Need help with rear axle: 1500 with 4.10's - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 23 Old 08-06-2011, 04:27 PM Thread Starter
GNCC Racer 520
Mount Hope, NJ
GNCC Racer 520's Avatar
Hope I posted this in the right place haha. I'm looking to rebuild/swap my rear end in my 2001 1500 4x4... Not looking to change the ratio, I just need help finding a rear end or rebuild kit for the Chrysler 9.25 with 4.10's. I've been searching craigslist and calling junk yards around the Tri-state area (I live in Jersey) and I haven't found anything besides rebuilt rears for around $1400. I was hoping someone on here could point me in the right direction or chime in with some advice or other options. I thought I found a junk yard rear for around $750 shipped from FL but the guys never got back to me and I can't seem to get a hold of them any more. I'm willing to drive a few hours or pay for shipping if need be.
Thanks,
Steve
GNCC Racer 520 is offline
post #2 of 23 Old 08-06-2011, 06:30 PM
OleTomCat
Bridal Veil Falls
OleTomCat's Avatar
Quoted: 1 Post(s)
Steve,
Welcome to Dodge Talk, can't really help with your problem but someone who can will be along shortly I am sure, may need to move this to the 4x4 section those guys are hard core about their rears....
I am originally from South Jersey myself, moved further south curtesy of Uncle Sam, and won't go back either....
Good luck.
Al..
My name is Al from Summerville, SC and I am a
Me: '14 Ram 1500 EcoDiesel
'01 Ram 1500 5.2L Sport
Rhino Liner, Pioneer sound, new ball joints
I am not just a member I am the President
Wife: '05 Durango 4.7L
OleTomCat is offline
post #3 of 23 Old 08-06-2011, 09:37 PM
Zach571
If you've never rebuilt a rear end then you'll have to find someone who has or bring it to a shop. Since you'll have to be doing that let them track down the rebuild kit (not that its hard, but they know where to look).
www.ringpinion.com
www.drivetrainspecialists.com
Whats wrong with it that you are even considering replaced the WHOLE houseing/axle??
Zach571
Zach571 is offline
post #4 of 23 Old 08-06-2011, 09:55 PM
dodgefan360
Platinum 2K R/T
dodgefan360's Avatar
Quoted: 1 Post(s)
Thanks,
Steve
Have you checked Ebay? You can also contact the boys at either Yukon Gear or Randy's Ring and Pinion, both are great and have knowledgeable staff that can if anything, point you in the correct direction.
2011 RAM Quad Cab 4x4 SXT - Silver
63,000kms
2000 5.9 R/T - Platinum - SOLD - 18 DEC 2014
155,000m (251,000kms)
Amsoil in the diffs, transfer case and engine - Hughes Plenum - Fastman 52mm TB - K&N FIPK - SCT tuner currently set at 87 octane - Magnaflow 15659 exhaust
dodgefan360 is offline
post #5 of 23 Old 08-07-2011, 08:24 AM
Moparite
Moparite's Avatar
Quoted: 313 Post(s)
What is wrong with the rear you have? I Also live in Jersey and there was ram in a junk yard not to far from me. It was a few years age so idk if it is still there.
Moparite is offline
post #6 of 23 Old 08-07-2011, 12:37 PM Thread Starter
GNCC Racer 520
Mount Hope, NJ
The truck has about 190k miles on it. Most are from highway and towing my trailers to atv races. After driving on the highway for a while, the rear end would begin to bind as soon as you came to a stop and started to accelerate. I came home from my campus a few weeks ago and noticed diff fluid all over the back side of my truck. My father and I pulled the diff cover and played with it for a while and we decided to just go for a junk yard rear. The truck just has to get me through 1 more year of college commuting so I can't really justify spending $1500 on a rear..
I have the whole rear end dropped right now in our shop. We have every tool in the book and I'm sure that between my father and I, we could rebuild the rear. He's been rebuilding cars and trucks since he was my age. We just thought it would be easier to take axle off and throw a junk yard rear in. Unfortunately, I can't find anyone with 4.10's. Did dodge have a thing against putting 4.10's in 1500's? Haha.
Thanks so far, guys.
PS. I check craigslist and Ebay religiously haha.
post #7 of 23 Old 08-07-2011, 12:40 PM
OleTomCat
Bridal Veil Falls
OleTomCat's Avatar
Quoted: 1 Post(s)
I don't think the 4:10 is a stock thing, may have been special ordered that way......
You can take your VIN to the dealership and get the build sheet for the truck that will tell you if it is stock or an upgrade or added after the truck was sold....
post #8 of 23 Old 08-07-2011, 02:08 PM
Zach571
I don't mean to be a dick but from what you've posted i would strongly recommend you find someone who has rebuilt a rearend to do it for you. "played with it for awhile and decided to go the junk yard route"...sounds like you don't even know what the actual problem is
Zach571
Zach571 is offline
post #9 of 23 Old 08-07-2011, 02:13 PM
dodgefan360
Platinum 2K R/T
Quoted: 1 Post(s)
Rear's aren't easy to do the first time without someone who knows what they're doing. You'll need to measure the preload and make sure the ring gear meshes with the pinion nearly exact. If you get a used axle, do change the fluid in it, and then change it again after 1000 miles!
63,000kms
post #10 of 23 Old 08-07-2011, 02:24 PM
Zach571
I would also recommend pulling the axle shafts and taking a peek at the wheel bearings, best to find out then if they are junk already. Sucks you can't just pull the carrier on those and look at the carrier bearings too, most rearends use shims, these don't so I doubt you have the tools to set the backlash for this rearend.
Zach571
Zach571 is offline
post #11 of 23 Old 08-07-2011, 06:32 PM Thread Starter
GNCC Racer 520
Mount Hope, NJ
Zach571
It's cool dude. This is my first time diving into a diff so I'm just in it to learn. Before we even took it apart, my father made the decision to go for a junk yard rear since it would be the easiest route (or so we thought). I pretty much took the entire rear apart just to try and understand and learn everything. Unfortunately, it's hard to learn about car mechanics when you're studying your ass off for summer college credits haha.
The truck needs to get back on the road soon since my fall semester starts Sept 1st so if I can't find a junk yard rear before then, I'll have to opt out for a rebuilt/new rear.
post #12 of 23 Old 08-07-2011, 06:52 PM
Zach571
I can't help you out locally but hit up local 4x4 shops (im sure those are scarce around there...) and next best place would be places that specialize in suspensions (like making leaf springs and driveshafts, they can recommend places too). Any auto shop can rebuild the rearend but its best to find someone who is KNOWN for it.
Another option is hit up on your local 4x4 forum or club, they WILL know someone who will set up the gears for ya, and since you have it that makes it all the easier, you can just drop it off...
Around here I could get it done for under $900 for sure, but thats just including the rebuild kit, not a set of gears if that is needed, which can be had for around $200 a set, look at those links I put up earlier and check those prices with whatever your local find charges you for parts
Zach571
Zach571 is offline
post #13 of 23 Old 08-07-2011, 10:54 PM
spun360
spun360's Avatar
Quoted: 153 Post(s)
4:10s are a rare beast. most people that have them wount give them up. they were equiped in the off road models. a specialty. if they ever hit the J-yards, it would only be for a minute.
parts for sale
ask about my treadwright retread experience
$150: 210lb double and dampener valve springs .550 lift
$pay shipping: new, dana/ spicer (1)greasable upper & (1)lower ball joint for dana 44
$pay shipping: new, standard oil pump
$pay shipping: new, super strength moog #377 frt axle hub universal w/ grease fitting
prices (for residence of the US)
cheep
shoot PMs my way
spun360 is offline
post #14 of 23 Old 08-16-2011, 10:21 AM Thread Starter
GNCC Racer 520
Mount Hope, NJ
Thanks for all the help so far, guys. After spending countless hours calling junkyards and searching the internet, we decided to throw in the towel. We're calling all the local shops today in hopes of finding a rear assembly for less than $1400.
-Steve
post #15 of 23 Old 08-17-2011, 06:20 PM
Lee Peterson
Lee Peterson's Avatar
Quoted: 4 Post(s)
I found a few.
Flushing Auto Salvage USA-NY Corona 1-718-672-0700 They want $750 stock #24880
Heres a few more not sure how close you are to these.
Auto Recycling Inc USA-PA(Coplay) 1-610-799-3234 $800
New Castle Auto Wrecking, Inc. USA-PA(New-Castle) 1-800-245-2226 $1200 86,000M
2002 Dodge Ram 1500 4x4.
360 Magnum
Hughes FI Air Gap
52mm BBK TB
210/220 .512I.512E 110 LSA cam
MSD 6A , Blaster 2 Coil
Spintech muffler
SCT tuned by FlyinRyan
Trucks & Guns Club Member #88
Lee Peterson is offline
post #16 of 23 Old 08-18-2011, 10:10 AM Thread Starter
GNCC Racer 520
Mount Hope, NJ
Originally Posted by Lee Peterson View Post
I found a few.
Figures!! I bit the bullet two days ago and bought a rebuilt rear end from M&R Motors in Walnutport, PA for $1300. She's all back together and running great. Now if I could only find a set of 34"-35"s to throw underneath it for cheap, I'd be in business haha.
One quick question - I took her out yesterday for a local drive. Everything seems fine except for a slight grinding noise which seems to be coming from the rear end. I think it sounds like the brake shoes rubbing up against the drum, but the noise tends to go away whenever I make left turns. Could it be something else like the gear oil hasn't traveled the length of the axles yet and lubed everything? Maybe I adjusted the drum brakes a little too tight?
Thanks again for everything, guys.
post #17 of 23 Old 08-18-2011, 03:04 PM
AC130Ghostrider
AC130Ghostrider's Avatar
Add some MOPAR limited slip additive and see if it goes away. One bottle (they're small) should do it.
2013 Ram 2500 4x4 Crew Cab, 6.7L CTD, 285 BFGs
2006 Ram 1500 4x4 Crew Cab, 5.7L Hemi
2001 Ram 1500 4x4 "Off Road" Sport 5.9L QC, 3" PA BL, 2" TGC level, TGC CAs, BFG 315/70/17, SCT by Hemifever, Hughes plenum, Magnaflow hi flow cat/Y pipe, 1 ton steering
1999 Ram 2500 4x4 QC, 305 Nitto Extreme mud grapplers
AC130Ghostrider is offline
post #18 of 23 Old 08-18-2011, 11:44 PM Thread Starter
GNCC Racer 520
Mount Hope, NJ
I added a limited slip/posi additive that I picked up from Napa. Took her on the highway today and I get a small shaking from 40-60mph. Goes away if I go faster. Gears breaking in?
post #19 of 23 Old 08-19-2011, 05:39 AM
Zach571
NO, gears will not cause a shake. Possible that the pinion is bent or not true enough to be vibration free, not much else with the rearend that would cause a vibration. Did you rotate your tires while they were off or are they back where they were before the swap?? I've had a slipped belt on one of my tires and didn't feel a shake if it was on the front, but in the rear she'd shake like a crack whore in rehab.
Zach571
Zach571 is offline
post #20 of 23 Old 08-19-2011, 10:22 AM Thread Starter
GNCC Racer 520
Mount Hope, NJ
Yep, I did. Gonna check it out today. If it's not one thing, it's another. Lol.
At least this gives me a reason to look for some 35's haha.
    Rear axle fitment for 08 Ram 1500 defa0009 3G Dodge Ram Performance Talk 1 12-23-2008 01:30 PM
    Anti-Spin Rear Axle, 08 1500 4.7 Ram? KARAM0182 3G Dodge RAM - Drivetrain Talk 9 12-20-2008 10:20 AM
    Ram 1500 Rear Axle Housing 9.25 Suspman For Sale - Truck Parts 0 01-04-2007 10:31 PM
    Ram Rear Axle Housing 9.25 2003 1500 Suspman For Sale - Truck Parts 0 01-04-2007 12:29 PM
    3rg gen 1500 rear axle Big Joe SS/T 2G Dodge RAM - Drivetrain Talk 0 10-25-2006 12:09 AM
