What can cause my headlights to Flicker? 08 Ram - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 08-24-2011, 06:55 PM Thread Starter
jorben1990
jorben1990's Avatar
My headlights flicker at night (duh) and its very annoying, i have a viper 5901 and thats the only thing that i would think interferes with the headlights but i could be wrong. Would the multi-function switch be at fault? When i try to put on the high-beams they will pop up but go back to regular while on high-beam, any suggestions would be appreciated!
jorben1990 is offline
post #2 of 11 Old 08-24-2011, 06:56 PM Thread Starter
jorben1990
jorben1990's Avatar
And they flicker at the same time by the way!
post #3 of 11 Old 08-24-2011, 08:30 PM
Bell_TRX4_2008
Bell_TRX4_2008's Avatar
Possible blown fuse? Check all your fuses as I've seen in other vehicles have flickering lights and it was cause by a blown fuse
Black Truck Club #205
2008 Ram 1500 TRX4 5.7L
No mods yet
2000 Grand Cherokee 4.7L
K&N FIPk, 32 Trxus M/T, 2 inch lift
2009 Ski-Doo 1200 XR
2000 Ski-Doo 788 Summit X 155
Bell_TRX4_2008 is offline
post #4 of 11 Old 08-24-2011, 11:28 PM Thread Starter
jorben1990
jorben1990's Avatar
i will check it out bro, i doubt its a fuse but i did ask for suggestions so im going to check!
post #5 of 11 Old 08-24-2011, 11:32 PM
btg0002
War Eagle!
btg0002's Avatar
Quoted: 13 Post(s)
you are using halogens correct? only time I have seen flickering lights on these trucks was from poor HID installs
TRUCK: 2007 RC/SB 1500 ST with the 3.7 v6
PERFORMANCE: l jba shortie headers l hypertech max power programmer l Jet 180 tstat l e3 spark plugs l K&N CAI l magnaflow cat back dual exhaust l fastman ported TB l RP engine oil and rear diff fluid l bluetooth ODBII adapter for Torque app l
SUSPENSION: l 3 inch lift spindles l 2 inch coil spacer l bilstein 4600 shocks front l monroe load leveling shocks rear l TGC 1.5" rear lift blocks l 5" total lift front, 2.5" total lift rear l
APPEARANCE: l rhino lined bed l tonnomax tri fold bed cover l bed lined fender flares, rockers, bumpers l big mouth rivet grille l led tail lights l lamin-x tails and 3rd l led everything l HID heads and fogs l HID reverse lights l led reverse flood lights l debadged l hood spears l tinted windows l audio system l black headlights l black billet 15" stubby antenna l daytona tail light covers l
WHEELS/TIRES:l 285/70/17 Nitto Terra Grappler l OEM 17s plastidipped black l
btg0002 is offline
post #6 of 11 Old 08-24-2011, 11:33 PM Thread Starter
jorben1990
jorben1990's Avatar
I just checked the manual , which fuse would control the headlights?
https://pictures.dealer.com/tomahlch...4288275446.pdf
post #7 of 11 Old 08-24-2011, 11:34 PM Thread Starter
jorben1990
jorben1990's Avatar
Pardon my ignorance, but if by halogens you mean the ones that came with our dodges then yes, i am a halogen user and abuser.
post #8 of 11 Old 08-25-2011, 06:00 AM
ricer2231
ricer
ricer2231's Avatar
When I first got my truck, 2006 1500 QC SLT 4x4, I had a similar problem. My headlights didn't really flicker just when I would ty to switch from low beam to high beam they would switch to high beam and then right back to low beam, just would not stay on high beam. Came to find out the multi-function switch was bad. Replaced the switch and everything has been fine since.
2" Springbender leveling kit, DIY CAI with drop-in K&N Filter, SC 3865 w/ advanced tranny tune(thanks SilsHemi), Magnaflow Y-Pipe, Magnaflow 11259 Muffler, Westin SS Nerf Bars, Hella 500ff's behind the grill, VHT tinted and buffed tails, blacked out badges and grill.
ricer2231 is offline
post #9 of 11 Old 08-25-2011, 02:54 PM Thread Starter
jorben1990
jorben1990's Avatar
That's what I'm aiming for also, did you change it yourself? Is it time consuming? Looks easy but god knows I'm not the handiest dude around
post #10 of 11 Old 08-25-2011, 03:09 PM
HEMIBOSS11
HEMIBOSS11
HEMIBOSS11's Avatar
I would agree that it sounds like cheap HID headlights.. I would first check your headlamp relay, which is located under the hood in the fuse panel. I would try switching the relay with another one of your similar relays (perhaps a windshield wiper relay if it is the same) If that doesn't fix it I would check out the multi-function switch
-Ty
HEMIBOSS11 is offline
post #11 of 11 Old 08-25-2011, 04:27 PM
ricer2231
ricer
ricer2231's Avatar
No, I took mine to the dealership and had it changed. You have to pull the steering wheel and I just didn't have the confidence to do that with the airbag and all. I think the switch was like $80.00 and like $90.00 to have it installed.
    HID Flicker.... Big Boi 3G Dodge RAM - General Talk 8 03-27-2011 08:52 AM
    Headlights and Dash Lights flicker when driving??? kjsbomb Dodge Neon - General Talk 0 06-02-2008 07:30 PM
    HID Flicker mattstoy 3G Dodge RAM - Interior/Exterior Talk 45 11-01-2007 11:20 PM
    HID Flicker mattstoy 3G Dodge RAM - General Talk 2 02-20-2007 11:46 PM
    2003 GC headlights flicker fyrewalker Dodge Caravan General Talk 2 10-21-2006 10:54 AM
