5th wheel on a 1/2 ton - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 21 Old 09-05-2011, 11:29 AM Thread Starter
JFM-jr
JFM-jr's Avatar
Jayco campers has a line of "HT" (half ton) lite weight fifth wheels out designed for smaller trucks. They are alot lighter than their regular line of fith wheel campers. In fact some of the HT fifth wheels are lighter than some of the bumper pull travel trailers. From all I have read here 5th wheel on a 1/2 ton is not the best idea but im wondering if the weights were the same between a bumper pull travel trailer and a 5th wheel what would be the better option? From reading i see the difference in pin weight vs tongue weight is a few hundred pounds. Any thoughts?
09 Hemi powered Ram QC 2500 Sport
Fuel Boost rims 17x9 +20MM
Nitto Terra Grapplers 305/70/17
OEM 4.56 gears
SuperChips Cortex 3950 (1449666)
JFM-jr is offline
Quote Quick Reply
post #2 of 21 Old 09-05-2011, 11:34 AM
sony224422
sony224422's Avatar
Quoted: 9 Post(s)
i would say, if the pin weight is with-in the weight limits for the payload, i would rather tow a 5th wheel than a bumper pull. They are easier to get into tight spaces (watch your cab corners though!) and they pull easier with less sway. This is coming from my personal experience however
2004 QCSB 2500 hemi with 4.10s Laramie
Back rack with whelen freedom 2 light bar (custom made by me with extras)
Whelen Par 36 aircraft landing lights behind the grill, Whelen par 36 spot lights for reverse lights, Whelen strip lights in the bed (6 in total), Whelen cencom to control everything
In bed tool box with lights and extra battery with isolator and also a solenoid to connect both batteries together if i need to
Color matched grill,
Fox box with 2 diamond d3 12's with Diamond d3 600.1 amp
SRT-10 a pillar with trans temp gauge
Mag-tec trans pan
Superchips 3865 with trans tuning
Nitto trail grapplers
POWER WAGON WINCH SET UP
Alpine ina-w900bt with reverse camera
Alpine type r 2 ways in the doors powered by alpine pdx-f4
steering box brace
sound deading
Big 3 done with 4 gauge
E-fan
POR-15 the frame and under body
Jimmy jammers
sony224422 is offline
post #3 of 21 Old 09-05-2011, 11:51 AM Thread Starter
JFM-jr
JFM-jr's Avatar
Yeah this was just something I was looking to get more info on. I like the idea of still having the reserve cargo in the bed with a bumper pull. I pull my camper on the beach as well and was not sure if putting the weight over the axle would do better in the sand.
OEM 4.56 gears
JFM-jr is offline
post #4 of 21 Old 09-05-2011, 03:37 PM
Ram3500Dually
Ram3500Dually's Avatar
Quoted: 38 Post(s)
Weight over the axle is better then weight behind the axle. If its designed for a 1500 they are fine. I have two friends that pull light weights behind their half ton trucks.
2013 Ram 3500 CTD 6.7L 6 Speed Aisin, 4:10 LSD
2005 Jeep Liberty Sport
1991 Shadow ES Turbo Convertible
1984 Mini-Ram Van (Show Van) **TOTM April 2007** In museum now
73 Pro Street Duster.**VOTM July 2008/ April 2011**
1951 Dodge 3 Window Business Coupe **VOTM Feb 2011**
1992 Custom Built Harley FXSTC Show Bike
2008 Harley FLHTCU Ultra Classic
DodgeTalk Administrator
Names Carl, if you cut me I bleed Mopar Blue
Past Trucks: 90 CC Dually CTD, 94 RC LB CTD, 95 CC SB 5.2L gas, 98 QC Dually CTD, 00 QC Dually CTD, 01 QC Off Road, 03 QC Dually CTD, 05 QC Dually CTD, 08 Dually CTD **ROTM April 2008**,10 CC Dually CTD,
Ram3500Dually is offline
post #5 of 21 Old 09-05-2011, 08:04 PM Thread Starter
JFM-jr
JFM-jr's Avatar
Yeah i'm gonna start poking around soon and just wanted an honest opinion on these light weights. I already know the salesman will try and tell me my truck will pull anything on his lot lol.
OEM 4.56 gears
JFM-jr is offline
post #6 of 21 Old 09-05-2011, 08:12 PM
Ram3500Dually
Quoted: 38 Post(s)
Ya, be careful with salesmen. A trailer salesman told my brother his 2008 1500 would pull an 11K 5th wheel with a pin weight of 1500 pounds LOL
post #7 of 21 Old 11-04-2011, 05:55 PM
MADBRAD
MADBRAD
MADBRAD's Avatar
Yah the 5th wheel setup rides so much better than the bumper pull setup. Having the weight over the wheels/springs preloads the suspension and it rides smooth as compared to the load behind the wheels bouncing around all the time.
MADBRAD
2006 Ram 1500 SLT 4x4 Regular cab short bed/ MDS HEMI
steel 17s painted black /265 70 17 BFG Rugged Terrain tires/3.55 LSD
tow hooks /front suspension skid plate
3" cat back Flowmaster original 40
dechromed/debadged
black grille/black bumpers
Truxedo Truxsport
Belltech drop shackles
personalized "MADBRAD" license plates
MADBRAD is offline
post #8 of 21 Old 11-05-2011, 09:31 AM
reynoldsfamily3
Check out the "sliding hitch" I am sure there is a better name for it. It allows the king pin to slide when you turn so you don't take out the cab corners with the short bed.
2006- 1500 Quad Cab 4x4, 5.7 Hemi, Vararam intake, 4.56 gears, Firestone airbags, on board air, Leer Cap
2007- 3500 Mega Cab 4x4, 5.9 CTD
reynoldsfamily3 is offline
post #9 of 21 Old 11-07-2011, 08:07 AM
mlobitz
Fathead
mlobitz's Avatar
While I agree that the 5th wheel setup is ideal, a properly set up trailer will tow just fine without bouncing and swaying. I have a 28' TT that I tow and it does not sway or bounce (at least not anymore than the truck would w/o the load). Proper equipment and vehicle set up goes a long way when towing...
Mike
2004 Dodge Ram QC 4X4 Hemi
mlobitz is offline
post #10 of 21 Old 11-07-2011, 01:03 PM
Big Thirsty
Big Thirsty's Avatar
Quoted: 1 Post(s)
Looks like those Jayco weights are from 1100 to a little over 1300. Your factory payload is 1393lbs. http://dodgeram.info/2004/load-tow/1500.html
You will exceed that rapidly. Your bedroom and all your storage is in the front of the RV along with whatever else you put in the truck and trailer. I would look at a bumper-pull with a WD hitch for what you are describing.
2004 Dodge 2500 4x4 gasser.
Big Thirsty is offline
post #11 of 21 Old 11-13-2011, 10:20 AM
V2Rider
V2Rider's Avatar
Quoted: 10 Post(s)
IMO I wouldn't be pulling anything that requires a 5th wheel with a 1/2 ton anyway, IMO. It's like the 1/2 ton with a plow on it debate. If so, I would be seriously upgrading the rear suspension, and maybe the rear axle with a bigger differential, along with gears.
Previous:2003 Ram 2500 HD 4X4, Sold but not forgotten
Current: 2015 Dodge Ram 1500 Laramie CC Black on Black, FULLY loaded
AMSOIL
V2Rider is offline
post #12 of 21 Old 11-16-2011, 04:56 PM
NYH1
NYH1's Avatar
Quoted: 1 Post(s)
Load any extra's in the rear of the trailer. That will take weight off the rear of the truck. I see 100's of half ton Ford, Chevy/GMC, Dodge and Toyota trucks towing small 5th wheel trailers every spring, summer and fall going up and down Interstate 81 and the NYS Thru-Way (Interstate 90) to and from the Thousand Islands, Adirondacks, Tug Hill and Canada.
"GO GIANTS" "ROLL TIDE" "YANKEES"
2015 Ram 2500 Reg. Cab. Tradesman, 6.4L Hemi, auto, 4x4, 4.10's w/anti-spin rear, tow/5th wh/goose pkg. Snow Chief pkg. LT275/70R18/E tires. Fisher 8.5' SS Xtreme V Plow. Work truck...plow in winter, tow mowing equip. in summer!
2007 Ram 1500 Quad Cab Short Box SLT ThunderRoad, 5.7L Hemi, auto, 4x4, 3:92's w/anti-spin rear, tow Pkg. LT285/70-17 Goodyear Wrangler DuraTrac Tires, Fisher SD 7.5' Snowplow. Trucks in great shape, daily driver, back up work truck!
NYH1 is offline
post #13 of 21 Old 02-08-2012, 09:04 PM
chaneyjd
chaneyjd's Avatar
I have a 23 ft bumper pull and my 2500 dosen't even know it is back there.
2004 2500 QC CTD 234K
Diablo Tuner
chaneyjd is offline
post #14 of 21 Old 02-10-2012, 03:48 AM
wyat72
PAID OFF!!!
wyat72's Avatar
Quoted: 20 Post(s)
I see it about daily, some farmer pulling some fifth wheel or goose neck with there 1/2ers. Just get one that isn't going to overload your truck and you will be fine.
Truck: 08, Ram, 1500, HEMI, QuadCab, Big Horn, 4x4, Inferno Red, Chrome Grill, Chrome Molding, Chrome 20s
Appearance Mods: Chrome Mopar Tubular Side Steps, Chrome Mopar Bug Guard, Mopar Tow Mirrors, Mopar Mud Flaps & Wheel Liners, Mopar Tow Hooks, Putco Chrome Door Handle Covers, AMI Chrome Fuel Door, Curt Customized Hitch Cover, Bully Locking Tailgate Handle, ACI Vanish Tonneau, Line-X Bed Liner, Autospring 2" Leveling Kit, Cooper Zeon LTZs.
Performance Mods: SuperChips FlashPaq, Volant CAI, 12589 Magnaflow Muffler and Y-Pipe.
Red Truck Club Member #289
wyat72 is offline
post #15 of 21 Old 02-10-2012, 07:15 AM
wixthedog
That guy
wixthedog's Avatar
Quoted: 36 Post(s)
Just because you see it happen does not make it right. Know your weights and follow them. Don't treat a half ton like a 3/4 ton.
Mike AKA: WixTheDog
2015 Dodge 1500 Crew Cab Laramie - 4x4- Deep Cherry Red
Stock...
2014 Dodge Durango R/T - 2WD - Redline2
Stock soccer mom car
2014 Mega 2500 = 2014 Crew Cab 3500 = 2013 Crew Cab 3500 = 2007 Quad Cab 2500 = 2003 Quad Cab 1500
wixthedog is offline
post #16 of 21 Old 02-10-2012, 01:18 PM
wyat72
PAID OFF!!!
wyat72's Avatar
Quoted: 20 Post(s)
I guess you didn't read the part where I told him don't over load his truck. They do make fifthwheels that are within the 1/2ers specs.
wyat72 is offline
post #17 of 21 Old 02-14-2012, 11:13 AM
VINCH
VINCH's Avatar
Quoted: 14 Post(s)
1500 + 5th wheel = DISASTER !!!!
Red Neck White Hair Blue Collar
2012 Ram Crew Cab 3500 6.7 H.O. CTD 4x4 SRW
285/75/17 Toyo Open Country Xtreme ATII
VINCH is offline
post #18 of 21 Old 02-15-2012, 09:29 AM
rpounds
rpounds's Avatar
You're going to have to prove that statement to me. As has been mentioned several times already, there ARE 1/2 ton towable 5th wheels. They've been around for a long time. For a while back in the 80's, they were making 5er's for mid-size trucks like the Ford Ranger and the Chevy S-10. They weren't the fastest thing on the road, but the combination worked well for those who chose them.
As always, one has to do the math. Know your GVWR, your GCWR, your payload capacities as well as the pin weight. If possible, get the trailer and the pin weighed so you know how much everything really is. Even better is to load the trailer for a trip and then weigh it. You'll sometimes be surprised how much 'stuff' you end up sticking in there. Know how much you and your passengers weigh. Factor in a full fuel tank. Factor in a full water tank (in the RV). Upgrade the truck tires to at least D range. Properly equipped, a half ton can safely pull carefully selected 5er's.
Oh . . . and as also was mentioned, don't believe anything that the RV salesman says. Ignore him completely, take a calculator and notebook with you and run the numbers yourself.
'05 2500 Quad Cab, CTD, 4x4, 48RE, Mineral Gray, "The Bus"
'12 Challenger R/T
Recovering Gasoline Addict
What do you like most about my truck? The noise or the smell?
rpounds is offline
post #19 of 21 Old 02-15-2012, 11:00 AM
VINCH
VINCH's Avatar
Quoted: 14 Post(s)
most 5ers are way over weight for our little 1500s
never said that there are not some out there that we can handle
just MOST are way over our limit
if you like pushing the envelope to the edge go for it just dont be surprised when you go over the edge LOL
I live in California and regularly drive my truck and TT in the high Sierra's
if you drive a 1500 and pull a 5er I wish you the best
yes most 5ers that we can tow were produced in the 80's sorry I will not tow 20-30 yr old trailer just asking for trouble
its ok to disagree we do live in America where we have the Freedom of choice just letting you know how I feel
VINCH is offline
post #20 of 21 Old 02-15-2012, 12:20 PM
rpounds
rpounds's Avatar
Yes, most are over the limits of a half ton truck. The example of 5er's from the eighties was for example only - to point out that your simple statement of 1500 + 5th wheel = DISASTER is ludicrous. There ARE 1/2 ton towable 5er's. They are a select few yes, but they are out there if you do your homework. Overloading ANY truck is stupid and I don't see anyone here advocating that. However, the OP is asking a fairly common question and instead of simply yelling NO!, we have given him actual information that hopefully will help him make an informed purchase. So if you're going to make a statement like that, be prepared to back it up with actual data.
'12 Challenger R/T
rpounds is offline
    Go Rhino Dominator III Wheel to Wheel Nerf Bars - Dodge Ram 3rd Gen RynoMight For Sale - Truck Parts 2 09-15-2010 03:29 AM
    Help! Chrome Wheel Cover Torn Off Wheel During Tire Change! '06 Ram 1500 Quad Cab 4x4 ScoutNHunt 3G Dodge RAM - Tire and Wheel Talk 11 04-25-2010 12:10 PM
    Chrysler Recalls Rear-Wheel-Drive Cars For Front-Wheel Issue RAM MAN Rumor Mill & Gossip Talk 0 11-04-2009 05:24 PM
    Interesting wheel failure (Jeep wheel, not PW wheel) LKelly 3G Ram Power Wagon Talk 7 09-23-2009 11:13 AM
    Westin Wheel to Wheel CHROME STAINLESS Step Bars Foxracing2321 For Sale - Truck Parts 0 01-02-2008 04:21 PM
