Just flushed radiator, having Trouble bleeding air out of radiator - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 19 Old 02-25-2012, 03:11 PM Thread Starter
Rambronco
Just installed a 180 thermostat, flushed cooling system, have only got 8 litres of coolant/water in so far. Read the book and old posts , I've ran it, let top hose get hot, shut it off, squeezed upper hose, let it cool and redo it. Why is such a simple job being a pain in the ass, any thing else I should do. I put the thermostat in with the nipple thing at 12:00.
2003 Ram 2500, Hemi, 35's
Power Wagon Conversion Project
Rambronco is offline
post #2 of 19 Old 02-25-2012, 03:17 PM
Voodoo
Motörhead For Life!
Voodoo's Avatar
Quoted: 56 Post(s)
Do what you just did with the ft higher than the back, (Pointed up hill ) that should help.
2012 Ram 1500 TRADESMAN REGULAR CAB 4X2 8' BOX ( TOTALED )
2014 Black Express
Edition 1500 Ram.
"You Can't fix Stupid"
Voodoo is offline
post #3 of 19 Old 02-25-2012, 05:39 PM Thread Starter
Rambronco
Just tried that, still nothing. Went for a drive and parked on a steep hill for awhile. Lower hose is cold as is hose for overflow tank. This is driving me nuts, waste of time, can't believe how long this is taking, should I keep trying or maybe pull thermostat out and redo, could there be air behind it?
post #4 of 19 Old 02-25-2012, 07:08 PM
hawk02
Quoted: 1 Post(s)
Make sure you are running the heater on high/hot while letting it get to temp, that way it is circulating throughout the entire cooling system to flush out the air. Good luck.
hawk02 is offline
post #5 of 19 Old 02-26-2012, 05:16 AM
LPGHemi
LPG Hemi
LPGHemi's Avatar
Quoted: 11 Post(s)
Just done this on my 03.......and I totally agree with hawk02.
Al.
03 Dodge Ram 1500 Hemi SLT
5.7 ltr QC sb 4x4
Performance Mods
K&N air & oil filters.
NGK Iridiums. Detroit TruTrac. TMR delete.
Procomp ES9000 with torsion bar tweak.
EBC slotted rotors with Yellow stuff pads and Cooper Zeon LTZ275/60/R20.
3" T304 stainless steel custom exhaust with high flow cat side exit near rear tire with DMH Electric cutout and T304 custom muffler.
Prinz LPG VSI sequential gaseous injection system
with 2x70 litre siamesed fuel tanks.
Exterior Mods
Siege Engineering Kong Mk2 Train horns 200 psi Viair 480C compressor & 3 gallon tank.
6000K HID Twiggy hi/lo + fogs.
White front and red rear LED license plate bolt Skulls.
Rear view colour camera with infra red, hooked up to an LCD rear view mirror doubling up as a 7" monitor
Tints 20's & Westins.
Raider Low Rider solid tonneau.
Xenon wheel arches.
Billet Aluminium Rapid hitch.
EZ lift tailgate torsion bar.
Bug deflector.
Dodge valve caps.
Interior Mods
Black coin holder ha ha ha.
DVD head unit.
2xRockford Fosgate Punch 12" subs.
2 Kenwood 6x9's & 2 5.25's.
2x9inch DVD screens built into custom headrests.
Full custom black leather interior with red piping & custom stitched red Ram logo into front seat backs .
Toad Thatcham cat 1 alarm
LPGHemi is offline
post #6 of 19 Old 02-26-2012, 08:01 AM
dakotavert4x4
4.7 turd owner
What about leaving the cap off when you first start it up and squeeze the upper and lower radiator hoses? Did this on a 70 Charger and seems to got it out I think.
Ram 1500 4x4 SLT reg cab/long bed 3.55 gears two tone
Powered by a 4.7L turd motor
dakotavert4x4 is offline
post #7 of 19 Old 02-26-2012, 11:10 AM
99Slobra
Biggin
99Slobra's Avatar
When I put my 180 in I had to keep my electric fan off and idle the truck at near 2000 rpm to get it hot enough to open the thermostat to start cycling.
2004 2500 Hemi R/C 4x4 on 35's
K&N CAI
Bilstein 5100's
Black Magic 183
SC 3865
Not loud enough
99Slobra is offline
post #8 of 19 Old 02-26-2012, 08:57 PM
MADBRAD
MADBRAD
MADBRAD's Avatar
I always park with the front up hill and I leave the cap off when I start the truck and let it circulate. I then turn the heater to hot to make sure the heater core fills. You can actually see the air bubbles working their way and bubbling up and out the fill tube if you watch it. Never have had any issues.
MADBRAD
2006 Ram 1500 SLT 4x4 Regular cab short bed/ MDS HEMI
steel 17s painted black /265 70 17 BFG Rugged Terrain tires/3.55 LSD
tow hooks /front suspension skid plate
3" cat back Flowmaster original 40
dechromed/debadged
black grille/black bumpers
Truxedo Truxsport
Belltech drop shackles
personalized "MADBRAD" license plates
MADBRAD is offline
post #9 of 19 Old 02-29-2012, 09:40 PM Thread Starter
Rambronco
I've been driving it around the last few days. The temperature will go up to just below half, then seems to settle down to where it should be, once and awhile it will move up a hair. It hasn't gone above half. Also, just checked when I got home, rad cap was cold as was lower hose, something doesn't seem right. Coolant level is steady.
post #10 of 19 Old 02-29-2012, 09:51 PM
njmike
njmike's Avatar
It should have removed all air pockets by now....
There is only one way to get rid of air lock... run the temperature to overheat than let it sit over night, Top off in the morning and good to go.
OR before you put the thermostat in, push open the thermostat and shove in an aspirin to hold the thermostat open. You will get flow until it dissolves and your good to go. Do it with every t-stat replacement.
njmike is offline
post #11 of 19 Old 03-01-2012, 12:22 PM
crasher76
Im wired!!!
crasher76's Avatar
I dont see what the hell you guys are talking about. Coolant flows through the heater core regardless of fan or temp setting in the cab.....thats pretty funny though!!!
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, 260 cam, 6.1 Rods/Springs, Home Ported/Polished Heads, Psc1, 04 Map sensor and Fuel pump assembly, Oil pressure guage, Amsoil, Champs, MSD 8.5MM Full length Wires, Transgo HD w/out resistor, Superchip, 180 T-Stat, K/N 77 Series, Ceramic Flowtech headers with Y-Pipe, Stage 8 locks, Ditched the cat, O2 sensor mod, Jack Rabbit bed cover, Sprayed bed liner, Big Mouth Grill-Black, Blackend Headlights/Tails, Silverstar ultras, Ditched all chrome, Custom 10's sub enclosure, Upgraded 160 amp alt, Window tint, Relocated purge valve, Energy suspension bushings, Rear spring clamps, Rebuilt front suspension, Ditched Sway Bar, Passport 8500 Radar Detector, Ditched the baby seat- kid wasnt mine, Cigarette burn in the seat mod, Debadged, Custom Rewired/Properly Grounded.
crasher76 is offline
post #12 of 19 Old 03-01-2012, 12:49 PM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 235 Post(s)
I run the fan and heater because it seems to be a high point in the system. If you're not getting any heat, your level is low. But with the cap off, heat in the cabin, and you can feel the t-stat opening and closing in the bottle, you should be OK. If you're having problems, I'd check the level every time I could. I'm not sure about your model year but I can open and remove my cap anytime without the fear of the system flash-boiling the fluid. By releasing the pressure while it running, you have better chance of removing any and all of air from the system. But PLEASE be careful when you try this for the first time. I had a radiator flash-boil on my and it put me in the burn unit for more than week. I did every right. The cap was cool to the touch; I turned the cap to the first stop to relief any pressure in the system; and then slowly removed the cap. The problem was the cap was defective and the lower section with the seal was jammed into the neck of the side tank. So the pressure was not released until the cap was completely removed. At that point, it flash-boiled and blew the boiling anti-freeze across my chest-neck-a-face. If you doubt me, I scan the picture and show you a very fugly picture of me while I has in the burn unit. It ain't a pretty sign!
... BE-CAREFUL
dmcelhannon is offline
post #13 of 19 Old 03-01-2012, 01:55 PM
njmike
njmike's Avatar
I would have to disagree with that statement.
Here is why:
Under the right conditions (ambient temperature, amount of air, in the system, size of the heater core) I can see how this may work in a very few situations. The reason you get air lock is because the coolant in the block is hot and the air trapped at the thermostat is cold so it causes the thermostat to not open and not allow fluid to flow. By running the heat you are cooling the fluid in the block thus allowing the thermostat to open as the air is heated on the other side equally. If the coolant in the block gets too hot than you will not get the thermostat to open at all until it cools down again because you will have 2 extremes, cool air on one side and hot fluid on the other.
In all actuality, the heater core is like the radiator but opposite purpose. The heater core is heated by the fluid and the heat is carried by the fan. The more air dissipated by the heater fan (the higher the fan speed) the more cooling property the heater core has. The radiator is heated by the fluid and then is cooled by air flowing through it. Same principal but totally different reason.
After all my experience with cars/trucks... I stick to my previous statement... been doing it that way for years... the best cure for air lock once you have it is to run the vehicle till the temperature gauge spikes (overheating) than let it sit for hours to cool down allowing the temperature to equalize through out the system. Once cooled down add fluid and your done.
But cranking up the heat with the radiator off seems to be the common response on google.
I will stick to the aspirin in the t-stat when you install it so I don't run into it at all.
And for anyone that is daring enough to take off a radiator cap after the vehicle has ran for even a minute... please do so with a few rags between your hands and the cap. At least that way you can control what happens. Your hands may get hot... very hot but at least you can shove the cap back on.
njmike is offline
post #14 of 19 Old 03-01-2012, 02:28 PM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
I like the asprin trick....
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #15 of 19 Old 03-01-2012, 03:30 PM
Voodoo
Motörhead For Life!
Voodoo's Avatar
Quoted: 56 Post(s)
would a Caffeine pill make the truck run faster or just stay awake longer??
This is the 1st time i seen the aspirin trick
2014 Black Express
Edition 1500 Ram.
Voodoo is offline
post #16 of 19 Old 03-01-2012, 03:58 PM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
A little viagra, maybe!
dizzyD is offline
post #17 of 19 Old 03-01-2012, 04:03 PM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
I had that happen on numerous ocasions, always used a rag or 2 to cover and open, never burned, but for somereason the caps' gasket likes to stick to the radiator neck, then woosh, it releases, when you dont expect it
dizzyD is offline
post #18 of 19 Old 03-01-2012, 05:12 PM
hawk02
Quoted: 1 Post(s)
That would keep it "UP" all night for sure! LOL
hawk02 is offline
post #19 of 19 Old 03-02-2012, 07:48 PM
sony224422
sony224422's Avatar
Quoted: 8 Post(s)
asprin doesn't contaminate the coolant at all? ( I know, i know, little pill, lots of water) just curious
2004 QCSB 2500 hemi with 4.10s Laramie
Back rack with whelen freedom 2 light bar (custom made by me with extras)
Whelen Par 36 aircraft landing lights behind the grill, Whelen par 36 spot lights for reverse lights, Whelen strip lights in the bed (6 in total), Whelen cencom to control everything
In bed tool box with lights and extra battery with isolator and also a solenoid to connect both batteries together if i need to
Color matched grill,
Fox box with 2 diamond d3 12's with Diamond d3 600.1 amp
SRT-10 a pillar with trans temp gauge
Mag-tec trans pan
Superchips 3865 with trans tuning
Nitto trail grapplers
POWER WAGON WINCH SET UP
Alpine ina-w900bt with reverse camera
Alpine type r 2 ways in the doors powered by alpine pdx-f4
steering box brace
sound deading
Big 3 done with 4 gauge
E-fan
POR-15 the frame and under body
Jimmy jammers
sony224422 is offline
    Having Trouble Bleeding the Air From the Cooling System stuartk57 Dodge Caravan General Talk 4 01-23-2012 08:12 AM
    Flushed heater core and radiator now no heat and overflow bubbling 918-hatch 1G Dodge Durango General Talk 3 10-08-2010 07:07 AM
    New radiator-old truck=trouble??? ProjectPowerRam Dodge Ram Truck 1st Gen (88 - 93) Forum 9 08-14-2009 07:21 AM
    radiator jpracer02 1948-1956 B & C Series Dodge Trucks 1 02-24-2009 11:52 AM
    Radiator / Water Pump Trouble?? BrassBitBandit 2G Dodge Ram Diesel Talk 3 10-02-2007 04:52 PM
