4 Wheel drive noise - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 11-04-2004, 01:00 PM Thread Starter
1BadRam
Unhappy 4 Wheel drive noise
I have a 1995 2500 Ram 4x4 that has a clunking and vibrating sound when in 4 wheel. All the noise is in the front and also feels like the front diff is "locked" - the front tires sort of jump when I turn. All u-joints in the front driveshaft and at hubs are brand new. This noise is only happening when in 4 wheel and under load (foot on gas) - smooth as silk in 2 wheel. Dana 60 front axle. Whats up here?!? Any help is much appreciated. Not to happy w/ Dodge right now - my '02 is having the tranny replaced after much arguing w/ dealership........
2002 Dodge Ram 1500 SLT 4X4
3" Flowmaster DeltaForce 40 dual exhaust
2" front leveling
Xenon Custom front bumber cover
Color-coded body mouldings
Throttle Body spacer
Fastman Over-bored throttle body
K&N Cold Air Kit
Under-Drive Pullies
Heads ported & polished
Hypertech Power-Programed
315/70 R17 BFG All Terrains
Tow package w/ 3.92 gears & limited-slip diff
Custom grill inserts
Color Coded Wiper cowl
X3 Carbon Fiber Tailights
Flashed PCM
DeBadged
Color Coded door handles, mirrors & tailgate handle soon to come...
1995 Dodge Ram 2500 SLT 4X4
All heavy duty options available
360 heavy duty
K&N filter
Amsoil lubes through-out
Electric brake control
Detroit Locker in rear
9' Diamond plow
2001 Dodge Intrepid R/T Motorsport Edition
No mods yet, but soon to come....
1BadRam is offline
post #2 of 7 Old 11-04-2004, 02:37 PM
baldpate
mountain grown
Hey when I first got my 94 1/2ton I couldn't bust out of a wet paper sack let alone get my truck up a gravel embankment. Had my buddy pull me up the friggin hill or I was f----- and he drives a bronco. Found out I had a burnt vacuum line going to the front diff.
Although when I cranked my wheels I would get the hop and skip like I WAS in 4WD.
baldpate is offline
post #3 of 7 Old 11-04-2004, 04:07 PM Thread Starter
1BadRam
Thanks, will check that tonite along with checking if 1 of the u-joints behind the hubs is froze - I would think that would make it cause the same problems I have....Also going to try to check some of the electric actuators for bad wires.....
2" front leveling
K&N Cold Air Kit
Under-Drive Pullies
Flashed PCM
DeBadged
360 heavy duty
K&N filter
9' Diamond plow
1BadRam is offline
post #4 of 7 Old 11-05-2004, 12:57 AM
BVRmonger
The jumping or hoping skipping is always there. Just the front wheels covering more ground than the back wheels and they are locked together when in 4 wheel drive and in a tight turn. As for the clunking vibrating sound...both of mine do make a little more noise in 4 wheel, I guess more vibration. Is the clunking continous? Intermittant?
BVRmonger is offline
post #5 of 7 Old 11-05-2004, 08:18 AM Thread Starter
1BadRam
its almost more of a slipping - like the splines aren't engaging all the way. This weekend I'm checking the splines behind the wheel bearings and under the vacuum actuator. After that I'm lost........
2" front leveling
K&N Cold Air Kit
Under-Drive Pullies
Flashed PCM
DeBadged
360 heavy duty
K&N filter
9' Diamond plow
1BadRam is offline
post #6 of 7 Old 11-21-2004, 10:58 AM
Meierznutz
Older, but no wiser.
Meierznutz's Avatar
This will sound stupid but I don't mean to offend... Are you doing this on pavement or a hard surface? 4wd is for loose surfaces. If the front wheels are getting too much traction (same as the rears) you will get this reaction. Otherwise you are going in the right direction by checking axle u-joints and the center axle disconnect. There is a kit out to eliminate the thermal/Vaccum disconnect. A vac leak will cause the collar to partially/ completely fail to engage. Good luck and keep us informed... Chris
'02 2500 Quad Short Box, HO Cummins, 6 speed,Fast Cooler and filter kits, Con-OFE clutch, 3:55 limited slip, Banks exhaust and Brake, K&N, Autometer Lunar series gauges, Air Dog 100gph, Adrenaline chip SOLD :-(
Current ride: 95 2500 2wd with a P-pump
90 Miata LS-1, 6 speed, 8.8 Cobra IRS
5-21-93 married, cost $15k
4-29-02 bought my Ram, cost $28k
3-15-99, 8-8-05 sons are born PRICELESS!
Meierznutz is offline
post #7 of 7 Old 11-21-2004, 03:55 PM Thread Starter
1BadRam
was testing it on a grassy surface. Anyway, curious about the kit to eliminate the vacuum dissconnect - wouldn't that just give u full time 4WD?. Replaced the gaskets and plastic bushings in the vacuum actuator, but it wasn't that. Took front drive-shaft out to see if maybe one of the u-joints replaced was also bad and noticed the spring loaded bearing in the velosity joint didn't look too hot so I replaced it and problem solved. Can't feel or hear anything in 4 wheel.
2" front leveling
K&N Cold Air Kit
Under-Drive Pullies
Flashed PCM
DeBadged
360 heavy duty
K&N filter
9' Diamond plow
1BadRam is offline
