How do you remove/replace a 1996 caravan tailgate? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 05-10-2012, 08:28 PM Thread Starter
skyoneder
Caravan 96
Question How do you remove/replace a 1996 caravan tailgate?
My mom backed up the van into a truck and now the liftgate got pushed in and it won't open, how would I go about removing it and then getting a used tailgate from a junkyard to replace it?
Thanks in advance.
skyoneder is offline
post #2 of 4 Old 05-19-2012, 10:40 AM
zarric
I would start by trying to remove the interior panal. If you have to, jjust bust it out. Once you have removed it, disconnect the latch as best as you can. Complete removal is your goal..
Get a 4x4 or a couple of 2x4s and nail them together real good.and cut them to the length from the passanger seat and leave enough space for a jack. So not to long and not to short. Jack it out carefully and keep plastic taped over the glassin case it shatters.
Once you jack it out, just disconnect the harness connectors,lifts, and get help removing the last few bolts for the gate itself.
Do not use the drivers seat for leverage!
2000 White Dodge Caravan 3.0 Engine
4 speed transmission
186K and counting
zarric is offline
post #3 of 4 Old 05-20-2012, 11:07 AM
htesto
I did this job last week ('99 caravan sport). Took a lot of time.The hinges on top have enough space between two halves to pass rope through. MAKE SURE ROPE IS STRONG ENOUGH!. Tied a rope about 5 feet long from one hinge to the other. Tied another rope to middle of first rope, ran it across garage rafter, then through pulley tied to second rafter, then tied it to 10 gallon bucket. Fill bucket with water, now you have 50 pound counterweight to the door.
Hinge has 4 bolts at top to roof of van, undo those and the door comes off. Counterweight allows you to manenuver door. I used same counterweight to work with junkyard door ($ 250 pick up at yard, $ 50 if you take it off yourself). Good luck.
htesto is offline
post #4 of 4 Old 05-20-2012, 01:28 PM Thread Starter
skyoneder
Caravan 96
great ideals, thanks guys, will try these out when I get those supplies, and probably some help from a friend or two!
    1996 Engine and Tranny Replace. want to tow. td1 Dodge Caravan General Talk 0 08-11-2010 09:01 PM
    how to replace front turn signal bulb on 1996 dodge caravan? blaaah Dodge Caravan General Talk 5 03-15-2009 09:17 AM
    how do you remove 1998 caravan tailgate handle pduck911 Dodge Caravan General Talk 7 03-22-2008 09:51 PM
    Need to remove and replace radiator 01 4.7 highpines 2G Dodge Dakota General Talk 1 12-01-2006 01:31 PM
    Replace or Remove the CAT Garage Boy 2G Dodge Dakota Performance Talk 15 10-02-2006 05:13 AM
