Help with reomving from caliper bolts - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 12 Old 11-11-2004, 03:35 AM Thread Starter
huh?
Run it 'til it DIES!!!
I am trying to change the the front brake pads, putting ceramics on, on my 1998 Durango and seem to be running into a problem. What is the caliper bolt head shape? Is it a hex? or is it a Star? Also what size is it?, as I got the wheel off, after rotating my tires and then tried using a 1/4 hex allen wrench and it was lose and started to spin, so instead of completly ruining it I decided to put the tire back on and write for help.
So help, please?
Also how hard is it to change the rear drum brake pads?
anyways, thanks,
huh?
1998 Dodge Durango SLT 4X4
5.2 V8
Over 151,000 miles
Gas Mileage= 11.5 mpg
Stock Everything-
except:
4 *NEW* 31x10.50x15 ProComp A/T (bitchin
Autolite 5224's SparkPlugs
Fram PCV (replaced every 5k miles)
and the ABS and Brake light is on 4ever! (yeah, sarcasm
Check out: www.thememoryhole.org
huh? is offline
post #2 of 12 Old 11-11-2004, 03:54 AM Thread Starter
huh?
OK, tell me if this is right or not, is it a 7mm hex allen wrench?
Also what would I use to remove them if I accidentally stripped them out? Haven't yet, but just in case would like to know.
huh?
5.2 V8
Over 151,000 miles
Stock Everything-
except:
huh? is offline
post #3 of 12 Old 11-11-2004, 05:17 AM
Almond Pale Ale
Patriot....
Almond Pale Ale's Avatar
I believe it is 7mm but I haven't done brakes yet so I'm no help there.
2004 Ram 2500 4x4 SLT, 305/555 CTD, 48RE, QC, LB
Intake: aFe Stage I intake, aFe Torque Tube Exhuast: IMCO HD performance muffler Drivetrain: PML rear diff cover, PML Tranny cover, Bilstein shocks Power: Diablosport Power Puck set on 60hp/100tq Fluids: AMSOIL front to back
Almond Pale Ale is offline
post #4 of 12 Old 11-11-2004, 05:28 AM
coachholland
Backwoods Hillbilly
coachholland's Avatar
If they're starting to round out, after you get them out, I would highly recommend changing them out to aftermarket ones from Advance or Autozone. They are normal bolt heads you can take off with a socket.
7mm is the correct size I believe.
2005 Durango Limited Hemi Bone Stock for Now.
Previously:
*DodgeTalk.com 318 Enthusiast Member #(5)*
1999 Durango SLT 4x4 5.2 V8 Light Driftwood Satin
Engine and Exhaust Mods
Mopar Performance PCM. 360 Air Intakez Power Shot w/ heat shield. DynoMax Super Turbo exhaust. Autolite Platinum 3923 Plugs. 180 T-Stat.
Interior Mods
EVS II Plus Security. Upgrade interior seating and door skins to leather. Replaced cassette w/ factory CD/Cassette then replaced w/ Pioneer DEH-45DH. Pioneer speakers. Powered MTX Thunderform. Dynamat Xtreme on all doors. APC White Face Gauge.
Exterior Mods
Front windows 20% tint. Ventshade window air deflectors. Blue Xenon headlights. Street Scene Grill Inserts. Diamond Cut Headlights and Corners. Altezza tails. Chrome grill. Chrome Bumper w/ stock valance. Polished Billet Locking Fuel Door. Mirrored Ram's head front license plate. Ram's head rear window sticker. Installed OEM fog lights. Polished stainless steel nerf bars. Chrome rear differential cover. Fender flares upgrade.
Wheels and Suspension
Monroe Sensa-Trac shocks. Drilled and slotted performance brake rotors. Aluminum to alloy wheels upgrade.
To Do List:
Custom Striping (To be installed). Fastman TB. Mopar Performance M1 Intake. Anodized Engine Accents. Performance Headers. Chrome Wheels.
Replacement Maintenance and Repairs:
Rear speed sensor. Window motor. Greasable upper ball joints. Water pump. Goodyear Wranglers. Mopar plug wires.
coachholland is offline
post #5 of 12 Old 11-11-2004, 12:06 PM
Neil F.
Neil F.'s Avatar
Some are allen and others are torx. 7mm allen or T-45 torx. The torx bits will comme off with the correct size allen. It's a good time to get a full set of metric and standard size allen wrenches.
99 Durango 5.9, FT 4x4, IP stage III w/ K&N air hat, M1, MOPAR PCM, Fastman TB, 1.7 RR, JBA headers, Borla cat back, Martin Saine valve body, Hotchkis swaybars, Blistein shocks, lowered 2" Black Rhino Kenya wheels, 246. 7 RWHP, 319 TQ
Neil F. is offline
post #6 of 12 Old 11-12-2004, 02:22 PM Thread Starter
huh?
Thanks for info.
I after getting the wheel off the other day I tried using a 1/4 size allen and it started to spin in the bolt, so I put the tire back on. Went to Sears to buy a 7 mm Allen bit and a T-45 Torx for my 3/8 wrench, but also ended deciding to buy a new craftsman air compressor w/15 gallon tank and a 75 peice Air tool set to help me with doing the job a little easier.
The question I have for you all now is how hard are the rear brakes to change? And are there any special things to know about changing them? ANy tips?
huh?
5.2 V8
Over 151,000 miles
Stock Everything-
except:
huh? is offline
post #7 of 12 Old 11-15-2004, 07:59 PM
MrCleanY0
Bob
MrCleanY0's Avatar
yeah.....don't forget to adjust your parking brake back to normal. I addidently forgot that one time and the brake went right to the floor. prolly not a HUGE prob. with an auto trans for some people but I HATE letting it roll to a stop in park (if you know what i'm talking about). I wanna keep that puppy going as long as possible.
1999 Durango SLT 5.9 4x4
DVD w/ 2 TV's
Pioneer DEH-8400 CD MP3 player w/ custom Infinity components
3" body lift
33" Hankook M/T's
Flowmaster 40 series exhaust
MrCleanY0 is offline
post #8 of 12 Old 11-16-2004, 06:20 AM
Neil F.
Neil F.'s Avatar
Do not use an air wrench to put the caliper bolts on! The rubber sleeves on the calipers make it pretty easy to mialign the bolts. The metal in the calipers also must be pretty soft to start with, myself and others have managed to strip the caliper bolt holes. An air wrench is a sure way to do it.
Neil F. is offline
post #9 of 12 Old 02-02-2005, 03:06 PM
frankfargo
I've repaired these with great success by using Helicoil 9mm x 1.25 inserts (with the helicoil supplied tap) and, from what I remember, a 22/64 drill. follow instructions & your problem with be absolutly cured.
'01 4.7 Durango 4x4, CJ-5, CJ-7, F-150 351 4x4, Intrepid, '73 Javalin 390 4sp, '87 Turbo Supra
frankfargo is offline
post #10 of 12 Old 02-02-2005, 03:36 PM
Fractal_Tech
Shawn the repairer
Listen to Neil about the air tools, the calipers are not the place for those, you really need to be able to feel how the bolt is threading and how tight you end up if you don't have a torque wrench.
Signature Police Officer # 015
2001 Durango SLT+ Dodge Red, 79,350
Factory Options: Running Boards, Fender Flares, 4.7 L engine, 4X4 on demand, 3.55 Gears, Open Rear Differential
Interior: Red Interior Lights, Carpet Stains,
Exterior: GrilleTech Race Grill
Engine: Autolite 3923's,
Suspension: Bilstein Shocks, T/S ~2" Lift
Armor: Front Winch Bumper, Steel Rear Bumper
Recovery: Mile Marker 12KLb Winch, 30Klb Tow Strap, 48" HiLift Jack
2001 Durango SLT Silver
Factory Options: Fender Flares, 4.7 L engine, 3.55 Gears, Open Rear Differential
Mileage: 74,250
Engine: IP Stage II w/9" Big Mouth, Autolite 3923p's, aftermarket seat heater
1996 Buick Riviera (Daily Workhorse)
Mileage: 107,500
Fractal_Tech is offline
post #11 of 12 Old 02-02-2005, 03:59 PM
frankfargo
You're right. Don't use air tools, they're overkill and not needed for this. It's cast iron and you'll need to take it easy.
post #12 of 12 Old 02-05-2005, 12:17 AM
Almond Pale Ale
Patriot....
The T-case plug is a 10mm allen head - just to add to what Neil said (i.e. more justification to buy tools!)
