transfer case fluid - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 09-12-2011, 08:16 PM Thread Starter
mutineer
transfer case fluid
in my 99 dodge what fluid should I put in my transfer case and how much?
mutineer is offline
post #2 of 9 Old 09-13-2011, 08:50 AM
AC130Ghostrider
AC130Ghostrider's Avatar
ATF+4 (auto trans fluid), fill it to just below the hole that you are pouring it in. I've always filled mine until it runs out, but that's not what the handbook says. It says something along the lines of one half inch below the hole.
2013 Ram 2500 4x4 Crew Cab, 6.7L CTD, 285 BFGs
2006 Ram 1500 4x4 Crew Cab, 5.7L Hemi
2001 Ram 1500 4x4 "Off Road" Sport 5.9L QC, 3" PA BL, 2" TGC level, TGC CAs, BFG 315/70/17, SCT by Hemifever, Hughes plenum, Magnaflow hi flow cat/Y pipe, 1 ton steering
1999 Ram 2500 4x4 QC, 305 Nitto Extreme mud grapplers
AC130Ghostrider is offline
post #3 of 9 Old 09-13-2011, 07:28 PM
Ricker97ram
97 shop manual says Dexron II, Mopar-Mercon, or ATF Plus. It also says that the correct fluid level is to the bottom edge of the fill plug hole. In the transmission be sure to use only ATF +4.
Ricker97ram is offline
post #4 of 9 Old 09-13-2011, 08:28 PM Thread Starter
mutineer
thanks guys
mutineer is offline
post #5 of 9 Old 09-16-2011, 06:33 PM
sportquad
Ok, dumb question. Which is the fill plug? Also on the bottom of the transfer case there is a plug with a spring and a plunger type mechanism. Is this a drain plug and how is the spring and plunger oriented when reinstalling. I removed the plug not expecting a spring to pop out and I'm not sure which way to correctly reinstall.
2000 Ram Sport QC Sb 4x4 5.9L 3.55 gears
Wt.5400 lbs W/O Pilot
Mods: Hypertech ppg III 93 octane setting
Flowmaster American Thunder Cat-back stainless tips
K&N FIPK FastMan 50mm TB
Magnflow cat and headpipes
Best ET:16.63@80.76mph
Best 60ft Time 2.382 sec
sportquad is offline
post #6 of 9 Old 09-16-2011, 07:26 PM Thread Starter
mutineer
I'm not sure about the spring the fill and drain are on the back side of case and have a hex style plug
mutineer is offline
post #7 of 9 Old 09-16-2011, 10:23 PM
Zach571
I'm gonna recommend you invest in a Haynes manual at the very minimum if you're going to continue to maintain your truck yourself.
Zach571
Zach571 is offline
post #8 of 9 Old 09-17-2011, 09:46 AM
sportquad
Mutineer thanks for the headsup. Zach571, always good advice when working on something unfamiliar. But before you pass me off as somebody that doesn't have a clue, I just finished rebuilding the complete tranny and OD unit on my 2000 ram from the groundup complete and it runs perfect. Better than new. Removed it, rebuilt it, and reinstalled by myself, on my back, in the driveway. And yes, I had a brand new repair manual which I consulted often. Was just looking to have a few "simple" questions answered without having to spend $25-$50 on a repair manual. And incidentally, that spring plunger mechanism I asked the question about, I was given the "wrong" orientation to reinstall by the local dealership. If you read my list of mods, all those and more have been done by myself. Don't claim to be a transfer case guru. Again, just looking to have some simple questions answered. Thanks.
post #9 of 9 Old 09-19-2011, 09:29 AM
AC130Ghostrider
On the back of the t case should be two hex bolts. The bottom is the drain and the top is the fill. To fill it, have the bottom one in, and fill it to the top hole.
    transfer case fluid oakey134 2G Dodge Dakota - Drivetrain Talk 2 07-25-2009 11:31 PM
    Transfer Case Fluid Czcrd 2G Dodge RAM - Drivetrain Talk 8 06-02-2009 09:17 AM
    transfer case fluid sel 2G Dodge RAM - General Talk 3 01-02-2009 11:16 PM
    Transfer case fluid? NYH1 3G Dodge RAM - Drivetrain Talk 4 08-10-2008 12:24 AM
    Transfer Case Fluid Josh87 2G Dodge RAM - Drivetrain Talk 3 08-10-2007 01:02 PM
