Oil Pan Bolts - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 03-16-2012, 10:48 AM Thread Starter
impuresoul2k3
Oil Pan Bolts
Does anyone know the size of the oil pan bolts? I want to replace my leaking oil pan gasket, and I want to use the oil pan tools to help with that.
impuresoul2k3 is offline
post #2 of 8 Old 03-17-2012, 03:05 PM
DODGEPICKUP
DODGEPICKUP's Avatar
Quoted: 2 Post(s)
.312-18x.875.....12mm socket
1999 RAM 1500SPORT QC 4X4 5.9 3.55's grrrr
360 MAGNUM POWER 165,000 MILES DYNOED 230/290 ON 35'S
1.7 CRANE ROLLER ROCKERS
DIY CUT,PORTED,EPOXY FILLED KEGGER/ALUMINUM PLENUM PLATE,53MM THROTTLE BODY
JACOBS PRO STREET CD IGNITION
BOSCH DESIGN 3'S 24LBS VETTE INJECTORS
MOPAR P DOUG THORLEY TRI-Y'S
TAYLOR 8.2 THUNDERVOLT WIRE'S
EBC ROTORS N PADS,RUSSELL SS BRAKE HOSES
MARCH UNDERDRIVE CRANK PULLEY
1 TON X-OVER STEERING
DT PRO-FAB TRAC BAR
HELL BENT STEEL 2IN SPACER/SKJ LCA
WINNDEKAR/DSS STEERING BRACE
DODGEPICKUP is offline
post #3 of 8 Old 03-18-2012, 11:50 AM Thread Starter
impuresoul2k3
I'm assuming you mean 5/16? Thanks for the help!
post #4 of 8 Old 03-18-2012, 08:27 PM
BigGreenV10
Big Green
BigGreenV10's Avatar
What is oil pan tools besides normal socket and wrench? Also 5/16 might fit but it is metric.
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #5 of 8 Old 03-18-2012, 11:37 PM Thread Starter
impuresoul2k3
So 8mm then?
The "tools" are these:
http://www.autozone.com/autozone/acc...mString=search
The screw into four corners of the block, and you can clip the gasket and pan into them. A set was included when I did my sister's Sable. They made the job a whole lot easier because the pan and gasket stay in alignment 1/2" from the gasket surface.
post #6 of 8 Old 03-19-2012, 02:13 AM
wiseone
disenchanted
wiseone's Avatar
http://www.stage8.com/moparoilpan.html
Install these and never worry about a leak from bolts coming loose.
wiseone is offline
post #7 of 8 Old 03-19-2012, 07:27 AM Thread Starter
impuresoul2k3
These are just for install, once the pan is bolted up, you use a flatblade screwdriver and remove the tools, then you put in regular bolts.
post #8 of 8 Old 03-21-2012, 01:09 AM
DODGEPICKUP
Quoted: 2 Post(s)
when i replaced my oil pump(2x) the gasket was stuck to the block both times....you can use gasket-cinch....it will hold the gasket in place for u....guess i was lucky....no leaks up to this point......
DT PRO-FAB TRAC BAR
    Cam Bolts WickedQuick 2G Dodge RAM - 4X4 Talk 10 07-16-2011 02:24 PM
    U-Bolts ozplanet 2G Dodge RAM - General Talk 32 07-16-2009 08:28 AM
    Wheel bolts/axle bolts vwdee 2G Dodge RAM - General Talk 0 04-14-2009 10:42 AM
    u-bolts 06HEMIon24s 3G Dodge RAM - Sport Truck Talk 6 05-13-2007 11:05 AM
    Were to buy u-bolts? Davcruz 2G Dodge RAM - 4X4 Talk 6 04-02-2007 10:00 PM
