1500 front wheel bearing? help and opinions - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 02-17-2012, 04:30 PM Thread Starter
mttaff
mttaff's Avatar
I have a 2010 ram 1500 quadcab. it is 4wd and has the 4.7 and the truck has 92000 miles on it. I have started noticing what i would think is a front wheel bearing. changes with speed change and sounds a little worse when turning right. it sounds like it is in the drivers side and also i think i can feel it in the floorboard. sound right to you guys and if so, anybody ever fix this themselves. if not what did a mechanic charge? i usually do a lot of maintenance on my trucks and have done a couple truck builds but ive never worked or even owned a truck that isnt solid front axle so i'm in new territory.
mttaff is offline
post #2 of 18 Old 02-17-2012, 04:33 PM Thread Starter
mttaff
mttaff's Avatar
Also, truck is completely stock right now but i have bilsteins on the way and will hopefully be adding a lift and bigger tires soon, anything else i should look at while it's apart.
mttaff is offline
post #3 of 18 Old 02-17-2012, 09:48 PM
trooperjoe73
Run, see what happens!
trooperjoe73's Avatar
Bump.
93,000? I have a 2010 myself and have 13,000.
Interested int he opinions here. I'm no mechanic, but enjoy getting information.
2012 RAM 1500 Lone Star Crew Cab 4X4:
Mods:
1. Window Tint / Windshield AS1 Line
2. Top Gun Customz 2.5" Leveling Kit
3. Code Alarm CA3051/Glass Break
4. Daystar .75" Rear Spacer
5. Truck Champ 4" Black Oval Steps
6. 275/65/20 Nitto Terra Grapplers
7. 20X9 - XD Crank (Machined) Rims
8. Laramie Flares
9. Grill-Back to Chrome w/ black honey-comb (previous color matched)
NEXT: Not sure. Maybe Line-X.
trooperjoe73 is offline
post #4 of 18 Old 02-17-2012, 09:57 PM Thread Starter
mttaff
mttaff's Avatar
Got some miles but runs like a top, it was a company truck that has tons of road miles and never did anything but interstate.
mttaff is offline
post #5 of 18 Old 02-18-2012, 10:46 AM
BlakDak71
Wheel bearings are gravy. Pop the wheel off, unbolt the break caliper and hang it out of the way, remove the break rotor, remove the axle nut and beat the axle shaft loose, and there are either 3 or 4 bolts on the back of the wheel bearing to take out, and then beat it with a hammer to get it off.
2011 Dodge Ram Express RCSB 2WD
14.3@94 - SOLD
1998 Dodge Dakota RCSB 2WD Sport
318/NV3500/3.92
13.3@103
Hemi swap in progress
BlakDak71 is offline
post #6 of 18 Old 02-18-2012, 01:24 PM
Doug D
Quoted: 8 Post(s)
The front wheel hubs on my '06 1500 QC 4x2 had to be replaced after 140K miles due to the bearings wearing out. Parts and labor was about $360 per side at the dealer - About $260 for the hub and $100 labor.
Firestone wanted $450, but it was lifetime warranty on the part. I went with MoPar.
2006 Dodge Ram SLT Quad Cab 1500 4x2 w/Hemi (MDS)
2010 Dodge Journey SXT 3.5L V6
Doug D is offline
post #7 of 18 Old 02-18-2012, 02:00 PM Thread Starter
mttaff
mttaff's Avatar
Thanks guys, sounds like I'll be doing this one on my own!
mttaff is offline
post #8 of 18 Old 02-19-2012, 04:26 PM
duso02
duso02's Avatar
Quoted: 14 Post(s)
what BlakDak said. These new wheel bearing/hub units are easy to change. More expensive then old school spindle bearings but they do last longer, 100K miles or so.
Jack up the tire, grab the top and bottom of the tire and check for play. there should be no in-and-out play. Remove the brake pads and rotate it. It'll feel gritty.
Mine went while on a long trip. What a mess.
LOU
2011 Blue Ram Sport QC HEMI 4x4
Military Truck Club Member #16
"The Marines I have seen around the world have the cleanest bodies,
the filthiest minds, the highest morale, and the lowest morals of any
group of animals I have ever seen. Thank God for the United States
Marine Corps!"-- Eleanor Roosevelt
duso02 is offline
post #9 of 18 Old 02-19-2012, 05:02 PM
BlakDak71
I have seen them where they don't have any play but still are noisy. Easiest way to figure that out (at least on FWD's) is to hold the coil spring and have somebody spin the tire. You should be able to feel the roughness transfer through the coil spring.
14.3@94 - SOLD
318/NV3500/3.92
13.3@103
post #10 of 18 Old 02-19-2012, 07:28 PM
duso02
duso02's Avatar
Quoted: 14 Post(s)
Yeah, that's why I pull the brake pads before I spin it, without the tire. Then you can really feel it.
LOU
duso02 is offline
post #11 of 18 Old 02-19-2012, 07:32 PM Thread Starter
mttaff
mttaff's Avatar
Exactly what I wanted to find out
mttaff is offline
post #12 of 18 Old 02-22-2012, 07:03 PM Thread Starter
mttaff
mttaff's Avatar
jacked the truck up and didnt feel any play on either side, also looked at brakes and the pads/rotors seemed fine. didnt have any help so im going to check by spinning the wheel tomorrow, but i was surprised when i didnt feel any slop. dont want to buy the wrong part at the price of a wheel bearing for this rig! lol
mttaff is offline
post #13 of 18 Old 02-22-2012, 08:16 PM
duso02
duso02's Avatar
Quoted: 14 Post(s)
Noise should be the same regardless of speed. If it's louder when turning right, that should be the driver's side.
LOU
duso02 is offline
post #14 of 18 Old 02-22-2012, 08:30 PM
Shanes66
SLOWER TRAFFIC KEEP RIGHT
Shanes66's Avatar
I don't know about the 09' and up but there is a youtube video of 02'-08' repair... watched it a few times before I replaced mine in the driveway....
2013 Dodge Challenger R/T
Super Track Pak - 3.92 - 6 spd
Shanes66 is offline
post #15 of 18 Old 03-02-2012, 10:59 AM Thread Starter
mttaff
mttaff's Avatar
Been a while but i finally got around to getting the wheel bearing. funny thing is, when i posted this i said it was worse when i turned right...i meant my other right! when i turn left you can hear it and kindof "feel it" in the floorboard or pedal. its not as bad when i turn right. so i was expecting the passenger hub to sound bad. went ahead and ordered passenger hub bearing assembly and this morning i lifted the truck on stands, removed both front wheels, calipers and rotors and to my surprise, the driver side sounds slightly worse and is a little harder to spin. looks like the bearings are the same for either side but i wanted a little input before i moved on. im just surprised that it would be the driver side if it isnt as bad turning toward the driver side.
mttaff is offline
post #16 of 18 Old 03-03-2012, 01:46 PM Thread Starter
mttaff
mttaff's Avatar
got the bilsteins on last night, once i finished that i decided to button it up and not worry about the bearing. maybe one will show itself to be the culprit pretty soon. took it out for a drive and dont hear or feel a thing now! dont know if putting the struts on dampens it enough that i cant feel or hear it or what but im at a loss whether to keep the bearing or take it back, it did cost $210.
mttaff is offline
post #17 of 18 Old 03-03-2012, 01:47 PM Thread Starter
mttaff
mttaff's Avatar
by the way, at install time the front finished 1/2 inch higher than the rear. after a trip to town and back they settled in at the back being 1/2 inch higher than the front...perfect for me. now to get alligned.
mttaff is offline
post #18 of 18 Old 03-03-2012, 01:51 PM
BlakDak71
I have had odd ball ones where they howled when you take weight off them. My dad's Lesabre comes to mind. That's not a repair you want to wait for it to show itself though, it can get ugly if that bearing comes apart. By your description, I'd put the driver's side on.
14.3@94 - SOLD
318/NV3500/3.92
13.3@103
    99 1500 Front wheel bearing/Hub assembly question cMarsh 2G Dodge RAM - General Talk 5 02-15-2012 06:59 AM
    front wheel hub bearing ringnalda506 3G Dodge RAM - Tire and Wheel Talk 5 06-30-2011 10:27 AM
    Front Wheel bearing/hub ???'s DAVE W 3G Dodge RAM - Drivetrain Talk 3 05-13-2011 10:10 PM
    wheel bearing/ front hub durango85 1G Dodge Durango - Tire/Wheel/Susp Talk 5 04-06-2010 11:08 PM
    wheel bearing sets for front landyacht318 Dodge B-Series Vans 1971 - 2003 7 04-13-2008 12:41 AM
