5.9 ltr O2 Sensor Location(s) - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 2nd Gen (94 – 01) Forums > 2G Dodge RAM - General Talk
twite63
  Question 5.9 ltr O2 Sensor Location(s) - Posted: 11-02-2004, 02:53 PM
twite63's Avatar
Post #1
OK-
Part II of a previous thread on oxygen sensors... I've purchased a Bosch replacement "Bank1/Sensor1" from a previous trouble code (P0139). My local NAPA counter guy told me this truck has three O2 sensors, left side (driver), right side (pass.), and catalytic converter. After crawling under and in the engine compartment, I can only find two sensors. One is located directly in front (upstream) of the converter and the other in directly behinid (downstream) of the cat. coverter. The NAPA guy thought there should be one on the drivers side exhaust manifold and one on the passengers side manifold, in addition to one downstream of the converter. Anybody know where my mystery "sensor 1" is located?
Your advice is appreciated...keep it comming
gouge93
 Posted: 11-02-2004, 02:58 PM
gouge93's Avatar
City: Aubrey, TX
View This User's Timeslip
Post #2
As far as I know the 1st sensor IS the one that's upstream of the cat. I've never heard of 3 sensors on any 360's. And I never believe anything an autoparts store counter guy says anyway. 99% of teh time they have no clue what they're talking about.
2002 Dodge Ram 1500 rc 2wd 360 Black Sport
Stock Options
-EVERYTHING available except side air bags
Mods
-1"/4" drop courtesy of Slammed1-Belltech Nitro Drop shocks (fronts courtesy of Beandip77)-20" KMC Zodiaks w/Toyo Parada Spec-X 305/50/20 on rear and 275/55/20 on front-JBA Headers(On'97 awaiting switch)-Magnaflow 3" High Flow Cat-Borla xr-1 exhaust - dumped-Superchips Performance Tune-Fastman 52mm tb-ASP underdrive crank pulley-14" x 3" K&N air cleaner-180 t-stat-Ignition(Taylor 8mm SP wires, Indexed NGK 2262 plugs, brass cap&rotor)-MSD SS Blaster Coil-MSD 6A Ignition-Zirgo 16" Electric fan w/adj. temp. control-SRT Hood-SRT Front Bumper -Sir Michaels Rollpan-Mopar Billet Fuel Door -RAM 3rd Brake Light Cover-Flamed Taillight Covers-Painted Stock Billet Grille and RamHead-Mopar Fiberglass Tonneau Cover-Power Sunroof-Silverstar lights
2012 Dodge Avenger R/T Black
1997 Dodge Ram 1500 rc 2wd 318 Black Sport
Retired and about to be parted out
twite63
 Posted: 11-02-2004, 03:04 PM
twite63's Avatar
Post #3
Yeah-
I know what you mean about taking advice, but you'd think with the computers they have now-a-days, there would be less room for mistakes...?!
Thanks for the input. I'll let you know how it goes.
spirit-dodge
 Posted: 11-02-2004, 04:18 PM
CHROME
City: Mi.
State: MI
Post #4
This post should help you http://www.dodgetalk.com/forums/showthread.php?t=19302
Get the front sensor for the right side cause the wire is longer. The left should be the smae sensor only with a shorter wire.
gouge93
 Posted: 11-02-2004, 04:36 PM
gouge93's Avatar
City: Aubrey, TX
Post #5
I just read through that and now you've got me all confused. I dont' think there's 2 upstream ones on my 02 360, but I didn't look at the y-pipe on the drivers side, I guess I need to do that. But in your last post of that other thread you say 97-99 with 5.2's have 2 upstreams. My '97 only had one upstream.
Stock Options
Mods
DodgeFreak
 Posted: 11-02-2004, 04:53 PM
DodgeFreak's Avatar
City: Clinton Twp
State: MI
Post #6
twite, what year is your Ram? The O2 set ups are different from year to year. My 96' only has 2. One pre and pne post-cat. My buddies 2000 has 3 like the parts guy was telling you. So it just depends on your year of truck.
2000 Jeep XJ 4x4
30x9.5s on 15 inch Eagle Alloys with 4.5 BS
*RIP*
96' Ram Sport 1500 RC/SB 5.9L
Mopar Performance PCM
Fastman 52mm TB
Edelbrock Headers
B&M TransPack shift kit
and so much more
spirit-dodge
 Posted: 11-02-2004, 08:29 PM
CHROME
City: Mi.
State: MI
Post #7
I should have pasted the E-mail I sent him. So here it is
> I have a Dodge Ram 4X4 '98 5.2 and would like to replace the pre-cat sensors. I have only one at the front of the cat. Could you please find the part #.
Got this from them
Yes, it's a bit confusing that our website shows a left and a right. I've run into this before, problem is all of my catalogs show that the '97-'99 models with the 5.2L have two in the upstream location. I usually just recommend Walker's 250-24080 which is listed as the right side sensor. It has the same connector as the one listed as the left side, just with a longer wire. I'm confident that it will work just fine in your '98. Feel free to call or write with any other concerns and thanks for your interest.
Mike Carter
Auto Medic Supply
27500 Cumberland Rd.
Tehachapi, CA 93561
1-866-441-7039
I've seen alot of post here where trucks only had one upstream sensor so from that and the E-mail from
https://www.automedicsupply.com/index.php I would say get the right side with the longer wire.
twite63
 Posted: 11-03-2004, 07:41 AM
twite63's Avatar
Post #8
I just checked and tried to re-verify my findings- I have a 2001 ram w/ 5.9 ltr engine. I can only find two(2) oxygen sensors - one directly in front, and the other directly behind the converter...several people have told me I have three sensors on this truck, but I'll be damned if I can figure out where #3 is!
twite63
 Posted: 11-03-2004, 07:51 AM
twite63's Avatar
Post #9
Gouge-
I just checked your link to a previous thread on O2 sensors....now I'm really confused.
Speaking of wires - the wiring from my pre-cat and post-cat O2 sensors travel up on top of the transfer case and dissapear from view. Is it acceptable just to cut the OEM wires near the sensor and splice in the new wires from the new sensor, or should the whole O2 assembly be removed as a complete unit? If so, is there a plug or some type of connector on top of the transfer case that I'm not seeing?
twite63
 Posted: 11-03-2004, 08:16 AM
twite63's Avatar
Post #10
I've got several good quality digital pix of this mytery O2 sensor situation... I'm just trying to figure out how to post them here... stand by...they should be attached.
twite63
 Posted: 11-03-2004, 08:20 AM
twite63's Avatar
Post #11
As you can see, there are no O2 sensors apparent on the dirvers side or passengers side exhaust manifolds. Only one in front and one immediately behind the catalytic converter.
The new Bosch sensor I purchased at NAPA looks identical to both of these sensors. My trouble code indicates "Bank1 Sensor1 High Voltage"... do I assume the "front" sensor is number one?
Mope
 Posted: 11-03-2004, 08:59 AM
Mope's Avatar
mope
City: Pocatello
State: ID
Post #12
I have a 98 ram with the 5.9. There are only two sensors on it. One right where both pipes come into the cat, and one about a foot behind the cat. This is the only two that there are. They are both different. I would not go with the Bosch sensor, because they don't work very well with Dodges. I tried this, and then went to the dealer and got one, and everything is working great. Hope this helps.
danno1
 Posted: 11-03-2004, 09:07 PM
Post #13
I replaced the "after converter" sensor when the check engine light came on. What a bi*ch trying to unscrew it.
Then I replaced the converter a week later. And wanted to replace the "before converter" sensor. I went to NAPA and he said the same thing about passenger or driver side. One was over 70.00 bucks and the other was over50.00 bucks. I bought the higher one, and noticed that the plug had the notch off slightly, but the wire length was the same. So I go back to NAPA, return it for the shorter wire that HAS the notch in the same spot as the old one. When I showed it to the muffler guy putting the new converter on, he said that will never reach. So, I just ended up putting the old sensor back in the "before the converter" spot.
Anybody replacing the upstream sensor, check the notch location with the old one, and see for yourself !
