Resetting TPMS? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 01-09-2012, 11:47 AM Thread Starter
Mudder
High Tech Redneck
Mudder's Avatar
Resetting TPMS?
I wondered if there was a way to reset the tpms? Mine started flashing at me last week when we had a colder night and the pressure got down under 30 on my drivers side rear tire. I checked it, filled it back up to 35psi and its held that but the flippin warning light wont quit blinking "low" and showing me the pressure screen.
2012 Jeep Wrangler Unlimited
Mudder is offline
post #2 of 6 Old 01-09-2012, 12:32 PM
Z mann R2
Texas Pride...HEMI Pride
Z mann R2's Avatar
Quoted: 3 Post(s)
Hmm mine goes away once I start driving
-Tim
'09 Ram 1500 HEMI 4X4 Quad Cab + 2.5" lift + Flowmaster 50 + HID's
missed: '06 CTD 4x4 Quad Cab, '95 Chevy S-10 ZR2 4x4
4th Gen Truck Club Member #1
Z mann R2 is offline
post #3 of 6 Old 01-09-2012, 12:35 PM Thread Starter
Mudder
High Tech Redneck
Mudder's Avatar
Doesn't even make sense. The tires not leaking and I assumed the warning was triggered when it hit under 30, but it hasnt dipped lower than 30 in 3 days. Still, everytime it tells me its low. I'm tempted to pull the battery cable and reset everything and see if that works.
Mudder is offline
post #4 of 6 Old 01-09-2012, 01:40 PM
richardson155
I have also experienced the same thing but what I did was inflate the tire to around 40 psi and checked the system. Then I deflated the tire to the correct pressure. The warning light went away.
O3' THUNDERROAD QC 1500 HEMI
AIR AID MIT
GROUND FORCE DROP SHACKLES
LIQUIDMETAL MAGMA WHEELS
285/50/20'S
MAGNAFLOW MUFFLER
JET STREAM SCOOP
11' SPORT CC 1500 HEMI
K&N AIR FILTER
MAGNAFLOW 22"
richardson155 is offline
post #5 of 6 Old 01-09-2012, 04:44 PM Thread Starter
Mudder
High Tech Redneck
Mudder's Avatar
Well, I tried that and it seems to have worked. Don't wanna jinx it though. These are not the stock tires mind you, but I puffed them up to 39.5 all around. Took it for a spin to reset them and as of now I have no warning light. I was getting upwards of 3psi fluctuation at any given time, so I may just leave them here to insure I don't get anymore warning lights.
Mudder is offline
post #6 of 6 Old 01-12-2012, 05:15 PM
Rob-ram-2011
Rob-ram-2011's Avatar
Your tires should be filled with nitrogen, I get free top ups at my dealer. Your better off not adding air to your tires. if you run normal air in your tires they can fluctuate 5psi and straight nitrogen only 1psi. nitrogen reduces the loss of tire pressure due to permeation through rubber over time by about 1/3.
2011 Ram 5.7 Sport cc
Rob-ram-2011 is offline
    Resetting the PCM fig0986 1G Dodge Durango Performance Talk 8 03-20-2008 11:57 PM
    Help Resetting my PCM Glenn Williams 3G Dodge RAM - General Talk 7 08-11-2007 09:05 AM
    Help resetting the PCM yellowbee 3G Dodge Ram Performance Talk 19 09-25-2006 09:04 AM
    Resetting the PCM TSR6 3G Dodge RAM - General Talk 4 06-26-2006 08:27 AM
    resetting the PCM klphelps 3G Dodge Ram Performance Talk 6 04-26-2006 06:50 PM
