remove vent window glass from swivel / frame - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 11-28-2011, 08:51 PM Thread Starter
DadTruck
any ideas on how to free the vent window from the swivel / latch and frame?
http://www.flickr.com/photos/1371835...7628198642351/
I got a set out of the pick apart that are factory tinted,, mine are not, would like to ues my frame and chrome latches are they are in better shape/
thanks
DadTruck is offline
post #2 of 11 Old 11-28-2011, 11:09 PM
duval67
Quoted: 3 Post(s)
If I recall correctly, I just took the screw out of the part that the glass pivots on, where it attaches to the glass and then just pulled them out of the channel...didn't take a lot of force.
There's a good chance that there is something that holds them in the channel, but the mechanism had long since worn out on mine, if it did indeed exist.
duval67 is offline
post #3 of 11 Old 11-29-2011, 01:58 AM
angusdevil
They call me Radio
angusdevil's Avatar
Yup, loosen the screw and rotate the window on the screw (with the window open) and it'll slide right out.
1973 RCLB Stroker SB
REBUILD BLOG - radio1973dodge.blogspot.com
- Longtravel suspension still being built, Grabber 35" MT's, Method Wheels, 4.10's.
- Custom dash/gauge cluster, Corbeau seats, dual electric fans, most of the wiring replaced, 7" HID's, lots of other flashy and bright lights
- Fuel cell, aluminum rad, rear tranny cooler, front and rear tube bumpers, cut rear rockers and cage work ready to get started on.
angusdevil is offline
post #4 of 11 Old 11-29-2011, 09:09 AM Thread Starter
DadTruck
I'll try that again,, but on the first one that I got at the pick apart,, I tried to get the vent glass free, to just buy the glass and not the complete frame,
took the screws out,, put a little thumb pressure on it, did not budge, tried to wedge a thin screwdriver in,, it busted in a million pieces....
DadTruck is offline
post #5 of 11 Old 11-29-2011, 12:57 PM
duval67
Quoted: 3 Post(s)
Maybe try spraying some water+dishsoap onto the seal in the channel? Might loosen it up a little bit.
duval67 is offline
post #6 of 11 Old 11-29-2011, 06:22 PM
ssroadrunner
sonny
i think the glass is held in with adhesive rubber like sealer
SS
ssroadrunner is offline
post #7 of 11 Old 11-30-2011, 08:41 AM
Speed Dragon
Aka Force Fed Mopar
Speed Dragon's Avatar
Yeah there is some sort of glue in there, most trucks down here it has been killed by the sun and the glass pops out easily. You might try using a piece of piano wire (what they use to cut windshields out with) carefully around it and free it up. Or just break it and scrape out the leftovers
Rob M.
'93 D150 RC SWB, 5.2 Magnum, NV4500 5-spd, 9.25" diff
'72 D100 RC LWB, PT project
Speed Dragon is offline
post #8 of 11 Old 12-02-2011, 02:45 PM
bookworm
bookworm's Avatar
Heat gun. Heat the channel to loosen the adhesive tape. Then hold the vent glass/channel assembly in such a manner that the frame is against a workbench top. Rap the glass out of the frame with a rubber hammer, firmly.
The problems I had was keeping the glass in the frame after switching it out. I would recommend just taking the vent glass out at the swivel, leaving it in the channel, then installing the whole thing in one piece.
" A man and his truck; it's a beautiful thing. "
I said to my wife:"All my mods aim at efficiency & durability. The added horsepower is an unintended side effect." She snickered in disbelief.
2005 2500 QC 2wd CTD, Charcoal Metallic
Banks PowerPack, FluiDampr balancer, ATS 2-piece exhaust manifold, Banks 3-Disc Billet Torque Conv., Transtar Billet flexplate, Transgo shift kit with some Sonnax billet goodies, Dorman steel trans pan w/drain plug, DieselSite external trans filter, Hellwig rear anti-sway bar, GDP MK-2 fuel filter kit
Tinted, mostly de-badged, some other stuff too.
My truck is exactly the way I want it...except there's a few things I want to change.
bookworm is offline
post #9 of 11 Old 12-13-2011, 07:18 PM
roadram360
roadram360's Avatar
i'd keep it in the channel if it's not pitted. the latch separates with the removal of the little pin in the arm. easy to lose
you like your truck more than you like me. sometimes i do
1978 d-150, 95 360, eddy 750, 4 speed auto, 9.25 rear. her name is sabrina
GOD BLESS AMERICA
*DodgeTalk.com 318 Enthusiast Member #(129)*
roadram360 is offline
post #10 of 11 Old 12-14-2011, 10:14 AM Thread Starter
DadTruck
thanks for the replies,, but the vent window glass seperated from the bottom channel and swivel clamp easily. I had tried one of these at a pull a part just for practice that one must have been glued together,, and I shattered the glass.
I went back to the pull apart and that truck was a D-350 and the vent window bottom chanel and pivot were shapped different fom my 83 D-150,,
I had thought that the D series vent windows were all the same..
DadTruck is offline
post #11 of 11 Old 12-14-2011, 07:04 PM
roadram360
roadram360's Avatar
early vents had a channel and a front latch. mid years had a rear latch and a channel. later vents had a rear latch and no channel
GOD BLESS AMERICA
    1958 Swivel Frame W300M Dodge Power Wagon crawler#976 3G Ram Power Wagon Talk 7 11-11-2011 02:36 PM
    window seal for rear sliding glass window DadTruck 1972-1987 Dodge Ram Trucks (D, W-series) 14 08-08-2011 03:34 AM
    Sliding glass window for Smooth Glass Window slAmArAm 3G Dodge RAM - General Talk 12 06-26-2009 12:09 AM
    Need part that connects window glass to window regulator 20inchDurango 1G Dodge Durango General Talk 0 04-16-2009 12:40 AM
    97 Grand Caravan vent glass interchange cbfarmall Dodge Caravan General Talk 1 06-11-2004 02:45 PM
