lifter tick? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 31 Old 09-12-2011, 01:26 PM Thread Starter
WickedQuick
wickedquick
WickedQuick's Avatar
lifter tick?
Is that soft tick tick tick tick i hear when i accelerate lifter tick? If so what excatly is it and how do I fix it? I would search but im at work and cant be on the computer right now and not knowing how to fix it is driving me nuts. THANKS!
2001 RAM 1500 5.9L OFF ROAD. 5" BDS suspension lift. 35x12.5x17 Micky Thompson Baja MTZs.
WickedQuick is offline
post #2 of 31 Old 09-12-2011, 02:21 PM
DODGEPICKUP
DODGEPICKUP's Avatar
Quoted: 2 Post(s)
could be your injectors....engine ping on acceleration....bad pcv valve....could be alot of thing....does it do it cold warm hot, what rpm you hear it most....hear it more going on a flat road or up a grade....could be alot of things......
1999 RAM 1500SPORT QC 4X4 5.9 3.55's grrrr
360 MAGNUM POWER 165,000 MILES DYNOED 230/290 ON 35'S
1.7 CRANE ROLLER ROCKERS
DIY CUT,PORTED,EPOXY FILLED KEGGER/ALUMINUM PLENUM PLATE,53MM THROTTLE BODY
JACOBS PRO STREET CD IGNITION
BOSCH DESIGN 3'S 24LBS VETTE INJECTORS
MOPAR P DOUG THORLEY TRI-Y'S
TAYLOR 8.2 THUNDERVOLT WIRE'S
EBC ROTORS N PADS,RUSSELL SS BRAKE HOSES
MARCH UNDERDRIVE CRANK PULLEY
1 TON X-OVER STEERING
DT PRO-FAB TRAC BAR
HELL BENT STEEL 2IN SPACER/SKJ LCA
WINNDEKAR/DSS STEERING BRACE
DODGEPICKUP is offline
post #3 of 31 Old 09-12-2011, 02:52 PM Thread Starter
WickedQuick
wickedquick
I hear it most from a dead stop. Hot or cold onflat ground. Just started doing itafter plenum fix and 180 stat install
post #4 of 31 Old 09-12-2011, 03:07 PM
DODGEPICKUP
Quoted: 2 Post(s)
directly after you fixed the plenum you did do an oil/filter change or drive a few miles?....coolant all ways gets into the lifter valley down into the pan....pull your oil cap and pcv valve have look for milkshake color oil....still could be your injectors though more so if you replaced the o-rings....some metal pipe to the ear can help you pin point weres the ticking is coming from....
DT PRO-FAB TRAC BAR
post #5 of 31 Old 09-12-2011, 04:37 PM Thread Starter
WickedQuick
wickedquick
good thinking. No after the fix I let her sit for like over 24 hours to make sure the permetex cured. But i honestly cant remember if i have done an oil change since then. and i did not do new o-rings. Maybe ill try a bottle of injector cleaner or seafoam in the tank to see if that helps?
could it be pinging from the 180 stat and not getting up to temp? Could a heavier weight oil help?
post #6 of 31 Old 09-12-2011, 06:57 PM
V-10 GUY
Smile
DON'T USE SEAFOAM. It will screw up your CAT. There is some good info on SEAFOAM from a member that works for an oil company on this board.
REFER to (Cats 02 senors for V-10)
V-10 GUY is offline
post #7 of 31 Old 09-12-2011, 09:37 PM
96magnumram
96magnumram's Avatar
I would try a bottle or two of Berrymans B12 chemtool in the tank...that stuff is REALLY good...if that didnt work, there is nothing wrong withadding a little atf in the oil, and running it a little bit to try and clean it up...then promptly change the oil and filter...
96magnumram is offline
post #8 of 31 Old 09-13-2011, 06:18 PM
2x4
2x4's Avatar
Quoted: 6 Post(s)
I'm not too sure about the "mechanic in a can" products but Lucas does make some good additives. Saved my Camaros engine when the oil pump pickup took a day off at the track one day You really could actually feel it on the internal parts when I tore it down.
Are you sure its not spark knock? Spark knock will sound like a few marbles in a coffee can but only when accelerating. If a shot of premium gas fixes it then thats the problem. Its usually caused by overadvanced timing, poor gas or compression being too hight for the octane used.
Lifter tick is constant "tapping" but usually goes away after the truck is warmed up. Injectors can make a very similiar sound & may come & go without warning. If you gas mileage took a dump I'd be looking at the injectors.
Rod knock is the heavy thud sound that only comes on during acceleration (up a hill). I'm thinking its not that at all, but maybe more of the injector or lifter tick.
I'm not sure if the computer can limit total timing, but it may be worth a look at with the timing light.
Did you try the ole vacuume hose in the ear trick to listen to different areas? Its a old trick but works pretty good for finding a loud injector!
FYI, I'm running a 180* thermostat & have had no new noises (just the same old ones!). I think the worst thing the 180* stat would cause is a rich fuel mixture & little heat on cold days. Temp stays just below 200* all the time according to the factory gauge.
(RIP) 96 Ram 4x4 shortbox, 450K.
2001 Ram 1500 long box 4x4
2x4 is offline
post #9 of 31 Old 09-13-2011, 09:32 PM
V-10 GUY
Smile
Berrysman is another of the old tried & true product. I read a test with injector cleaners & Lucas doen't rate that good. For oil I use Power Punch or Morrey's. For injector cleaning the best I have found is at the dollar stores. Their Octane Booster is also good & ONLY a BUCK.
V-10 GUY is offline
post #10 of 31 Old 09-13-2011, 10:57 PM
96magnumram
Berrymans B12 Chemtool is the only additive/chemical I will use in my truck...I do not use anything in my oil,ever...never have never will. After working for an oil company for the last 12 years, I have realized that oils are blended with the additives the oil company's labs have tested for it to do it's job properly. Addiing to that additive package with other chemicles/additives can throw off the additive package the oil company has built into the oils. IMO, if someone is using an oil that they feel the need to add to it with additives/chemicles, they should probably buy better oil.
post #11 of 31 Old 09-14-2011, 09:25 AM
OldBettsey
OldBettsey's Avatar
where can you find "Berrymans B12 Chemtool"
1998 Ram 1500 5.2L 147K miles
OldBettsey is offline
post #12 of 31 Old 09-14-2011, 12:04 PM
96magnumram
Walmart, autozone, Advance
post #13 of 31 Old 09-14-2011, 04:05 PM
DODGEPICKUP
Quoted: 2 Post(s)
do an oil/filter change asap....run some mopar combustion cleaner through it per the direction on the can....
DT PRO-FAB TRAC BAR
post #14 of 31 Old 09-18-2011, 06:19 PM Thread Starter
WickedQuick
wickedquick
allright thanks guys. Im pretty sure its lifter tick cuz its quite. I can only hear it when im driving next to a building or wall and the sound bounces back in my open window. It does not sound terrible at all, just not quiet like it used to. Can a bad header gasket or crack make a sound like that?
post #15 of 31 Old 09-18-2011, 06:20 PM Thread Starter
WickedQuick
wickedquick
and I agree with not doing a bunch of oil additives. If your buying quality oil you shouldnt need all that extra stuff. Fuel on the other hand is different
post #16 of 31 Old 09-19-2011, 07:42 PM
ClubCab5.9
ClubCab5.9's Avatar
Believe a cracked or leaking header could sound close. It would be louder on a cold start then warmed up i think.
ClubCab5.9 is offline
post #17 of 31 Old 09-20-2011, 02:57 PM
ABF
ABF's Avatar
Yep, a bad header gasket can sound like a lifter tick. Mine did. A Remflex gasket solved the problem.
2001 Ram 5.2
K&N 57-1511-2 CAI
Hemifever SCT
Hedman Hedders 79540
Super 10 Series Flowmaster 8425152 SIDO
ABF is offline
post #18 of 31 Old 09-21-2011, 11:16 AM
CARL2206
CARL2206's Avatar
Hope you changed your oil as Dodgepickup has said even if it is not the reason for the tick it should be done anyways after a plenum repair. Then move on to other possibilities.
CARL2206 is offline
post #19 of 31 Old 09-29-2011, 10:20 PM Thread Starter
WickedQuick
wickedquick
Doing it tomorrow but I'm 90% sure I did it after the repair
post #20 of 31 Old 10-03-2011, 09:33 AM Thread Starter
WickedQuick
wickedquick
changed the oil but noise is still there. ill try to get a video up
    Lifter tick and exhaust manifold jheyde 3G Dodge Dakota General Talk 1 07-12-2010 01:00 AM
    lifter tick jrod102503 1G Dodge Durango Performance Talk 3 01-28-2009 08:51 PM
    Hemi Tick or Lifter? Active 3G Dodge RAM - General Talk 3 01-11-2009 05:13 PM
    Lifter "tick" in 03' 4.7 Ram KCRam 3G Dodge RAM - Drivetrain Talk 1 02-11-2005 01:37 AM
