Squeaking When Backing Up - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 08-25-2011, 03:51 PM Thread Starter
garywkamp
garywkamp's Avatar
I get a noise that sounds like squeak, squeak, squeak, squeak, It does it ONLY when backing up and does it wether or not I push on the breaks. Could it be U-joints? The truck has like 98,000 on it dont know if they have ever been replaced.
2002 Dodge Ram 1500 4.7 Magnum Automatic Trans 4X4 94,000 Miles
Mods and Work Done
Bully Dog Chrome Locking Gas Door, 20% Tint All Around, Sony Detachable Bluetooth Head Unit, "Gutter Grill", New Front Rotors and Pads, K&N Drop in Air Filter, Synthetic Oil Change, New Primewell Tires Factory Size, Diamond Plate Delta Toolbox, Debadged, Hellas 500FF Behind "Gutter Grill", Homemade "Power Wire".
Mods and Work Need Done
Level Truck, Fix The All Popular Crack Dash Syndrome, Better Front Shocks, New Right Front Wheel Bearing
garywkamp is offline
post #2 of 3 Old 08-25-2011, 04:55 PM
Stevie
Hmmm..could be U joints...could be a brake caliper dragging a bit.
I've had U joints that were not just out-out and loose...but made squeaking noises. Took the drive shaft down and the joints were about locked up. Changed them out and the rollers were all there..but full of rust too.
Maybe jack the truck up and put the trans in neutral and get underneath and turn things backwards and forewards to see if it's U joints or a hung up caliper?
Stevie is offline
post #3 of 3 Old 08-29-2011, 09:58 AM Thread Starter
garywkamp
garywkamp's Avatar
Just so everyone knows. I replaced the U-Joints this weekend and that solved my sqeuking problems. And also if yours is like mine the bolts had locktite on them. I figured out if you heat the bolt up with a torch they come out alot easier. It wasnt that hard and worth the time to have greaseable u-joints.
Mods and Work Done
    Noise while backing up.... hemi operator 3G Dodge RAM - Drivetrain Talk 9 05-23-2006 11:15 AM
    Clunk when backing up kent0 2G Dodge RAM - 4X4 Talk 4 04-02-2006 07:52 PM
    backing up. 2002durango1960 1G Dodge Durango General Talk 1 07-24-2005 05:26 PM
    Lights for Backing-UP rmcqcc 3G Dodge RAM - General Talk 20 01-31-2005 10:18 PM
    Backing lights thBriGuy 1G Dodge Durango - Drivetrain Talk 1 12-17-2004 12:08 AM
