Hood scoops and lower grille mods... - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 28 Old 09-28-2011, 11:15 AM Thread Starter
Harley's Ram
Harley's Ram's Avatar
A couple of mods I've done within the last couple of days and thought I would share. Hood scoops have been drilled out and the heat shield cut to where a little more air comes in and the heat comes out when parked. Lower grille cut out just to eliminate some of the cheap plastic look and allow room for some tow hooks that are coming soon. All done with a rotary tool...
2014 Ram 1500 4x4 Sport, Flat black stock 20's w/33x12.50x20 Federal Couragia M/T
Harley's Ram is offline
post #2 of 28 Old 09-28-2011, 11:40 AM
myoung84
Administrator
myoung84's Avatar
Quoted: 19 Post(s)
Looks good!
Retro Shop Custom FXR Projectors | Diablo inTune | Vararam Intake | Moe's 87mm TB | BT Oil Catch Can
Toyo A/T II Tires | Bilstein 5100 Front Shocks @ 2.1" | Bilstein 5100 Rear Shocks | Movotech UCA's
Bora 1.25" Spacers | AirLift Air Bags | Bestop PowerBoards | Undercover LUX Bed Cover | BedRug
Magnaflow Exhaust | Volant Intake | Diablo inTune w/Hemifever Tuning | BT Oil Catch Can
myoung84 is offline
post #3 of 28 Old 09-28-2011, 01:01 PM
Ghostknife
Ghostknife's Avatar
looks good i just did the lower grill mod yesterday on mine too, but i have to find the dremel to fine tune the cut
Ghostknife is offline
post #4 of 28 Old 09-29-2011, 11:13 AM Thread Starter
Harley's Ram
That's the hardest part or that part that takes the most time anyways. The plastic likes to get heated and bunch up to make a mess. Good luck and yours looks good in the pic.
post #5 of 28 Old 09-29-2011, 11:29 AM Thread Starter
Harley's Ram
How did I forget! Also did my interior before the other and got rid of the silver trim that matched nothing on the truck. Went with a universal black metallic to start and see how it turned out and I like it.
Crappy pic quality...
post #6 of 28 Old 09-29-2011, 01:12 PM
tadamson
Sweet looking. Great work on the detailed cutouts.
How hard was it to pull the interior trim for paint?
tadamson is offline
post #7 of 28 Old 09-29-2011, 02:15 PM Thread Starter
Harley's Ram
Thanks man! Not hard at all except the part where you're starting and nervous to pull and tug. A few screws to remove and the rest is pretty easy.
post #8 of 28 Old 09-29-2011, 03:40 PM
Thor09
Thor09's Avatar
Quoted: 1 Post(s)
Looks good!
2015 Sport 1500 Ceramic Blue Crew
|Rancho Quicklift level, Duratrac 305/55r20, 42" curved LED bar, Vararam, 6K HIDs|
Thor09 is offline
post #9 of 28 Old 09-29-2011, 04:32 PM
adwdurango
adwdurango's Avatar
Looks awesome! Ditch the little plastic piece under the bumper though!
2004 Flame Red Durango Limited
5.7L Hemi / AWD / 3.55's
17" x 9" (-12) Black XD Spys / 285/70 Nitto Trail Grapplers / Cranked Torsion Bars
Color Matched Grill Shell / Grillcraft Mesh Inserts / 6k HID's in the fogs / K&N 77 Intake / Resonator Chop & Flowmaster 40 / Leds in several different places
Some other small mods with even bigger plans.
Sig pic by: BMRbrnSNRbrd
adwdurango is offline
post #10 of 28 Old 09-29-2011, 05:18 PM
BMRbrnSNRbrd
Try harder
BMRbrnSNRbrd's Avatar
Can you do a close up pic of what you did with the lower bumper grill?
Mineral Gray 2010 Dodge Ram CC Hemi Sport
Exterior: Limo tint | Painted tips | Painted calipers | De-badged | Painted grill inserts | Gloss black b-pillars | Color matched antenna base |
VHT tinted puddle lights | Color matched tailgate handle | Shaved and two-toned grill | Painted Vararam lid w/ two-toned Ram badge |
Color matched Laramie 2500 flares | Shaved tailgate badge | Shortened and painted antenna
Lighting: Color matched headlights retrofitted with 5000k Morimoto projectors |
5000k HID fog lights tinted with Lamin-x | 6000k HID retrofitted reverse lights
Interior: Color matched interior plastics | 2 MTX 12" subs in a cheap box | REN MyGig 30gb headunit | Black microsuede wrapped headliner and sun visors | Black microsuede wrapped and shaved pillars | Black microsuede wrapped custom made door inserts | SEM black painted interior plastics
Suspension: McGaughy's 2/5 Economy drop | BrakeMotive cross-drilled and slotted rotors | All black Milano M724 22s | 305/40R22 Nitto 420s | AirLift Helper Bags
Performance: Superchips Vivid Paq w/ trans tuning | Vararam Air Grabber | Magnaflow 18" Muffler | Raceland USA E-Cutout |
Billet Technology Oil Catch Can | Clutch fan delete | 180 T-stat | Magnaflow Y-Pipe with relocated crossover pipe
BMRbrnSNRbrd is offline
post #11 of 28 Old 09-30-2011, 03:29 PM
Adidas_kn
Agent Orange!
Adidas_kn's Avatar
Quoted: 5 Post(s)
Where is the air from the scoops going? Just dumping into the top of the hood liner? It all looks good though.
09' QC 2wd, Custom Lift with air suspension, Ram Runner Wide Body, Custom interior, Full Bolt-on.
14' Ram Express Black Edition RCSB, 8spd, 3.55/LSD. Ported Heads/Intake/TB, Greene STG 2 HL Cam, Full Bolt-on, Lowered.
78' D100 Adventurer SE RCSB, 445ci Big Block, Comp Cam, Torker 2 intake, MSB Pro Billet Dist. H/O coil, FiTech 600 EFI, Hooker long tubes, True Duals, Full LED conversion.
Adidas_kn is offline
post #12 of 28 Old 09-30-2011, 09:51 PM
BMRbrnSNRbrd
Try harder
Even if they don't do anything, it would be nice to say it's a functional hood vs non-functional.
post #13 of 28 Old 10-01-2011, 09:22 PM
RedExpress11
RedExpress11's Avatar
What did you use to cut the grill? How do you remove the insert from the bumper?
2011 Ram 1500 Express
RedExpress11 is offline
post #14 of 28 Old 10-01-2011, 09:27 PM
BMRbrnSNRbrd
Try harder
Removing the insert is very easy...just slide under there and look. You simply pop out some tabs from the loops they insert into.
I would say a dremel and a steady hand would make for a clean cut. Just use any kind of tape to mark your lines so you stay straight.
post #15 of 28 Old 10-01-2011, 09:33 PM
Ghostknife
Ghostknife's Avatar
hell i used a 4.5" cutoff wheel and then a dremel to fine tune it in
post #16 of 28 Old 10-01-2011, 10:19 PM
RedExpress11
Thanks for the info, I am going to try this tomorrow.
post #17 of 28 Old 10-11-2011, 05:49 AM
straightravage
I have the same question as well.... Where does the air scoop channel the air into?? I looked under my hood... and the Fire blanket coveres both points where the air would come in!
at higher speeds do you have to worry about that blanket coming off hood and falling on the engine?
Just wondering??
straightravage is offline
post #18 of 28 Old 10-25-2011, 07:42 AM
straightravage
Bump for an answer?
post #19 of 28 Old 10-25-2011, 02:48 PM
Musclemckeester
5.7L HEMI
Musclemckeester's Avatar
Just wondering??
It basically goes nowhere, just up into the back of the hood. The hood was a really poor design. Some will get dropped into the engine, some will go to the back of the hood and be useless. What he did - and I did the same thing - was cut open the fire blanket where the scoops roughly open. There's not that much air going in through the scoops for you to worry about the entire thing falling down.
Musclemckeester is offline
post #20 of 28 Old 12-30-2011, 05:07 PM
ipsd39173
Two ques. First- Ghostknife, are you planing to paint the insert white? Second-HarleysRam, what did you use on the silver trim and was there much prep work? I know they have paint made for plastics but have never used them. Thanks. I just traded my 2006 for a 2012 a few weeks ago and I am ready to start some changes.
ipsd39173 is offline
    where to go for hood scoops? r6_ram 3G Dodge RAM - General Talk 3 03-23-2008 12:16 PM
    New hood, grille and light mods+ PICS Carrolls Ram 3G Dodge RAM - General Talk 9 07-15-2007 09:24 PM
    hood scoops vpkeeper 1G Dodge Durango - Interior/Exterior 3 10-29-2005 03:13 AM
    Hood w/ Scoops R/T_Brett 1G Dodge Durango - Interior/Exterior 21 01-25-2005 09:43 AM
