TPMS problem - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 22 Old 10-02-2011, 09:13 PM Thread Starter
BMRbrnSNRbrd
Try harder
BMRbrnSNRbrd's Avatar
TPMS problem
We've recently started having colder temps in the early morning and this morning my TPMS light came on because my right two tires were low. Now I've added pressure to them (36 psi) and all four tires are the same but my two right side tires are still tripping the TPMS light. Is there a way to reset the TPMS sensors?
Mineral Gray 2010 Dodge Ram CC Hemi Sport
Exterior: Limo tint | Painted tips | Painted calipers | De-badged | Painted grill inserts | Gloss black b-pillars | Color matched antenna base |
VHT tinted puddle lights | Color matched tailgate handle | Shaved and two-toned grill | Painted Vararam lid w/ two-toned Ram badge |
Color matched Laramie 2500 flares | Shaved tailgate badge | Shortened and painted antenna
Lighting: Color matched headlights retrofitted with 5000k Morimoto projectors |
5000k HID fog lights tinted with Lamin-x | 6000k HID retrofitted reverse lights
Interior: Color matched interior plastics | 2 MTX 12" subs in a cheap box | REN MyGig 30gb headunit | Black microsuede wrapped headliner and sun visors | Black microsuede wrapped and shaved pillars | Black microsuede wrapped custom made door inserts | SEM black painted interior plastics
Suspension: McGaughy's 2/5 Economy drop | BrakeMotive cross-drilled and slotted rotors | All black Milano M724 22s | 305/40R22 Nitto 420s | AirLift Helper Bags
Performance: Superchips Vivid Paq w/ trans tuning | Vararam Air Grabber | Magnaflow 18" Muffler | Raceland USA E-Cutout |
Billet Technology Oil Catch Can | Clutch fan delete | 180 T-stat | Magnaflow Y-Pipe with relocated crossover pipe
BMRbrnSNRbrd is offline
post #2 of 22 Old 10-02-2011, 09:22 PM
hemi_jeff
hemi_jeff's Avatar
My only thought would be to air up to 39-40 and see if that fixes it. I see a lot of people this time of year and throughout the winter with the dummy light that comes on because of the cold weather. I do not know a specific way to reset the system.
2011 Ram 1500 Sport Crew Cab 4x4
3.92 LSD | Line-X Bedliner | Monster XD Wheels | LED tag lights | LED switchback front signals | HID fogs | Retrofit Headlights | Mufflex 14"
Previous Trucks:
hemi_jeff is offline
post #3 of 22 Old 10-02-2011, 09:31 PM
duso02
duso02's Avatar
Quoted: 14 Post(s)
Did you drive it long enough after airing up? It needs time to read. Also, if you turn the truck on and the light flashes for a long time before going steady on, it's a problem with a sensor or the system.
LOU
2011 Blue Ram Sport QC HEMI 4x4
Military Truck Club Member #16
"The Marines I have seen around the world have the cleanest bodies,
the filthiest minds, the highest morale, and the lowest morals of any
group of animals I have ever seen. Thank God for the United States
Marine Corps!"-- Eleanor Roosevelt
duso02 is offline
post #4 of 22 Old 10-02-2011, 09:36 PM Thread Starter
BMRbrnSNRbrd
Try harder
There is no way I'm going to run 40psi. I normally run 35-36 without problems. I drove it home 20 miles this afternoon when temps were higher and even though the pressure was back up they still popped the light and the values on the right side continued to flash.
post #5 of 22 Old 10-02-2011, 09:38 PM
techman1a5
From my understanding of the TPMS, is that it take a while before the TPMS will send the correct data to the computer to turn off the light.
Brand New 2012 Ram 2500, Big Horn Edition[/COLOR], 5.7L 3.73 diffs. HEMI,4X4 Crew Cab, 430 Sat Radio, All Power Options. Sun Roof, Remote Start, Parking assist, backup Cameras. 17" Rims,
Mods so far
:AMP power steps, Undercover Top , 3 12v power outlets in overhead console, 2 front looking cameras that only run when the truck is running, spoiler on back w/brake lite... more to come.
98 merc v8 daily driver 233k miles, 28mpg's
Techman1a5, SCPO, USN, Retired @20yrs,10 days
Gone, but not forgotten: 2007 1500 Ram 4x4 Thunderroad, 2011 1500 Ram 4x4 quad cab, bighorn. 2012 2500 4X4 CC bighorn
techman1a5 is offline
post #6 of 22 Old 10-02-2011, 09:41 PM
War Machine
Put it up to 38 just to make sure the reading from your tire gauge doesn't differ from the tpms. Then you have to drive it for about 15 minutes with a consistent speed above 20 mph. If you stop or slow down before it relearns you'll have to start over again
'13 2500 Laramie - 8" BDS long arm, Fox shocks, 37" Toyos
'14 Wrangler Unlimited Sahara - 2" BDS, Fox shocks, 33" BFGs
'15 Challenger Hellcat - Black on black ordered 26 July
War Machine is offline
post #7 of 22 Old 10-02-2011, 09:43 PM Thread Starter
BMRbrnSNRbrd
Try harder
I drove 20 miles this afternoon going 70+ with all tires reading 35psi.
post #8 of 22 Old 10-02-2011, 09:49 PM
ITSARAM
ITSARAM's Avatar
Time to trade it in.
09 Quad TRX4 HEMI
Detonator Yellow
Hot-rodicus supersonicus
ITSARAM is offline
post #9 of 22 Old 10-02-2011, 09:49 PM
War Machine
I'm pretty sure 35 is incorrect and it should be 40 psi. i could go check our 2011 1500 but that might be different then your 2010. I run my 2500 at 50 psi where the spec is 60 psi on the door placard. It sounds stupid but if my light comes on I have to fill to 61 psi to turn the light off then deflat the tire to 50 psi which keeps the light off.
post #10 of 22 Old 10-02-2011, 10:08 PM
10TXRAM
10TXRAM's Avatar
Mine will usually reset them selves after driving a couple blocks. Did you try and see if it shows any codes on your tuner?
Diablo tuner
Magnaflowed
Cutout
Jeep srt8 headers
custom Y pipe
HID heads/fogs
HID Reverse lights
Cooper STT's
3" level
10TXRAM is offline
post #11 of 22 Old 10-02-2011, 11:14 PM
hemi_jeff
hemi_jeff's Avatar
Sorry, I didn't mean continually run 40. Just raise pressure to get the light to stop flashing and the computer back to normal then try lowering all the pressures again.
Previous Trucks:
post #12 of 22 Old 10-03-2011, 11:28 AM
hemiwicked
Quoted: 1 Post(s)
got 54K on mine, does it all winter long, they come on and off, just keep an eye on the tires you'll be ok
2009 Ram 1500 QC SLT 4X4
Borla Exhaust
tow rig, 2012 Passport 3180RE(6k dry weight)
or a 2006 Nitro 189 Sport 200HP Merc optimax Boat
hemiwicked is offline
post #13 of 22 Old 10-03-2011, 01:39 PM
jasonlmarsh
jasonlmarsh's Avatar
Quoted: 8 Post(s)
I just got my truck back from Bob Moore on NW Expressway for this same issue. My left 2 sensors were not reading in the EVIC (well it was sporadic when the would read). I swapped the left wheels to the right side and the problem stayed on the left side, so I assumed it was the truck, not the sensors (And I told them that). They replaced one of the wheel sensors on the left side anyway and said "there ya go, all fixed". Got halfway to work and the left side is out again.... ugh. Back to the dealer next week. If you get this fixed before me, please let me know what was the culprit.
2011 Laramie CrewCab 4x4
9" Lift (RCX 6" + Bilsteins 1.4" + 1.5" rear spacer + 1.5" Zone Body Lift)
325/60/20 (35.5x13) Goodyear Wrangler Duratrac
Gear Alloy 20x10 -19mm wheels
Bestop Powerboards | Cabin Filtration
2010 Laramie QuadCab 4x4(Gone and missed!)
10" Lift (Procomp 6" + Bilsteins 2.8" + Body Lift 1.25")
37x12.5x20 Nitto Trail Grapplers | 20x10 Fuel wheels -12mm 5" BS
AMP Research Power Steps | Power Wagon Flares
BDS Dual steering Stabilizer | Cabin Filtration
jasonlmarsh is offline
post #14 of 22 Old 10-03-2011, 02:03 PM
candy08
candy08's Avatar
Mine always read correct tire psi but my light stays on, just had the tpms module replaced.....worked for 2 days and the light is back on again....getting anothe new one next week.
'11 CREWCAB SPORT 4X4 / SUNROOF / ALPINE / NAV / REMOTE START / TRAILER BRAKE
AWE FAWK TOO MUCH TO LIST!
TRUCK IS FOR SALE
candy08 is offline
post #15 of 22 Old 10-04-2011, 12:01 AM
jsdragonsoul333
jsdragonsoul333's Avatar
My sensor warning wouldn't/won't disapear until psi was right at or close to 40psi.
2007 1500 3.7L Rear ended and wrecked by an illegal immigrant.
2010 1500 3.7L Soft spot for the the little under powered workhorse.
A loyal friend, a gentle giant, a monster when provoked.
jsdragonsoul333 is offline
post #16 of 22 Old 10-04-2011, 07:32 AM Thread Starter
BMRbrnSNRbrd
Try harder
The light finally shut off yesterday afternoon. I'm still running 35 psi and no problems have popped back up yet.
post #17 of 22 Old 10-17-2011, 09:42 AM
11HemiNate
11HemiNate's Avatar
There is a recall for this. I just purchased a 2011 4x4 Crew Hemi and there are 3 flashing from the dealer on mine. They are ordering 3 new sensors and performed a multitude up flashes trying to fix the issue. The tech (which I trust, He worked on my 04 Hemi and 05 Cummins) said they are having so many issues with these sensors. They ran my pressure up to 45 PSI and couldn't clear the symptoms.
11HemiNate is offline
post #18 of 22 Old 10-17-2011, 03:01 PM
mergner26
mergner26's Avatar
I've had this problem twice now after a good cold night. I inflated the tire with the warning to about 37-38 which was more than the rest of the tires and it still would not go off. I finally had to get it over 40 until the light went off then just deflate it back down. That's fixed it both times so far.
2010 Dodge Ram 1500 4.7 SLT 4x4 (White)
  • Bilsteins set at 2.8
  • 18x9 Rockstars (Black)
  • 295/65/18 Wrangler Duratracs
mergner26 is offline
post #19 of 22 Old 10-17-2011, 04:03 PM
dwins1900
dwins1900's Avatar
Yeah the sensors are a pain in the A## your suppossed to run 32 psi but if its cold you cant run close to 32 without the sensors going off. I usually run 36 in the winter just to keep the lights off my dash
dwins1900 is offline
post #20 of 22 Old 10-17-2011, 04:35 PM
DodgeMan33
Wow....36psi? That seems too low. Is that really what the door says? Wow. I know that the manufacturers "recommend" a certain tire pressure for NVH, but damn. How often do you go thru tires? Hmmm?
38-40 is definitely better IMO than 36, but still a little low.
Why wouldn't you run 40psi? What, in your opinion do you see as detrimental at running at a better pressure for longer tread life, better MPG, etc? Especially on the factory 20's.
I run mine at 45psi w/NO problems. And I have the 17s. Yeah, if I want a smoother, or quieter ride I could drop it down. But I'd rather pick up the extra 10% mpg or so and prolong the life of my tires.
Just a thought. It won't hurt to run at a slightly higher pressure.
Oh wait, you're running the SRT 22's? Then yeah, you are definitely too low @ 36psi. You should be running 40psi or higher, no doubt
2010 1500 RC SLT
Mineral Grey
Hemi
22" SRT wheels
265/45/22 and 305/40/22 Toyos
3.21 gears (I want 3.92 w/limited slip/anti spin)
4th Gen Truck Club #3313
DodgeMan33 is offline
    TPMS vs MPG briansal 4G Dodge RAM Performance Talk 4 03-07-2011 03:10 PM
    Tpms wescougar 3G Dodge RAM - Tire and Wheel Talk 8 12-12-2010 12:51 PM
    tpms? TEDDYCHK 3G Dodge RAM - Tire and Wheel Talk 5 11-14-2010 07:12 PM
    Tpms Will225 3G Dodge RAM - Tire and Wheel Talk 8 04-28-2010 06:00 PM
    07 Grand Caravan TPMS problem navytwidget Dodge Caravan General Talk 2 12-21-2009 09:37 PM
