05 Gr. Caravan blinking dash lights and sometimes brake & abs lights come on and off - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 11-06-2011, 05:31 PM Thread Starter
kiefer
I have this wierd problem. Blinking dash lights, radio goes off, brake light and abs light come on and go off in 3 seconds ... and then everything is ok for a little while. Vehicle wants to stall but never did so far. Battery checks good, alternator checks good. All ground cleaned and greased up with dielectric grease. It is wors when it's raining or it is just wet. Cluster test shows no codes ... goes through just fine. Sometimes when I turn it off, I hear a beep every some 10 seconds for about 4 to 5 minutes and then it's gone.
kiefer is offline
post #2 of 6 Old 11-07-2011, 02:17 PM
The_War_Wagon
The_War_Wagon's Avatar
Quoted: 106 Post(s)
Red face
Sounds like a bad PCM in there somewhere. We just traded in an '08 SE with the same issue. As it was in the shop, I traded it for an '08 SXT!
'92 Ramcharger - 318 Magnum, 35" M/T's - 4 1/2" lift - 4.56 gears, and a continual work in progress!
The_War_Wagon is offline
post #3 of 6 Old 11-09-2011, 01:35 AM
Ratchet75
Quoted: 12 Post(s)
Model year?
Ratchet75 is offline
post #4 of 6 Old 11-09-2011, 08:10 PM Thread Starter
kiefer
2005 grand caravan (just grand caravan)
kiefer is offline
post #5 of 6 Old 11-14-2011, 12:56 PM
1977TA
Any Ideas Why Instrument Panel Goes Out When Flasher Is Pushed
1977TA is offline
post #6 of 6 Old 11-14-2011, 04:58 PM
Ratchet75
Quoted: 12 Post(s)
I've read posts recently about a ground stud that was either corroded or the nut was loose creating similar problems. It's the G303 ground at the base of the drivers side "B" pillar. That's near the drivers seatbelt anchor.
The IPM (fuse box) has had a history of corrosion problems on 4th generation vans. Check the connections for corrosion and security. Could be on the internal circuit board. Try wiggling connections to induce/correct the problem.
    Dash and running lights went out... brake/turn lights fine? aaron7 1972-1987 Dodge Ram Trucks (D, W-series) 3 12-02-2010 09:59 AM
    Blinking headligthts and dash lights aepowell 1G Dodge Durango General Talk 8 04-28-2008 09:26 AM
    96 Caravan. Blinking lights, Heat On/OFff MattGrass Dodge Caravan General Talk 4 09-27-2007 10:18 PM
    HEADLIGHTS<TAILLIGHTS>DASH LIGHTS BLINKING LIKE CRAZY! blinkindodge 2G Dodge Dakota General Talk 6 05-19-2007 04:49 PM
    2001 Grand Caravan Blinking Dash lights rickymon66 Dodge Caravan General Talk 2 09-20-2005 12:47 AM
