air shocks ( snow plow ) 2500 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 09-20-2011, 12:03 PM Thread Starter
J Sell
J Sell
Hey,
I just bought a 2008 2500 ram with the 6.7 and i want to put on a western wideout snow plow.. The people from western say its a bad idea due to the weight of the diesel ... If i would of bought the truck with the hemi then everything would be just fine
i really want the plow as it it would greatly help my landscape company grow. So if i put this plow on whats going to go to sh**? Should i be looking into these air shocks? http://www.truckspring.com/suspensio...evel-rite.aspx
Are the factory ball joints going to make it? (dealer already replaced 2 of them)
How about steering?
http://www.truckspring.com/suspensio...w-support.aspx
Any help... anyone
This is the plow
http://www.westernplows.com/wp/showroom/wideout
J Sell is offline
post #2 of 5 Old 09-22-2011, 08:52 AM
JackedDak03
JackedDak03's Avatar
Quoted: 1 Post(s)
Hey there, I'll post up because I've been plowing for about 10 years now.
First off - Dealers/plow dealers will tell you what they have to tell you due to liability and GVWR of the vehicles. The plow you are looking at is basically the heaviest plow made (with exception of the Blizzard 8610LP), coming in at around 1000 lbs.
The HEMI weighs a good deal less so it can accept heavier plows and stay under the GVWR for the front axle.
Regardless, yes your truck will hold the plow fine. My buddy/plowing partner has a Fisher XLS (Fisher's version of the Wideout, they are all owned by the same company) on his 02Ext Cab Long Bed Chevy 2500HD which is only rated for a 7'6" straight blade. He's had to do some work to handle the weight but he's been holding it fine for 3 years now.
As for the other parts - You can look into Timbrens which are basically large rubber bump stops that don't affect your ride. A lot of guys I know buy SuperCoils and they say the ride is actually better than stock. Another option is just buying 2" spacers. These all won't help save your suspension at all, they'll just keep the plow higher off the ground while driving.
Lastly - Ball Joints, Wheel bearings/hubs will go much sooner. A good aftermarket ball joint will last longer but the wheel bearings suck on these trucks and go pretty quick. IF you want to do this and have less repairs and save money in the long run, I'd invest in some Carli ball joints, and possibly a free spin hub kit. You'll be into it for about $2500 but you'll save gas with the free spin kit and not have to replace your hubs/ball joints again.
Good luck, there is a lot of money to be made when the snow flies!
BMW X5 & Chevy 2500 HD POS
Gone:
2002 Ford F350 Crew Cab Diesel
1999 Dodge Ram 2500 Quad Cab 4x4 Sport V10
1998.5 Dodge Ram 2500 Quad Cab 4x4 24V Cummins
2004 Dodge Ram 2500 Quad Cab 4x4 HEMI
2003 Dodge Dakota Quad Cab 4x4 4.7
2002 Dodge Ram 1500 Quad Cab 4x4 4.7
2001 Dodge Ram 1500 Quad Cab 4x4 5.9 V8
1999 Dodge Ram 2500 Quad Cab 4x4 5.9 V8
1997 Dodge Ram 1500 RegCab ShortBed Sport 5.9 V8
Past -92 Daytona R/T, 94 3000GT, 91 TransAm, 88 RX7 TII, 89 YJ, 92 Bronco, 88 YJ, 94 F150, 96 Rodeo, 88,89,90,91 5.0 Mustang's, 03 Mustang GT, 04 SRT4
JackedDak03 is offline
post #3 of 5 Old 09-23-2011, 02:05 PM Thread Starter
J Sell
J Sell
free spin hub kit.. would you have a link for that?
I did buy the plow for $6,323 installed and it will be put on next Friday... but the Carli ball joints are going to be ordered soon.. what do you think about the carli leveling kit?
J Sell is offline
post #4 of 5 Old 09-23-2011, 04:29 PM
Josh Brown
Josh Brown's Avatar
Shock mounts were never designed for carrying weight so don't use air shocks.
06 2500 QC SB 4x4 CTD Auto Mineral Gray Big Horn.
295/70/18 Nitto Trail Grapplers on Ultra Predators on stock suspension. A few performance mods.
Josh Brown is offline
post #5 of 5 Old 09-23-2011, 09:58 PM
TwinStick
Freespin kits- http://www.8lugtruckgear.com/Dynatra...-ABS-p233.html
http://www.8lugtruckgear.com/Dynatra...locs-p234.html
BallJoints- http://www.8lugtruckgear.com/Dynatra...odge-p389.html
http://www.8lugtruckgear.com/Carli-E...kage-p551.html
Also, expect accelerated wear on front axle u-joints. If you can't afford the freespin kits, then check this out- http://www.dodgetalk.com/forums/show...03#post3819603
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
    snow plow nam vet willie 2G Dodge RAM - General Talk 1 12-03-2010 06:47 PM
    snow plow nam vet willie 2G Dodge RAM - General Talk 1 11-12-2010 08:31 PM
    Western Pro Plus Commerical Snow Plow for 02-06 2500/3500 cbrumit For Sale - Truck Parts 1 06-16-2008 09:59 PM
    Snow Plow shuencl For Sale - Dodge Trucks 0 09-07-2007 10:11 AM
    shocks w/ Fisher snow plow kgd017 2G Dodge RAM - General Talk 0 07-07-2006 08:38 PM
