Rattling/Buzzing in 2012 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 4th Gen (09 – Up) Forums > 4G Dodge RAM - General Talk
Whiteout08
  Rattling/Buzzing in 2012 - Posted: 01-18-2012, 07:03 AM
Whiteout08's Avatar
City: Rochester
State: NY
Post #1
I have recently noticed a VERY annoying rattle/buzz sound coming from what seems to be the dash on the passenger side of my truck, but only happens at speeds over 30mph. I had my wife hold her hand up there to "push" the dash down a little to see if it was loose plastic, but it didn't stop.
The only thing I can see, when I pop the hood, it seems as though the under-hood insulation or heat barrier isn't attached as well as you'd think it should be, and it's loose right where the noise seems to be coming from.
Anyone have a way to secure this to see if it helps? Anyone else had this same issue with their 2012 with a buzzing noise at higher speeds? Are there other areas to check aside from the insulation that could be causing this noise?
I'm going to try taking it back to the dealer to have them fix it since I've only got 700 miles on this truck so far, and my sanity is slowly decreasing (more than normal anyway).
Jeff
2012 Dodge Ram 1500 Express QC - Mineral Grey
Mods: Mufflex DOD14M, TGC Level Kit (2.5" front, 3/4" rear), 20x10 Ultra Baja Champs (custom "Black Chrome") w/ 305/55/20 NTG, DDM 5000k HID's in Fog Lights
thebluegoat
 Posted: 01-18-2012, 01:17 PM
thebluegoat's Avatar
Post #2
Check the A-pillar cover
2011 Ram 1500 CC Sport 4x4 Deep Water Blue Pearlcoat
Mopar Molded Mud Flaps | WeatherTech Floor Mats | 2013 Sport Rims | 14" Magnaflow DIDO | Magnaflow 5" Tips | Y-Pipe Deleted | Tailgate Light Bar & LED Tails | BT Catch Can & Under Hood Kit | Tint
Future Mods: Color Matched Tailgate Handle, Antenna Base, JBA Short Tubes, Roll-Bak Tonneau Cover
Whiteout08
 Posted: 01-18-2012, 01:27 PM
Whiteout08's Avatar
City: Rochester
State: NY
Post #3
Will do, thanks. I need to get my truck back to the dealer soon anyway to fix a paint issue, so if I can't find the cause I'll have them fix it.
Rlbeck1990
 Posted: 01-19-2012, 06:56 PM
State: PA
Post #4
Do you have a bench seat? If so do you have a pull down cupholder section in the middle? (sorry im note sure what rams come equipped with what stuff) If you have that cupholder section in the middle, after you open it and let it "hang", push down on it (towards the floor). It will lock into place. Mine rattles if it is not locked into place. Just my $0.02
Whiteout08
 Posted: 01-19-2012, 07:28 PM
Whiteout08's Avatar
City: Rochester
State: NY
Post #5
I feel like I've tried everything, but I'll give that a shot. From the driver's seat, it definitely sounds like it's coming from up near the windshield, or from the engine bay...that hood liner isn't exactly attached very tight.
JoBob30
 Posted: 01-20-2012, 01:00 PM
Post #6
check the sunvisor to make sure its latched
Ghostknife
 Posted: 01-20-2012, 01:04 PM
Ghostknife's Avatar
State: MI
Post #7
I have the same issue but i have a 10 and its only when im stopped, iding.
Whiteout08
 Posted: 01-20-2012, 04:16 PM
Whiteout08's Avatar
City: Rochester
State: NY
Post #8
Got it fixed this morning...it was the hood liner. They don't attach it very well so on each corner it kind of flaps around...at higher speeds it slaps against the hood and creates a "buzzing" sound.
2012 Power Wagon or 2012 Mega Cab 04Ram2500Hemi 4G Dodge RAM - 4X4 Talk 67 02-15-2011 07:52 PM
Hella 500 buzzing guru77 3G Dodge RAM - General Talk 5 02-23-2008 07:40 AM
Buzzing fuse box on 96 EDCaravan96 Dodge Caravan/Grand Caravan Talk 4 07-28-2005 01:12 AM
buzzing sound jo doh 3G Dodge RAM - General Talk 8 08-02-2004 08:09 PM
