what kind of ignition type is on the 86 w150 with a 318 manual trans? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 10-11-2011, 05:55 PM Thread Starter
ryuku tatsu
I am not getting any spark and i am not sure what kind of set up i have for an ignition system. I did a search in the forum and i could not find anything,
Thanks,
2005 QC 4X4 Hemi 1500, 97 ext cab 4x4 360 auto, 86 w150 4x4 reg cab long bed 318 manual
ryuku tatsu is offline
post #2 of 6 Old 10-11-2011, 06:25 PM
crazzywolfie
Quoted: 1 Post(s)
the ignition system be something like this.
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
93 ramcharger 318 FI 2wd
crazzywolfie is offline
post #3 of 6 Old 10-12-2011, 07:27 AM
coastermeister
coastermeister's Avatar
'86 has a spark control computer in the drivers side fender which could have died. Could be several other things as well. With the switch on do you have power at the positive terminal of the coil? Be sure to measure the coil voltage from a good ground (not the negative terminal on the coil) to the positive terminal on the coil.
'86 D150 Custom LWB, White, A/C, 318-2bbl, 727, 6050 GVWR, 9-1/4 3.21 Sure-Grip
All Heavy Duty Options- 114 amp alternator, big radiator, transmission cooler, original owner, everything works!
coastermeister is offline
post #4 of 6 Old 10-12-2011, 04:41 PM
roadram360
roadram360's Avatar
where are you not getting fire? coil terminal? dist? plugs?
you like your truck more than you like me. sometimes i do
1978 d-150, 95 360, eddy 750, 4 speed auto, 9.25 rear. her name is sabrina
GOD BLESS AMERICA
*DodgeTalk.com 318 Enthusiast Member #(129)*
roadram360 is offline
post #5 of 6 Old 10-26-2011, 06:34 PM Thread Starter
ryuku tatsu
What i did is pull a spark plug wire and but a bolt inside where the spark plug would connect, then i had someone crank the engine, I barely saw a very light orange spark. I looked for a short somewhere, and i found a wire going to the hot side of the alternator that was shorting to the engine block. I made sure the wire was not touching anything and the truck started right up and has been running fine. Ive only had this truck for a month, and im still working out the kinks. I replaced spark plugs, and Im checking the timing this weekend...
post #6 of 6 Old 10-26-2011, 10:05 PM
roadram360
roadram360's Avatar
cool
GOD BLESS AMERICA
    rebuilding a 78 dodge w150 with 440 ignition questions nlpro 1972-1987 Dodge Ram Trucks (D, W-series) 6 04-27-2011 09:51 AM
    manual trans to automatic trans swap gomez7162 2G Dodge RAM - Drivetrain Talk 0 03-28-2008 08:24 AM
    86 w150 ignition issues..... rovertech 1972-1987 Dodge Ram Trucks (D, W-series) 8 12-01-2006 10:47 PM
    1984 W150 trans. problems 10cylinderRAM 1972-1987 Dodge Ram Trucks (D, W-series) 8 11-13-2006 03:55 AM
    84 W150 clutch or trans problem nightman 1972-1987 Dodge Ram Trucks (D, W-series) 3 05-05-2005 07:29 PM
