how much oil does your hemi take? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 20 Old 04-21-2012, 07:06 AM Thread Starter
cumminsmannow
diesel guy
cumminsmannow's Avatar
So I did another oil change on my hemi yesterday. First one was done at 3k and I used mobil 1 and have since learned that it makes the hemi tick more pronounced. So at 5k (yesterday) I changed it again and put amsoil in it. I didn't really pay attention last time as I was using 2 of those 5qt jugs of mobil 1. But this time I had the quart jugs of amsoil oe 5w20. After I changed my mopar filter for a new mopar filter It took all of 8 quarts to get it to the full line on the stick.
I could swear these motors are only sopposed to be 7 qt capacity.
So let me know how much you put in your hemi when you do an oil change, And make sure you say what year your truck is too.
2012 2500 megacab 4x4 hemi laramie.
Mineral grey/ Bright silver bottom.
cumminsmannow is offline
post #2 of 20 Old 04-21-2012, 07:22 AM
dwins1900
dwins1900's Avatar
7qts is what the hemi should take. Be careful not to overfill your oil it can do very bad damage to your motor because the oil wont cuirculate right. Make sure you have let the truck sit for at least 5 minutes without starting it to check the oil level so the oil seeps down to where it can be properly read. Also make sure the truck is on level ground. You may already know all of this but I would hate to see someone destroy a good motor. I would almost say filling it all the way to the fill line is not good just keep it in the middle of the safe line. At high rpms when your oil is to full the oil can get whipped into a foam and wont cuirculate and you will cease your engine, you can go drive it around and everything might seem normal. Ive heard of people going 150 miles with their oil to full and then shit hits the fan.
dwins1900 is offline
post #3 of 20 Old 04-21-2012, 09:26 AM
Ramjoe
Quoted: 3 Post(s)
7 qts on the dot!
Ramjoe is offline
post #4 of 20 Old 04-21-2012, 10:00 AM
PCP
what's my bore?
PCP's Avatar
all i can say is WHAT???
fill it till it's full and call it good.
510 rwhp and 522 foot lb of torque.
fastest 1/4 and 3rd time out 12.33 at 110 mph
check out our rat rod build.
Don't TOUCH my truck Club # 92
Silver truck club #235
Trucks and Guns Club #145
PCP is offline
post #5 of 20 Old 04-21-2012, 12:45 PM
Ramjoe
Quoted: 3 Post(s)
go by the book. I would not put a whole extra quart in. 7 is all you need. If it is in the hash marked section of the dipstick and not on add then there is no need to add more oil.
Ramjoe is offline
post #6 of 20 Old 04-21-2012, 05:07 PM Thread Starter
cumminsmannow
diesel guy
we are talking well below the hashed area of the stick with 7qts
post #7 of 20 Old 04-21-2012, 07:42 PM
dwins1900
dwins1900's Avatar
[QUOTE=PCP;4337461]all i can say is WHAT???
Dude do some research on adding to much oil to a vehicle
post #8 of 20 Old 04-21-2012, 07:47 PM Thread Starter
cumminsmannow
diesel guy
Yes it may be too much oil for a normal vehicle. But I am only putting enough oil in it to be at the full mark. If the motor blows they can put a new one in it because i only filled it to the full mark.
Sent from my Autoguide iPhone app
post #9 of 20 Old 04-22-2012, 06:09 AM
zabman
zabman's Avatar
7.7 litres for us Canuks.
2009 QC Sport loaded,debadged,Borla Pro XS,LineX,Zeibart,ARE tonneau,tint, Mopar T handle,OEM flares,Vararam,JBA headers.
zabman is offline
post #10 of 20 Old 04-22-2012, 02:26 PM
HEMIHag
HEMIHag's Avatar
I'm on my thrid Ram with a Hemi. Always did my own oil changes and only put 7 quarts in. Never checked the dip stick to see where it was at, cause I didn't worry. My father in law has my first one still with 150,000 on it and has no problems.
The manual says 7 quarts so that's what it must be. Don't think they would tell you to put in less than the engine should take or they'd probably be doin a bunch on engine replacements. Put in more at your own risk.
2011 RAM 1500 OUTDOORSMAN
Extang Trifecta Tonno, Mufflex muffler w/ no reso dumped, K&N CAI, 4" Rough Country Lift
20" Fuel Offroad Pump's w/ 35x12.5 Toyo Open Country ATII's, Readylift UCA and Offroad Steering Kit, Fox shocks all around front coilovers set at 1"
HEMIHag is offline
post #11 of 20 Old 04-22-2012, 03:48 PM Thread Starter
cumminsmannow
diesel guy
So i let the truck sit for almost 24 hrs since i got home yesterday and went out and pulled the stick. I am roughly 1/4" over the full mark. So i do have too much in there but not by much. Maybe a 1/4 of a quart. I will drain a little out later when i get home. And from now on i will just put in 7 and not worry about it.
post #12 of 20 Old 04-22-2012, 04:42 PM
dwins1900
dwins1900's Avatar
There is a lot of oil that sits inside the the engine and allowing it to seap back down to where the level can be checked is important, my uncle was a mechanic and would tell me all the time that someone put way to much oil in. He said it is also just as important to check it on level ground.
post #13 of 20 Old 04-22-2012, 07:29 PM
Second_Life
Second_Life's Avatar
From the Owner Manual
5.7L Engine (SAE 5W-20, API Certified) 7 Quarts/6.6 Liters
2011 Ram 1500 Outdoorsman Crewcab 4x4
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - AirLift 1000 - Bully Dog GT for Hemi Plus
Second_Life is offline
post #14 of 20 Old 04-25-2012, 10:41 PM
lvrr
lvrr's Avatar
Quoted: 4 Post(s)
If you took 8 quarts to read full you may want to hop over to your dealer and check to make sure your dip stick is the proper length for the engine. In my earlier lifetime as a mechanic I have come across one or two sticks that were not made properly and were short giving incorrect readings.
Just tell them the situation and that you would like it checked.
lvrr is offline
post #15 of 20 Old 04-25-2012, 11:17 PM
TwinStick
Or check it with someone elses truck. Even though it may only be a 1/4" above full, it could still be 1 qt overfilled. Reason: maybe above the full mark on the dstick, the area opens up a lot. So it would not be the same as, bottom of safe mark = add 1 qt. Not 100% sure though.
Mine takes 7.
My 04 w/6 pass engine oil cooler, lines & larger filter, took 9.
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
post #16 of 20 Old 04-26-2012, 07:39 AM
Ramjoe
Quoted: 3 Post(s)
bottom line 7qts is all that is required. any more is pointless and will do more harm than good.
Ramjoe is offline
post #17 of 20 Old 04-27-2012, 04:11 PM
hawk02
Quoted: 1 Post(s)
My 05 takes 8 with the oversized filter.
hawk02 is offline
post #18 of 20 Old 04-27-2012, 04:57 PM
2011_Ram_RT
2011_Ram_RT's Avatar
7 is correct.
2011 Flame Red Ram RT (mine):
Mods: Bedrug
2010 Brilliant Black Mustang GT coupe (Wendy's):
2011_Ram_RT is offline
post #19 of 20 Old 05-07-2012, 05:52 PM
hounddogg
hounddogg's Avatar
Tick on startup is caused by the oil filter. Not the oil.
2009 Quad Cab SLT White,Hemi,2WD,20 inch wheels,3.92 gear.2003 Quad Dually 4x4,6 speed,4.10 gears,diesel.Banks 4 inch exhaust,Afe Pro Guard filter,Rottech crank sensor mod.Amsoil fliuds front to back.08 Corvette Convertible.
hounddogg is offline
post #20 of 20 Old 05-07-2012, 06:09 PM
MSparks909
MSparks909's Avatar
My 06 takes 8 with the larger K&N oil filter.
06 Black QC G56, 76K miles and counting...
Thuren coils, tracbar, control arms, shackles, draglink, limit straps, towers, Stage 3 front King 2.5's, DBL Bypass rear King 2.5's, Carli leaf springs, Carli upper & lower BJ's and diff cover, PSC notched steering brace, 08.5 "T" linkage, PSC Extreme Duty Steering Box, Borgeson Lower Steering Shaft, Magnaflow muffler, Airaid Intake, American Racing ATX Thug 17x8.5, Yokohama Geolander AT/S 37x12.50x17, Rockcrusher rear diff cover, Airflow snorkel (fitted to Airaid full intake), Magnaflow y-pipe & Flowmaster Super 44 muffler, Go Recon Super White cab lights, EBC slotted rotors/Yellowstuff pads, winch thermal bypass & locker bypass, Pit Slave-modded SmartBar, greasable front u-joints, tint, JL Audio 12" subwoofer & JL Audio 500W amp with adjustable bass knob
Upcoming Mods:
Flowtech Headers, Line-X rocker panels/fender flares, eBay black mesh grill, DIY blacked-out headlights, Diablosport programmer, chopped rocker panels, tube bumpers F/R, Rigid Industries LED lightbar, axle truss, stiffer shock valving, VH tire carrier, Mastercraft Baja RS seats, Filtermag, Go Pro HERO 2
MSparks909 is offline
    Volant CAI + Ram Air Setup for HEMI with SRT hood (Daytona/Rumble Bee, HEMI Sport) RTICWOLF For Sale - Truck Parts 2 09-30-2009 03:05 PM
    Airaid Throttle Body Spacer for HEMI Ram and HEMI Durango - PICS! SiZzOuRcE For Sale - Truck Parts 14 04-30-2007 10:42 PM
