My Truck Won't Get Warm - Engine or Interior - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 12-21-2011, 11:23 AM Thread Starter
JackedDak03
JackedDak03's Avatar
Quoted: 1 Post(s)
Ok, I hate to make another thread but I'm thinking its just a thermostat and wanted opinions.
What is happening:
Start truck, let idle for awhile, get in and drive. Regardless of outside temp, the needle for the engine temp doesn't move off of the lowest position. I originally thought it needed a temp sensor but when I hooked up my plow for our last storm, the needle started to come up to just above 130* and the vents started blowing warm air.
I didn't really notice the no warm air from the vents until we had some really cold weather and the inside of the truck just wasn't warming up. I've taken trips to Mass from my house and the temp of the truck never moved off of the bottom position.
This has me thinking Thermostat.
Next question- Never done one, and not afraid to try since it seems simple. My question is the coolant. Do I just fill with coolant and be done with it, or does it have to be 50% coolant, 50% water - distilled I'd assume. Thanks in advance.
BMW X5 & Chevy 2500 HD POS
Gone:
2002 Ford F350 Crew Cab Diesel
1999 Dodge Ram 2500 Quad Cab 4x4 Sport V10
1998.5 Dodge Ram 2500 Quad Cab 4x4 24V Cummins
2004 Dodge Ram 2500 Quad Cab 4x4 HEMI
2003 Dodge Dakota Quad Cab 4x4 4.7
2002 Dodge Ram 1500 Quad Cab 4x4 4.7
2001 Dodge Ram 1500 Quad Cab 4x4 5.9 V8
1999 Dodge Ram 2500 Quad Cab 4x4 5.9 V8
1997 Dodge Ram 1500 RegCab ShortBed Sport 5.9 V8
Past -92 Daytona R/T, 94 3000GT, 91 TransAm, 88 RX7 TII, 89 YJ, 92 Bronco, 88 YJ, 94 F150, 96 Rodeo, 88,89,90,91 5.0 Mustang's, 03 Mustang GT, 04 SRT4
JackedDak03 is offline
post #2 of 11 Old 12-21-2011, 11:31 AM
mad 1
mad 1's Avatar
sounds like thermostat is stuck open needs replaced
as for the anti freeze you can get the pre mix or full streigth and mix 50% or 75%
depending were you live and temps
2011 Ram Power Wagon
1997 Ram 1500 5.2 auto 4x4 ext
SCT tune by Hemifever, Fastman 50mm,14x3 open air cleaner, Magnaflow,4:11,, 265/75/16
1993 Jeep YJ4.6 Stroker,, 5 speed,
Alum. head, roller rocker, Duel header, Magnaflow,,4:56,, 33" MTRS,, 2"' lift, Warn Wench, Nates Bumpers
2007 700 Yahama Grizzly ATV
Maxis Bighorns, Power tip,, Play Ground SE Kentucky
2009 Blast 150 Toybox F/S
mad 1 is offline
post #3 of 11 Old 12-21-2011, 11:37 AM Thread Starter
JackedDak03
Quoted: 1 Post(s)
I think I'm going to buy the straight coolant, its about the same price and technically your getting more (I don't want to pay for the added water). Its generally pretty cold up here but nothing crazy, what do you recommend?
Gone:
post #4 of 11 Old 12-21-2011, 11:54 AM
mad 1
mad 1's Avatar
if replacing all anti freeze. what i usally do is pickup two gallons of green
add 1/2 gallon strait to radiator then fill that with water giving it a 50% mix
add that to radiator ,, then open second gallon and 1/2 fill the empty and fill both with water giving a 50% mix and add to truck as needed and extra in resiavior ,, system will burp while driving
add to truck as needed till up to operating temp and thermostst opens cycles
mad 1 is offline
post #5 of 11 Old 12-21-2011, 12:44 PM Thread Starter
JackedDak03
Quoted: 1 Post(s)
Cool thanks, Yeah I'd rather replace it all now since I'm assuming it hasn't been done before.
Gone:
post #6 of 11 Old 12-21-2011, 04:17 PM
BigGreenV10
Big Green
BigGreenV10's Avatar
I always like going with the 70% mix for the max protection not like it cost that much more.
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #7 of 11 Old 12-21-2011, 10:06 PM
mad 1
mad 1's Avatar
its a little bit stronger than50% adding the first 1/2 gallon full strength,,but i usally flush system with water and this covers any water in the block not drained
mad 1 is offline
post #8 of 11 Old 12-23-2011, 11:55 PM
spun360
spun360's Avatar
Quoted: 148 Post(s)
was it a stant t-stat?
parts for sale
ask about my treadwright retread experience
$150: 210lb double and dampener valve springs .550 lift
$pay shipping: new, dana/ spicer (1)greasable upper & (1)lower ball joint for dana 44
$pay shipping: new, standard oil pump
$pay shipping: new, super strength moog #377 frt axle hub universal w/ grease fitting
prices (for residence of the US)
cheep
shoot PMs my way
spun360 is offline
post #9 of 11 Old 01-23-2012, 09:06 AM
welder4
Please check to see if your system needs to be burped . if you have replaced a hose and lost coolant or replaced radiator or heater core it is possible you need to burp the system, start with a cold engine take the radiator cap off and start the engine stand to the side as you want to avoid getting antifreeze in your eyes or clothes. after a few minutes you might see air bubbles coming up through the coolant look into the radiator opening but do so from an angle . or use a mirror . you may have to repeat this a couple of times but if you have air in the system it will prevent the coolant from going into the heater core. if you do see air bubbles coming up make sure to top off the coolant with 50/50 or if it is not up to par you may want to use full strength antifreeze. you can also have someone monitor the temperature and not let it get to hot.
welder4 is offline
post #10 of 11 Old 01-24-2012, 08:27 AM
Moparite
Moparite's Avatar
Quoted: 302 Post(s)
Drill a small hole(1/8 inch)in the t-stat and you won't have to burp the system.
Moparite is offline
post #11 of 11 Old 01-24-2012, 09:54 AM Thread Starter
JackedDak03
Quoted: 1 Post(s)
I havent even gotten around to doing this yet but I did buy the new Tstat. I do need to get this done though.
Gone:
    Warm up Time, engine cuts off until warm Hundy72 1972-1987 Dodge Ram Trucks (D, W-series) 23 12-04-2010 07:54 PM
    lose oil pressure when engine warm pb_ 2G Dodge RAM - General Talk 15 10-24-2009 10:51 PM
    V10 Engine sputters bad once it is warm KorryArdell 2G Dodge RAM - General Talk 3 12-23-2008 11:18 AM
    Engine dies after intial warm up! STILL GrimReaper 3G Dodge RAM - General Talk 3 01-12-2008 10:50 PM
    engine warm,no start chigato 2G Dodge RAM - General Talk 1 01-20-2006 10:46 AM
