Vibration On The Right Front Wheel When Braking - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 02-27-2012, 05:59 AM Thread Starter
Hemi Von
Hemi Von
Hemi Von's Avatar
I have a 2006 Hemi Ram shortbed 2WD that I bought new, it now has 45K miles and I changed the front pads at 25K even though it did not need them, did not cut the rotors, they looked fine.
Have a nice set of Michelins on it with less then 10K miles. Recently noticed a bad vibration when braking from speed with and without the trailer, when driven just around town don't notice it, just when slowing down fast from highway speeds. Any help will be appreciated.
Hemi Von
Hemi Von is offline
post #2 of 9 Old 02-27-2012, 10:02 AM
71'dart
Don't mean to hijack but I have a simular thing happen on my truck.2005 4x4 1500.
in town fine above 50 with moderate to heavy braking it pulsates.
also when backing up slowly and turning sometimes i get a humming noise.
It has 68000 miles and all 4 corners was upgrade to brakemotive drilled slotted rotors last fall maybe 10000 miles ago
71'dart is offline
post #3 of 9 Old 02-27-2012, 01:45 PM
DodgeCares
Dodge Cares
DodgeCares's Avatar
Quoted: 38 Post(s)
Hemi Von
Von,
There was a TSB that could be related to your issue. I have posted it below.
NUMBER: 02-001-07 REV. A
GROUP: Suspension
DATE: March 31, 2007
SUBJECT:
When Braking The Vehicle May Drift To One Side Or Exhibits A Body Shudder
OVERVIEW:
This bulletin involves identifying the type of vehicle drift that may be present and
implementing the appropriate repair procedures for the type of vehicle drift.
MODELS:
2006 - 2007 (DR) Ram Truck (1500)
NOTE: This bulletin applies to 4x2 and 4x4 light duty (1500 model) vehicles built on
or before November 27, 2006 (MDH 1127XX).
SYMPTOM/CONDITION:
The customer when braking may experience a vehicle drift to one side and/or a vehicle
body shudder. This condition may be more noticeable when brakes are applied at speeds
of 88 km/h (55 mph). The vehicle body shudder may exhibit itself as: steering wheel shake,
brake pedal pulsation, or seat or floor vibration.
DIAGNOSIS:
1. Verify that all four (4) vehicle road tires are in good condition
2. Verify that the tire pressure in all four (4) vehicle road tires are set to 241 Kpa (35 psi).
3. Road test the vehicle in a safe environment on a flat and level road at a highway
speed of approximately 88 km/h (55 mph).
4. Without applying the vehicle brakes. Does the vehicle exhibit a drift to the left, right,
or both sides on a flat and level road? Record the direction of vehicle drift.
a. If YES >>> then perform the section of the Repair Procedure for “Front Tire
Cross-Switch and Front End Alignment”.
b. If NO >>> then proceed to the next step.
5. Apply the vehicle brakes. On a flat and level road, does the vehicle exhibit a shudder
or drift to the left, right, or both sides that is different than when the vehicle brakes are
not applied? Evaluate the vehicle when braking several times (during deceleration, at
the end of a stop, or during light, moderate, or hard stops).
GROUP: Suspension
a. If YES >>> then perform the section of the Repair Procedure for “Front Lower
Control Arm Bushings Replacement”.
b. If NO >>> then this bulletin does not apply.
DodgeCares is offline
post #4 of 9 Old 02-27-2012, 02:16 PM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
So the thoughts, Seperated belt on tire (Dont hear of it with Michilins), Draging caliper causing rotor to warp, Rotor warpped due to heavy braking, Control arm bolts loose or control arm bushings bad.
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #5 of 9 Old 02-27-2012, 10:34 PM Thread Starter
Hemi Von
Hemi Von
Hemi Von's Avatar
Chris, thanks for your quick and very complete reply, I am going to jack it up and check the control arms. Hemi Von
Hemi Von is offline
post #6 of 9 Old 02-28-2012, 10:25 AM
DodgeCares
Dodge Cares
DodgeCares's Avatar
Quoted: 38 Post(s)
Hemi Von,
Hope it helps you figure out your problem.
post #7 of 9 Old 02-28-2012, 10:44 AM
sony224422
sony224422's Avatar
Quoted: 8 Post(s)
Classic warped rotor. For what it's worth, ive always been told to do pads and rotors as a set. They wear to each other and when new is put with old, different contact points and wear. Rotors aren't that expensive to just replace with pads anyways..
2004 QCSB 2500 hemi with 4.10s Laramie
Back rack with whelen freedom 2 light bar (custom made by me with extras)
Whelen Par 36 aircraft landing lights behind the grill, Whelen par 36 spot lights for reverse lights, Whelen strip lights in the bed (6 in total), Whelen cencom to control everything
In bed tool box with lights and extra battery with isolator and also a solenoid to connect both batteries together if i need to
Color matched grill,
Fox box with 2 diamond d3 12's with Diamond d3 600.1 amp
SRT-10 a pillar with trans temp gauge
Mag-tec trans pan
Superchips 3865 with trans tuning
Nitto trail grapplers
POWER WAGON WINCH SET UP
Alpine ina-w900bt with reverse camera
Alpine type r 2 ways in the doors powered by alpine pdx-f4
steering box brace
sound deading
Big 3 done with 4 gauge
E-fan
POR-15 the frame and under body
Jimmy jammers
sony224422 is offline
post #8 of 9 Old 02-28-2012, 10:53 AM
sony224422
sony224422's Avatar
Quoted: 8 Post(s)
Also check to make sure both sliders on the calipers are free
Mag-tec trans pan
steering box brace
sound deading
E-fan
Jimmy jammers
post #9 of 9 Old 02-28-2012, 04:05 PM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
I typically get 3 to 1 on the brakepads to rotor, doing 1 to one is throwing away $. Its different if your warping your rotor by end of pad life.
dizzyD is offline
    Vibration in steering wheel while braking azlakerfan12 4G Dodge RAM - Drivetrain Talk 8 08-29-2011 10:38 AM
    Bad Wheel Bearing = Vibration while braking? jmmagrin 3G Dodge RAM - General Talk 14 09-29-2009 07:19 PM
    Source of front wheel vibration BONE WSO 1G Dodge Durango - Tire/Wheel/Susp Talk 0 10-29-2008 11:22 PM
    squeaky drivers side front wheel/bad vibration 10cylinderRAM 2G Dodge RAM - General Talk 2 08-24-2006 11:39 AM
    Vibration While Braking?? MDavison 3G Dodge RAM - General Talk 4 08-27-2003 12:06 AM
