Transmission Cooler Installation Pics - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 11-19-2011, 02:40 PM Thread Starter
prototype4342
prototype4342's Avatar
Quoted: 25 Post(s)
Alright guys, I did my transmission cooler install today and thought I would share my pictures as to how I did it. Some people made it more complicated than it needed to be I think.
Basically, I didn't mess with the feed line at all, I left it as is, it is the lower line into the radiator. I basically took my Dremel and cut the hard return line to insert the cooler.
Here's the top return line leaving the radiator cooler and routing to the auxiliary cooler.
Here's the line out of the auxiliary cooler back to the transmission, notice I kept the quick disconnect from the original return hard line and used it to route the line around the radiator.
And the same thing just from the other side
Here's a view of the cooler, it will get moved but I was in a time constraint, so it stays there for now. You can see the return line from the cooler going in between the condenser and AC line to the hard line.
Blue Truck Club Member # 245
Cracked Dash Enthusiast Club Member #29
2000 Dodge Ram 1500 RCSB: 8.0L V10/NV4500 swap, 3/4 ton axles...IT'S ALIVE!!!
1981 Chevy Camaro: 5.7L '86 350 LT9, Edelbrock Performer Intake man., Edelbrock 600 carb., Drop base air cleaner, unnamed headers, pypes crossflow exhaust, ECP all aluminum radiator, Mark VIII electric fan, PTFB GT suspension, single adjustable AFCO shocks, C/E subframe connectors, 4-speed.
1998 Jeep Cherokee: Stock
1988 Dodge B350 Maxi Wagon: Stock
1998 Kawasaki KLX300R: Mikuni t36 carb, Stroker exhaust, plated
1986 Yamaha FJ1200: Stock
2007 Triumph Tiger 1050: Stock
prototype4342 is offline
post #2 of 8 Old 11-19-2011, 04:42 PM
damilleniumboy
damilleniumboy's Avatar
Nice write up; how much was the tranny cooler?
I love Corvettes
6000k HID's, cold air intake, dual exhaust, aftermarket power windows, after market power locks, 31x10.5x15 BFG's all terrain k/o tires, DVD/NAV touch screen, Rockford Fosgate amp, Sony 12" subwoofer, 35% tint, and there will hopefully be more to come
damilleniumboy is offline
post #3 of 8 Old 11-19-2011, 04:57 PM Thread Starter
prototype4342
Quoted: 25 Post(s)
That one was $60 from Advanced Auto, it'a a plate and fin cooler not a tube fin cooler, so it cools better, not to mention it's the same size as the largest tube fin cooler and looks much better.
It came with everything needed for a simple install like this, I even bought extra hose in anticipation of needing it, I took it back like 15 minutes ago, haha.
I have just seen some people cutting the original rubber tubing, which I would really prefer not to do, this keeps me from having to do that, at least until I get a trans. temp gauge, then I'll have to splice in a T on the feed line.
post #4 of 8 Old 11-19-2011, 09:38 PM
Hylander
Hylander's Avatar
Not to sound dumb, but what is the difference ?
Failure is not an Option
99 SLT 1500 4x4, Trac-Lok, 1.75" lift 2500 Coil Springs
Hylander is offline
post #5 of 8 Old 11-19-2011, 10:08 PM Thread Starter
prototype4342
Quoted: 25 Post(s)
Tube-fin:
Plate-fin:
Basically they use the same heat exchange principle, but you get better cooling with a plate-fin cooler because more of the fluid contacts the cooling fins than in a tube-fin cooler.
post #6 of 8 Old 11-19-2011, 10:10 PM
spun360
spun360's Avatar
Quoted: 150 Post(s)
a plate & fin cooler; most often called a manifold cooler/ radiator
same thing as the engines antifreeze cooler
least amount of back pressure
fast fluid movement
average heat displacement properties
a tube & fin cooler ;also called a linear flow radiator
consists of one continous tube occupied by fins
compounded additional back pressure for every bend
very slow fluid movement
high heat displacement capabilities
parts for sale
ask about my treadwright retread experience
$150: 210lb double and dampener valve springs .550 lift
$pay shipping: new, dana/ spicer (1)greasable upper & (1)lower ball joint for dana 44
$pay shipping: new, standard oil pump
$pay shipping: new, super strength moog #377 frt axle hub universal w/ grease fitting
prices (for residence of the US)
cheep
shoot PMs my way
spun360 is offline
post #7 of 8 Old 11-19-2011, 10:34 PM Thread Starter
prototype4342
Quoted: 25 Post(s)
Makes sense I guess, I always saw it as with a plate-fin type there is more fluid being cooled at once inside of the plate, as opposed to a tube-fin.
I think the stock ones on the newer Rams are plate-fin.
post #8 of 8 Old 11-19-2011, 10:48 PM
damilleniumboy
I might add that to my Corvette, it's automatic and I just replaced the transmission this past August. The Ram is a 5 speed, so there is no need to install a tranny fluid cooler lol. I had been looking for an idea as to how to add one, and I couldn't find one on the corvetteforum. Thanks a bunch!
I love Corvettes
    Transmission Cooler Installation - '99 Dakota 3.9 Liter brown518 2G Dodge Dakota - Drivetrain Talk 0 07-20-2009 01:45 PM
    Transmission Cooler beboboy9 2G Dodge RAM - General Talk 1 01-22-2008 05:27 PM
    Transmission Oil Cooler: Have one ? Results ? Fan Forced trans cooler a good idea ? RamVanMan Dodge B-Series Vans 1971 - 2003 19 04-09-2007 04:50 PM
    transmission cooler? DurangoSnwBdr 1G Dodge Durango General Talk 10 02-17-2005 02:01 PM
    Best Transmission Cooler To Buy poloski 2G Dodge RAM - Drivetrain Talk 1 06-09-2004 12:50 PM
