How to- Replace power steering cooler - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 02-09-2012, 03:45 PM Thread Starter
firemanbill
2008 Dodge Ram 5.7L Hemi
Had to replace the power steering cooler due to a leak. It was located in front of the radiator on the passenger side. I have pics. But had to attach them, can't upload links yet.
I double checked that it looked correct. Mine was leaking at the bend on the passenger side. I placed the new one in front of the old. Check the pictures.
I only had to remove two bolts and two hose clamps. I could not get a wrench on them from the top side and had to go underneath. Ill post pics of before and after I removed the plastic dust shroud. It made all the difference. Here is the before, note all the shiny fluid on the plastic. Check the pictures
The two rusty looking areas in the picture from below are the mounting brackets. 10MM bolts with nuts. The replacement part came with new bolts that were 3/8". The hoses were just held on by clamps. I learned one thing, be careful of the cooler and radiator fins. They are sharp and very easy to bend with unintentional contact.
By the way, this is my first post after lurking around for over a year. I hope to get some feedback so I can start to post pics in a better way.
firemanbill is offline
Quote Quick Reply
post #2 of 2 Old 02-09-2012, 04:55 PM Thread Starter
firemanbill
Sorry the pics are out of order. Ill do better next time. When I wrote the how to I figured the pics would be in the middle of the post not all at the end. Live and learn. I also forgot write end.
END
    power steering cooler ? RAMbo26 3G Dodge RAM - General Talk 0 01-24-2012 06:21 PM
    power steering cooler foofs 3G Ram Power Wagon Talk 6 06-13-2011 10:47 PM
    Power steering cooler Beastro 3G Dodge RAM - Drivetrain Talk 2 01-30-2011 07:21 PM
    Power Steering Cooler replacement MrAbody 2G Dodge RAM - 4X4 Talk 0 07-14-2009 12:22 PM
    Power steering cooler marsh14 3G Dodge RAM - General Talk 10 09-06-2008 10:53 AM
    You may not post new threads
    You may not post replies
    HTML code is On
