2001 Ram 1500 with 318 - NO START INTERMITTENT - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 11-02-2011, 08:24 PM Thread Starter
MoparGrl
MoparGrl's Avatar
Question 2001 Ram 1500 with 318 - NO START INTERMITTENT
Hoping someone can help out. Truck just randomly wouldn't start one day, so had to get it pop started (it's a manual) and gt it home. In the driveway it started every time. Then wouldn't start in the morning. Replaced the starter and it started over and over. Started next morning and then wouldn't start again last night. Pop start get it home, starts fine last night. This morning, No start again.
Here is the important info :
Replaced starter and had core tested 2x it failed (seized up)
When turning the key can hear click at relay (swapped with blower motor relay and nothing changed)
when turn key and push clutch during it's no start condition, there is plenty of power and can hear fuel pump power up
battery terminals and grounds have been cleaned
problem developed in the past week, it has become colder, however we've also had warmer days in the 50's when this happens
Right now at the ultimate frustration level, because well... it usually starts fine in the driveway and wont start when it's somewhere else, then once it gets home it starts fine until after it sits overnight.
Anyone else have this problem? Any Ideas welcome
MoparGrl is offline
post #2 of 7 Old 11-02-2011, 08:32 PM
Silver 1500 4X4
Still Pump'n
Silver 1500 4X4's Avatar
When thiis happnes you are saying the starter won't spin, or spins but does not engage the ring gear, or the engine turns over but won't fire?
2001 Ram 1500 4X4 Quad Cab SLT
SCT TUNED
Silver 1500 4X4 is offline
post #3 of 7 Old 11-02-2011, 08:33 PM Thread Starter
MoparGrl
MoparGrl's Avatar
No Crank at all when you turn the key. It's bizarre, but once it gets pop started, thing starts over and over without a problem ? I imagine the ignition switch would be ok if the relay is clicking ? and it seems to run absolutely normal once it's started.
MoparGrl is offline
post #4 of 7 Old 11-02-2011, 08:43 PM
Silver 1500 4X4
Still Pump'n
There is a switch on the steering column that is activated by a rod from your ignition key lock cylinder. This switch may be failing, or may have come loose & is not letting the actuator rod move far enough to make the switch make contact inside. The ignition key cylinder itself may be worn to the point where it can not allways move the rod far enough to make the switch make contact properely.
If the components I have mentioned are all OK, them I would suggest a voltage drop & amperage draw test at the starter by a mechanic.
SCT TUNED
post #5 of 7 Old 11-02-2011, 09:27 PM Thread Starter
MoparGrl
MoparGrl's Avatar
definitely something worth checking, thank you It's currently doing it's no start thing sitting in the driveway right now. Have to invest in some Torx drivers to get the cover off and check.
MoparGrl is offline
post #6 of 7 Old 11-02-2011, 11:54 PM
Silver 1500 4X4
Still Pump'n
Try shaking the key switch when turned to the start position when this no start condition happens. Rock the key towards the dash & back towards yourself.
SCT TUNED
post #7 of 7 Old 11-03-2011, 04:12 PM
25HEMI00
25HEMI00
25HEMI00's Avatar
ground issue? you said it starts after you pop start it though.
2003 Hemi Ram 2500 Sold
Current:
1999 Ram 2500 v8 Reg Cab<<<<Rescued from Auction Lot!
Completely put her back together and installed:
7'6 Western plow<< redesigned 1500 carriage and made brackets for 2500
hughes plenum repair+93 octane=no more ping
25HEMI00 is offline
    2001 Ddge ram 1500. wont start or idle coybrown29 2G Dodge RAM - General Talk 1 07-15-2009 07:01 PM
    Please HELP! 2001 RAM 1500!! 3.9L Intermittent idling problems while driving. AlphaTech 2G Dodge RAM - General Talk 2 10-17-2008 08:08 PM
    Intermittent Start rlr154 2G Dodge Stratus - General Talk 4 11-25-2005 01:26 AM
    2001 G/C Intermittent Brakes rwtapp Dodge Caravan General Talk 1 11-08-2005 09:10 AM
    Intermittent No Start...Need Help kervin22 Dodge Caravan General Talk 6 09-23-2005 09:10 AM
