'00 1500 V10 Project Thread - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 652 Old 02-26-2012, 09:11 PM Thread Starter
prototype4342
prototype4342's Avatar
Quoted: 25 Post(s)
Ok, I finally pulled the trigger and bought myself a V10 donor truck, so I can transplant that huge engine into my little 1500. My engine recently developed a loud chirping noise, which we eventually narrowed down to crank walk [friend who is a mechanic thinks it may be a hairline crack in the crankshaft]. We had a bit of extra money laying around so we bought the donor yesterday. It's a '96 2500 V10 5-speed truck 4x4 with 153K miles on it and a bad clutch.
It took us awhile to decide whether or not to get it, since we couldn't check the rest of the drivetrain components behind the V10. When the motor in our current 1500 decided to take a dump [at 116K miles, no less] we decided something needed to be done, so that was my motivation. Luckily they changed from OBDI to OBDII in '96 so I'm hoping the wiring will all be fairly easy. I'm also hoping I can still use my current gauge cluster, because I don't really like the looks of the one in the '96.
Anyone know if a steering column transplant is required for a manual transmission swap? Or can I just take the column shifter out?
Enough talking, I suppose. Here are the pics I took of the donor. It's rough, dash is shot, and the front of the frame near the bumper is rusted. Engine runs great so far, no strange noises. Trying to decide if I should axle swap.
And the beast
Blue Truck Club Member # 245
Cracked Dash Enthusiast Club Member #29
2000 Dodge Ram 1500 RCSB: 8.0L V10/NV4500 swap, 3/4 ton axles...IT'S ALIVE!!!
1981 Chevy Camaro: 5.7L '86 350 LT9, Edelbrock Performer Intake man., Edelbrock 600 carb., Drop base air cleaner, unnamed headers, pypes crossflow exhaust, ECP all aluminum radiator, Mark VIII electric fan, PTFB GT suspension, single adjustable AFCO shocks, C/E subframe connectors, 4-speed.
1998 Jeep Cherokee: Stock
1988 Dodge B350 Maxi Wagon: Stock
1998 Kawasaki KLX300R: Mikuni t36 carb, Stroker exhaust, plated
1986 Yamaha FJ1200: Stock
2007 Triumph Tiger 1050: Stock
prototype4342 is offline
post #2 of 652 Old 02-26-2012, 09:13 PM Thread Starter
prototype4342
Quoted: 25 Post(s)
Here's the truck it's going into, overall in great shape, none of the normal issues aside from dash crack and faded clear coat.
post #3 of 652 Old 02-26-2012, 10:21 PM
Zable49
Not Great But It's Mine
What do you have to change out???? I know engine, wiring, what else?
1998 Dodge Ram 1500 4x4 - SOLD!!! :-( I miss her
*DodgeTalk.com 318 Enthusiast Member #(82)*
*DodgeTalk.com Green Truck Club Member #(33)*
*DodgeTalk.com Military Truck Club Member #(33)*
*DodgeTalk.com Quad Cab Club Member #(15)*
Zable49 is offline
post #4 of 652 Old 02-26-2012, 10:47 PM Thread Starter
prototype4342
Quoted: 25 Post(s)
Well mine will be more difficult than a V8/auto to V10/auto swap, since my donor is a 5-speed manual. Mine is going mostly by ear, but I know it will be:
engine
transmission
transfer case
motor mounts
radiator
all engine and trans related wiring
driveshafts [they'll need to be shortened as well]
and any odds and ends stuff, it never goes completely according to plan, but so far as I have read it is a bolt-in swap, especially since I have a donor truck for all the parts. I'll keep track and hopefully have a list of parts by the end.
I may also be swapping axles, and swapping springs may not be necessary but I think the spring rate may cause issues with the 1500 springs and V10 weight.
post #5 of 652 Old 02-27-2012, 12:10 AM
TrappedPerson
Stock floor bodydropped
TrappedPerson's Avatar
Quoted: 11 Post(s)
Is that a reg cab long box the V10 is in???? Thought they only came in ext cabs. Wow
1996 2WD 1500 RCSB claret red-- Bagged and bodied
TrappedPerson is offline
post #6 of 652 Old 02-27-2012, 11:16 AM
Smokeybones
Smokeybones's Avatar
Good eye! i have never seen one either didnt know they made em
Current- Audi A6 2.7 Bi-turbo Quattro
01 2500 4x4 ext cab Lwb Cummins!
Silencer ring MIA, 3" Exhaust, K&N Intake 2.5 leveling kit SOLD!
1997 1500 4x4 ext cab sport Arctic White SOLD!
1999 1500 4x4 ext cab Sport Electric blue SOLD!
1998 1500 4x2 360 Single cab LWB SOLD!
Flowmaster 40 No Cats True Duals
Rhino spray in liner
Tint, Rain Guards, Bug Shields
100k Club!!!!!!!!!! #35
Cracked Dash Enthusiast Club #19
Blue Dodge Truck Club Member #216
Smokeybones is offline
post #7 of 652 Old 02-27-2012, 11:35 AM
JackedDak03
JackedDak03's Avatar
Quoted: 1 Post(s)
It should literally bolt right in - computer and all. As for your column, you can use the auto column, just put it in park, remove the shift lever, and use the plastic covering from your donor truck. You can swap over your gauge cluster so you'd never know it was a manual. As for everything else, it should bolt right in if you use everything from your donor truck (driveshafts, axles, tranny, transfer case, engine). The only modification will be the spring perches on the 2500 axles, the 1500's are narrower I believe.
BMW X5 & Chevy 2500 HD POS
Gone:
2002 Ford F350 Crew Cab Diesel
1999 Dodge Ram 2500 Quad Cab 4x4 Sport V10
1998.5 Dodge Ram 2500 Quad Cab 4x4 24V Cummins
2004 Dodge Ram 2500 Quad Cab 4x4 HEMI
2003 Dodge Dakota Quad Cab 4x4 4.7
2002 Dodge Ram 1500 Quad Cab 4x4 4.7
2001 Dodge Ram 1500 Quad Cab 4x4 5.9 V8
1999 Dodge Ram 2500 Quad Cab 4x4 5.9 V8
1997 Dodge Ram 1500 RegCab ShortBed Sport 5.9 V8
Past -92 Daytona R/T, 94 3000GT, 91 TransAm, 88 RX7 TII, 89 YJ, 92 Bronco, 88 YJ, 94 F150, 96 Rodeo, 88,89,90,91 5.0 Mustang's, 03 Mustang GT, 04 SRT4
JackedDak03 is offline
post #8 of 652 Old 02-27-2012, 03:39 PM
BigGreenV10
Big Green
BigGreenV10's Avatar
Just start it already we will figure out what is needed when you get to that point.
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #9 of 652 Old 02-27-2012, 04:28 PM Thread Starter
prototype4342
Quoted: 25 Post(s)
I got the radiator and support off yesterday, just took some pictures today. I snatched the upper intake off today, but forgot my masking tape and sharpie, so that's as far as I got. I pulled the dash out, every time I touched something plastic, it broke off. Something is still holding the full dash from being pulled out, but I'll get to that later.
Here they are sitting together, oh and the wife over in the corner.
post #10 of 652 Old 02-27-2012, 04:41 PM
Foshv10
Foshv10's Avatar
are you parting out the rest of the truck??? im looking for body parts for my truck if you are, i need fenders, and short bed.
1998 Dodge Ram 2500 Laramie V10
1. Custom CAI w/k&n filter
2. Flowmaster Dual-side exhaust
3. Edelbrock Performer IAS Shock Absorbers
4. Hemifever SCT Tuned
5. 305/70/16 Fierce Attitude M/t
Foshv10 is offline
post #11 of 652 Old 02-27-2012, 09:32 PM
spun360
spun360's Avatar
Quoted: 162 Post(s)
? we are making a 2000 v10 4x4 5speed short bed ?
parts for sale
ask about my treadwright retread experience
$150: 210lb double and dampener valve springs .550 lift
$pay shipping: new, dana/ spicer (1)greasable upper & (1)lower ball joint for dana 44
$pay shipping: new, standard oil pump
$pay shipping: new, super strength moog #377 frt axle hub universal w/ grease fitting
prices (for residence of the US)
cheep
shoot PMs my way
spun360 is offline
post #12 of 652 Old 02-27-2012, 09:57 PM Thread Starter
prototype4342
Quoted: 25 Post(s)
Wouldn't mind selling a few parts, I don't think I'll get much for this truck if I transplant the v8/46RE in it, so it will probably just go to a scrap yard when I am done. Although it's a long box, not short.
Yes, yes we are.
post #13 of 652 Old 02-27-2012, 11:54 PM
TrappedPerson
Quoted: 11 Post(s)
Came with some nice headlights. That retro shop guy here on DT just made some projectors out of a set just like that. This guy will give you a basic idea how to remove the whole dash
post #14 of 652 Old 02-28-2012, 02:34 PM
JackedDak03
Quoted: 1 Post(s)
Oops didn't realize you had a short bed (work computer is blocking all of your pictures).
Then yes your driveshafts won't work LOL
Gone:
post #15 of 652 Old 02-28-2012, 03:26 PM
BigGreenV10
Big Green
You will have to do a write up each day and then edit it so it is in one post. Take allot of pics as this is something someone else will be asking and havent scene it done yet.
post #16 of 652 Old 02-28-2012, 05:38 PM Thread Starter
prototype4342
Quoted: 25 Post(s)
I'm going to take the 2500 shafts and get the rear one cut and front one lengthened. I will need to do this after the axle swap, though, so I have the right lengths.
I will try to do a bit of a write-up. Although if it is a bolt in as a few have said, a write up won't even be necessary. I honestly think the hardest part will be the manual swap stuff. I have been taking pictures of all the connectors next to what they connect to, I always end up with one or two connectors that I have to test fit everywhere because I can't remember where they go, haha.
I even went so far as to make separate folders for upper intake, lower intake, block, interior, etc for all the connector pictures.
So far I'm ~$400 into parts, with the new clutch, new motor mounts and transmission mount, and today I ordered and intake manifold gasket set. All are just preventative maintenance aside from the clutch.
Just for a break down:
Clutch: $250
Mounts: $35 each
Trans mount: $25
Gaskets: $23
I will still buy all replacement u-joints for sure, and anything else I see wrong when I pull the engine. I noticed one of the freeze plugs is plugged with a strange looking thing with RTV around it, which worries me a bit. I'll investigate further next time I go out to work on it. Progress during the week will be slow. It's a 20 minute drive to where the truck is and I get off work 30 minutes before it gets dark, so it will mostly be weekend work, unfortunately.
post #17 of 652 Old 02-28-2012, 05:52 PM
charlie1935
charlie1935's Avatar
Quoted: 6 Post(s)
Search for captian cameltoe. He put a V10 in a 1500 a year or two ago.
Grouchy Old Man
Sport short bed
R&S Automotive cat back duals
SSBC slotted rotors
Tri wing tonneau cover
Ultra 50/51 16x10 wheels
265 70x16 Firestone Destination LE tires
3.55 rear
99-01 sport headlights with Silverstar bulbs
MSD coil
Fram Boost intake -Freebie. I won it
Edelbrock shocks
Yes, grandpas like toys too
87 D100 318 auto. stock
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist'
charlie1935 is offline
post #18 of 652 Old 02-28-2012, 05:54 PM Thread Starter
prototype4342
Quoted: 25 Post(s)
Yeah, 2wd haha
post #19 of 652 Old 02-28-2012, 07:07 PM
spun360
spun360's Avatar
Quoted: 162 Post(s)
Originally Posted by prototype4342 View Post
Yeah, 2wd haha
although he installed a mild performance cam in his, and he wasnt so worried about budget. he did a really nice job!
parts for sale
cheep
shoot PMs my way
spun360 is offline
post #20 of 652 Old 02-28-2012, 07:36 PM Thread Starter
prototype4342
Quoted: 25 Post(s)
Yeah mine is somewhat out of necessity and a budget build. He had a lot of time and seemingly lots of money to do his. Not to mention it seems that the V10 aftermarket has died a lot.
Oh and I was joking about the 2wd thing. I know it has been done before several times.
    Bagged Dually Project Thread zackdrews 3G Dodge RAM - Sport Truck Talk 35 07-20-2012 11:03 PM
    Smoothing my rear bumper (ALMOST COMPLETED) LaidNeon 4G Dodge RAM - Interior/Exterior Talk 37 03-21-2012 12:04 PM
    2009 Dodge Ram 1500 Official Thread Helevitia 3G Dodge RAM - General Talk 5 12-19-2007 09:31 AM
    Mega Cab 1500 2wd lowering thread. slammed1 3G Dodge RAM - Sport Truck Talk 4 03-06-2007 05:11 PM
