2003 Caravan-Sound from transmission as I slow down... - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 02-14-2012, 02:51 PM Thread Starter
kanny
A clunk sound comes from the transmission when my 2003 Grand Caravan slows down... could you please tell me what could be wrong?
kanny is offline
post #2 of 4 Old 02-15-2012, 06:34 PM
no_common_sense
Quoted: 11 Post(s)
What engine do you have and how many miles are on the van?
I do have an immediate suspicion if your van has over 150,000 miles (241,400 kilometers) on it and that would be the front motor mount and rear trans mount have failed. It's a very common failure for the 01-07 generation. Try rocking the motor back and forth with your hands. If it rocks really easy, both mounts are bad. If it doesn't rock, there's still a good chance at least one mount is shot and the other is not far behind. The rubber tends to separate from the aluminum as they age and the mounts may not initially look so bad if you don't pay attention to where the aluminum and the rubber bonds. Especially at the cores with the bolt holes.
no_common_sense is offline
post #3 of 4 Old 02-15-2012, 08:41 PM Thread Starter
kanny
Hi. Thanks for your help. It has only 107 000 km, and the engine is 3.3 litres 2003 model. The engine mounts would not rock, they are okay. When I put it on D (drive), it makes a clunking noise, and when i put it in 3, it does not make a noise... when I am cruising on 70+km and I slow down to 20km-30km, it makes a clunking noise. Thanks.
kanny is offline
post #4 of 4 Old 02-16-2012, 01:37 PM
no_common_sense
Quoted: 11 Post(s)
I'm out of good ideas for you but I'm guessing there could be electronic problems with a shift solenoid. This is a more obscure problem, but I've seen chrysler transmissions with check balls can slam the separator plates in the valve bodies to a point where the plate distorts the orifice it's supposed to be metering for shift feel. Start with the basics though and look at the color, level, and condition of your fluid and maybe have the pan and filter dropped for inspection.
    2003 Caravan transmission filter service ???? rocketman87 Dodge Caravan General Talk 15 10-30-2007 11:26 PM
    2005 GC 3.3L Moaning sound while turning during slow speed Dr. John Dodge Caravan General Talk 0 08-13-2007 03:18 PM
    2003 Caravan 3.3L Transmission Fluid Problem darylcesal Dodge Caravan General Talk 2 07-19-2005 09:36 PM
    2003 Caravan Transmission - Help perryjo Dodge Caravan General Talk 8 06-15-2005 06:14 PM
    2003 Dodge Caravan Transmission Problem bg1 Dodge Caravan General Talk 11 06-01-2005 12:17 AM
