Lock outs/ Posi - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 21 Old 01-09-2012, 10:18 PM Thread Starter
BamaORourke18
BamaORourke18's Avatar
Lock outs/ Posi
me and my buddy have been tossing this idea around for a while.. 1st can i turn my front axle from a regular 1500 axle into a lockout axle? and 2nd Can i change my rear end into posi trac?
BamaORourke18 is offline
post #2 of 21 Old 01-10-2012, 07:23 AM
Moparite
Moparite's Avatar
Quoted: 318 Post(s)
Why do you want to do that?
Yes.
Moparite is offline
post #3 of 21 Old 01-12-2012, 10:10 PM Thread Starter
BamaORourke18
how would i go about changing it into a posi?
and for the front me and a friend we're talkin about wheeling one day and how only 2 wheels usually spin.. and i would like to have a TRUE 4 wheel drive, where all 4 tires spin..
Bama
97 Dodge Ram 1500, Ext cab, Short bed
360 Mag, 4x4, 2in Leveling, 35in Maxxis Bighorns
RAM THE DAUGHTER, DODGE THE FATHER
post #4 of 21 Old 01-13-2012, 07:29 AM
Moparite
Moparite's Avatar
Quoted: 318 Post(s)
You have to change the carrier to a limited slip or locker. You have lots of options here. If your truck is a gen2 your front axle will be disengaged by the transfer case(no drive). No need for locking hubs. To have "TRUE 4 wheel drive" you need both axles(front and rear) to be LS or locker.
http://www.eaton.com/Eaton/ProductsS...ials/index.htm
Moparite is offline
post #5 of 21 Old 01-13-2012, 12:19 PM Thread Starter
BamaORourke18
-so they will already be able to fit into my 1500 axles?
-where would i buy the locker?
-would i only need the locker, or do i have to buy a kit of some sort?
Bama
post #6 of 21 Old 01-14-2012, 08:03 AM
Moparite
Moparite's Avatar
Quoted: 318 Post(s)
Like i said before you have a lot of options. What are you going to be doing with your truck that you want/need "true 4WD"? Limited slip diffs are good for every day use. Lockers are just that. They "lock" the axle. Like having a solid axle. Not good on the street. You can get an air locker. Lock the axle with a flip of a switch. lot of options. Do a Google search.
Moparite is offline
post #7 of 21 Old 01-17-2012, 10:46 PM
spun360
spun360's Avatar
Quoted: 155 Post(s)
most people dont start by locking the frt to start with. go for the 9 1/4 upgrade first. two options here
lockrite: its a syncro gear and it is a solid lock up. kinda like a ratchet wrench in the rear diff. research it. just a little cheaper, little less reliable, can be swapped right into the open diff rear. not much work involved
truetrac: near $600 for the kit, pull the entire contents of the 9 1/4, real reliable, tech and labor intensive
what do you need posi for, just a two wheel peel?
parts for sale
ask about my treadwright retread experience
$150: 210lb double and dampener valve springs .550 lift
$pay shipping: new, dana/ spicer (1)greasable upper & (1)lower ball joint for dana 44
$pay shipping: new, standard oil pump
$pay shipping: new, super strength moog #377 frt axle hub universal w/ grease fitting
prices (for residence of the US)
cheep
shoot PMs my way
spun360 is offline
post #8 of 21 Old 01-17-2012, 11:04 PM Thread Starter
BamaORourke18
no. i dont wanna burn my meaty tires off.. i want posi to have more pullin power and to be a step closer to a TRUE 4x4
Bama
post #9 of 21 Old 01-19-2012, 08:26 PM
spun360
spun360's Avatar
Quoted: 155 Post(s)
take a look at the youtube searches for the lockrite and the truetrac. you'll enjoy that.
parts for sale
cheep
shoot PMs my way
spun360 is offline
post #10 of 21 Old 01-19-2012, 08:42 PM Thread Starter
BamaORourke18
is there a certain one or just any?
Bama
post #11 of 21 Old 01-20-2012, 10:35 AM
jdserna
Diego Serna
jdserna's Avatar
Quoted: 20 Post(s)
If you are going to the expense of installing the LSD or full case locker, then regear your axles at the same time. No need to pay for labor twice. Deeper gears will give you the pulling power you are looking for.
jdserna is offline
post #12 of 21 Old 01-20-2012, 12:17 PM Thread Starter
BamaORourke18
i think im just gonna try to find some 2500 axles. with lower gearing for pulling. and i found this..
http://completeoffroad.com/i-1401004...sl-d44-30.html
and i might throw this is the 2500 rear axle.
what do you all think about the spartan?
Bama
post #13 of 21 Old 01-20-2012, 03:03 PM
jdserna
Diego Serna
jdserna's Avatar
Quoted: 20 Post(s)
Lunch box lockers are all ok. It all depends on what size tire you are going to use. Most of them are rated for 33 or smaller. Another thing to consider is how you drive you truck. If you use the skinny pedel alot, you are going to break something. Usually the stock carrier or the gear. Also if your truck is manny, never left off the clutch to quickly. Bad things happen when you do that. What gearing does you truck have now?
jdserna is offline
post #14 of 21 Old 01-20-2012, 09:31 PM
spun360
spun360's Avatar
Quoted: 155 Post(s)
i would suggest again against locking the frt diff. the driver side axle has a bottle neck down in gauge, in other words the frt axles have week spots in them. just lock the rears and try that for a while.
parts for sale
cheep
shoot PMs my way
spun360 is offline
post #15 of 21 Old 01-20-2012, 09:36 PM Thread Starter
BamaORourke18
ok ill just lock the rears. and my truck has just stock gear. i have no clue what they are.. but im planning on upgrading to a set pof 2500 axles cause i plan on running 38's. i do plan on wheelin a bit.. but not to much. and it is a bama is auto.
what would be the best kinda locker to get for that?
Bama
post #16 of 21 Old 01-20-2012, 10:19 PM
spun360
spun360's Avatar
Quoted: 155 Post(s)
man! whats your budget?
parts for sale
cheep
shoot PMs my way
spun360 is offline
post #17 of 21 Old 01-21-2012, 10:13 AM Thread Starter
BamaORourke18
im gettin some money from my parents that they've owed me. and its all goin into bama
Bama
post #18 of 21 Old 01-21-2012, 10:23 AM
spun360
spun360's Avatar
Quoted: 155 Post(s)
i dont know if the 2500 axles will just bolt right up- the issues are the leave widths are wider and if the universals are the same size for the drive shaft? idk? it really could become expensive! maybe you could grind off the sides of the leaf perch and make the u-bolts fit, but the uni-s are possible an issue. and your going to need new rims. most people max out thier 1500s at 5" and 35" tires. just looking out for your bottom line. if its a big build up you got, i'd run the trutrac from detroit. the lockrites are common on jeeps and lesser hp vehicles.
parts for sale
cheep
shoot PMs my way
spun360 is offline
post #19 of 21 Old 01-21-2012, 12:26 PM Thread Starter
BamaORourke18
trutrac from detroit for the front and rear or just rear? and yes i plan on a big build with 3in body 5in sus 2in spacer. and i wanna run 38s.. i wont wheel alot.. but i want to wheel some.. so thats why i was thinkin of 2500 axles so i wont break my 1500 axles.
Bama
post #20 of 21 Old 01-21-2012, 12:40 PM
spun360
spun360's Avatar
Quoted: 155 Post(s)
http://www.ebay.com/itm/Eaton-Detroi...sories&vxp=mtr
parts for sale
cheep
shoot PMs my way
spun360 is offline
    9.25 Dodge ram posi-lock - $100 (blackshear GA) weedahoe E-Bay and CraigsList Finds 0 11-11-2009 12:46 PM
    Best deal on a posi-lock bigkountry 2G Dodge RAM - Drivetrain Talk 5 04-29-2009 12:44 PM
    9 1/4 mopar trac-lock posi daynz For Sale - Truck Parts 10 11-23-2008 08:23 AM
    lock outs skidoo99 Dodge Ram Truck 1st Gen (88 - 93) Forum 1 12-01-2004 10:59 PM
