How to: Hanger flip, Dodge Dakota - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Dakota 1st Gen (87 -96) Forum
Meezyy Jayy
  How to: Hanger flip, Dodge Dakota - Posted: 12-23-2011, 10:40 AM
Meezyy Jayy's Avatar
Long Bed FTW !
City: Dirty South
State: AL
Post #1
I know there must be tons of articles on this but idc its my time to shine lol this is how i did it.
Materials
Angle Grinder and/or Air chisel.
Super powerful drill
Crow Bar
Can of Oil
1/4 drill bit
1/2 drill bit
8 Grade 8 Bolts, Nuts, Washers, and Lock-washers
4 Strong people
Ramps
Impact gun (preferred)
5x5 inch rubber sheet (i used one off of and old rubber bed liner)
Instructions
1. Drive the rear wheels on the ramp
2. Take the bed off of the truck
Would be easier if you had an impact gun
loosen the gas tank neck
remove the spare
remove tail lights
get people to help lift the bed off the truck
3. Get angle grinder/ air chisel and hack off the rivets on both sides.
4. Get your super powerful drill and turn it to the picture of a drill bit, put your 1/4 bit in there and drill straight through the frame where the rivet was.
5. Do the same as step four but use a 1/2 drill bit
6. Once you drill our the last rivet, the hanger will bounce up in the air so watch out
7. Use the crow bar to turn the hanger upside down, the top left hole and the bottom right hole should line up
8. Get your grade 8 and put it in.
9. Drill the other two holes, 1/4 first then use 1/2
10. Put your grade 8s in there and your done with the hanger
11. Place the bed back on the truck, semi tighten the bolts
12. Lift it just a tad so the rubber sheets can fit in between the hanger and the bed
13. Tighten down the bolts and put all the parts you took off the bed back on and your done.
Hope this helps, i couldn't find a good hanger flip thread so i just made one, any questions and comments?
**USE THE OIL TO COOL DOWN THE HOLE YOUR DRILLING SO IT DONT GET TOO HOT!**
Before Pic
Hanger is Flipped
After Pic
Bone Stock - 12.066 @ 60.31
>>babybluedakota<<
dodgef25
 Posted: 12-23-2011, 02:46 PM
dodgef25's Avatar
Crazy4x4RT
City: NM
Status: Online
View This User's Timeslip
Post #2
Cool! I did one similar for a 4wd to lift it. I bought different mounts to lift it more. Here is mine.
http://www.dodgetalk.com/forums/show...173&highlight=
My Youtube Videos! ---My Dana 44 SAS
"No truck should ever be lowerd! NEVER"
Meezyy Jayy
 Posted: 12-24-2011, 03:36 PM
Long Bed FTW !
City: Dirty South
State: AL
Post #3
nice, my bud has an old 92 4x4 he was wanting to do a cheap lift on, i'll show him it.
>>babybluedakota<<
dodgef25
 Posted: 12-26-2011, 10:06 PM
dodgef25's Avatar
Crazy4x4RT
City: NM
Status: Online
Post #4
How much did it drop it?
Meezyy Jayy
 Posted: 12-27-2011, 10:42 AM
Long Bed FTW !
City: Dirty South
State: AL
Post #5
four inches in the rear, im not positive on this one but if you flip the front hanger, wont that lift the truck?
>>babybluedakota<<
dodgef25
 Posted: 12-27-2011, 01:10 PM
dodgef25's Avatar
Crazy4x4RT
City: NM
Status: Online
Post #6
Do you have a before and after shot of the truck?
Flipping the front may lower the truck a bit, I say it is not worth it since you will need to drill all new holes.
hogback
 Posted: 12-27-2011, 01:21 PM
hogback's Avatar
City: Angola IN
State: IN
View Member's FaceBook Profile
Post #7
yes get a after pic please
1989 Dodge Dakota 3.9L Auto 2wd
Hopefully going to fix the rust, put a 360 with single turbo, 5 speed, 9 inch rear end with posi, and some nice soft 8's and street strip tires.
Meezyy Jayy
 Posted: 12-27-2011, 05:07 PM
Long Bed FTW !
City: Dirty South
State: AL
Post #8
yeah check the OP
>>babybluedakota<<
hogback
 Posted: 12-27-2011, 07:02 PM
hogback's Avatar
City: Angola IN
State: IN
Post #9
thanks for the pics i like it i think im going to do the flip
Meezyy Jayy
 Posted: 12-27-2011, 09:08 PM
Long Bed FTW !
City: Dirty South
State: AL
Post #10
just make sure you lower the front, i still havent lowered my front and it looks goofy lol but good luck to you man, post pics when you do it.
>>babybluedakota<<
hogback
 Posted: 12-27-2011, 09:38 PM
hogback's Avatar
City: Angola IN
State: IN
Post #11
how should i lower the front? with lowering springs?
Meezyy Jayy
 Posted: 12-27-2011, 09:51 PM
Long Bed FTW !
City: Dirty South
State: AL
Post #12
that or drop spindles or lower control arms, the cheap way will be to cut the springs, or heat them up, but that will sacrifice the ride. i might get some s10 springs and throw them on my dak to get a drop, they are the same diameter and length but meant for a lighter load so it should give me about 2-3 inches.
>>babybluedakota<<
hogback
 Posted: 12-28-2011, 08:30 AM
hogback's Avatar
City: Angola IN
State: IN
Post #13
Im eventually going to put a 360 in it do you think that the extra weight of the v8 on the v6 springs will lower it enough to look good
Meezyy Jayy
 Posted: 12-28-2011, 09:55 AM
Long Bed FTW !
City: Dirty South
State: AL
Post #14
it may lower it about an inch, what i would do is go to a junk yard and pull some springs from a regular cab short bed thats a 4 cylinder. that should give you the drop you want.
>>babybluedakota<<
hogback
 Posted: 12-28-2011, 10:31 AM
hogback's Avatar
City: Angola IN
State: IN
Post #15
yeah but will it support the v8
Meezyy Jayy
 Posted: 12-28-2011, 09:21 PM
Long Bed FTW !
City: Dirty South
State: AL
Post #16
yeah it will but the ride will be a little bouncy
>>babybluedakota<<
hogback
 Posted: 12-29-2011, 07:48 AM
hogback's Avatar
City: Angola IN
State: IN
Post #17
ok
hanger installation dakotas ram 2G Dodge RAM - Sport Truck Talk 14 07-19-2009 11:11 PM
Borken exhaust hanger tamatama 3G Dodge RAM - General Talk 15 03-14-2009 12:29 AM
hanger for tailpipe Megunticook 1972-1987 Dodge Ram Trucks (D, W-series) 27 10-06-2008 09:56 AM
2G low cost rear lowering...spring hanger flip...crediting slammed1 backtobasics 2G Dodge RAM - Sport Truck Talk 3 11-28-2007 12:18 AM
Exhaust Hanger Howie 2G Dodge Ram Performance Talk 5 05-26-2004 07:18 AM
