, see if they tighten up.
Unless you find a leaking wheel cylinder or axle seal, I'm betting the shoes just need to be adjusted.
Zach571
Zach571 is offline
    rear brakes locking up?? tanker10 2G Dodge RAM - General Talk 9 11-24-2010 06:28 PM
    Rear Brakes Locking Up Even After Pedal is Released mattd860 1G Dodge Durango - Tire/Wheel/Susp Talk 7 06-09-2009 04:31 PM
    Rear Brakes Locking Up DenverCruiser 1G Dodge Durango General Talk 13 05-05-2009 06:40 AM
    Rear brakes locking up jaded 2G Dodge RAM - General Talk 3 02-18-2008 07:52 PM
    Rear brakes locking up toocheaptosmoke 2G Dodge RAM - General Talk 4 05-24-2006 04:17 PM
