Broken Recirculation Door - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 07-31-2011, 11:22 PM Thread Starter
340dartswinger
340dartswinger's Avatar
Quoted: 12 Post(s)
Moved my ac from fresh air to recirculate today and heard a loud snap from the passenger side and realized I had almost no air coming through the vents. I pulled the blower motor out and found the door resting on the blower motor blocking all air flow. So I pulled the broken door out and now I have full air moving through the vents, but with the door missing I'm getting all the hot air from outside and the air isnt getting as cold as it was when I was able to recirculate it.
After I did a quick google search I found some people have been able to replace the door by pulling out the glove box. They make it sound somewhat easy-Have any of you guys done this? Is it pretty easy? What issues will I run into if I just duct tape off the fresh air inlet inside the air box so I am permanenty on recirculate?
Thanks
2012 Ram Big Horn Crew Cab
Hemi 6spd Auto
Superchips 3842, Truxedo Lo Pro Tonneau, Tinted windows, 100w 20" LED Lightbar in Front Bumper,
2 18w LED Rear Lights, LED Tailgate Lightbar, In-Channel Vent Visors, Cooper Zeon LTZ's, BedRug Bedmat
1969 Dodge Dart Swinger
360- Edelbrock RPM Heads and Cam, Holley intake and Carb, Harland Sharp Roller Rockers, TTI Headers, Full MSD Ignition.
727 Manual reverse pattern trans, 2800 Stall converter.
8 3/4 Auburn posi 3.73's.
Fiberglass Hood and Bumpers, 10pt cage and Dodge Neon bucket seats.
340dartswinger is offline
post #2 of 10 Old 08-01-2011, 12:14 AM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 250 Post(s)
See if this helps you out ...
http://www.dodgetalk.com/forums/showthread.php?t=259714
dmcelhannon is offline
post #3 of 10 Old 08-01-2011, 04:34 PM
steev0
steev0's Avatar
Happened to me. gotta take off the glove box and such then take the little motor off for the broken door then pull out this white pin in there that holds the door in (where it should be if it wasnt broken) i went to the dealer and said it was broken and they sold me a whole new unit for like 50 bucks, all i used was the door off of it tho. stuck the door up through the blower motor hole, stuck that white pin back through when i had the door in the correct position then put the little motor back on and put every thing back together. all together it took me about 45 minutes to do it and that is wihtout ever doing something like that before.
04 ram 2500 QC ST 4X4 HEMI
Exterior/Suspension:
5in procomp lift, Carli Adjustable Track Bar, Pure Performance Sway Bar End Links, Bilstein Gas Shocks, 08.5 Steering Upgrade, Moog Ball Joints, 20in Chrome Xd Rockstars on 37/13.5/20 Nitto Mud Grapplers, Color Matched Bushwacker Pocket Style Flares, Carr Hoop Steps, Westin Bull Bar, Cheap Chrome Handle Covers, Recon Clear Cab Lights, 8000k H.I.D. with Recon Projector Headlights, Drilled and Slotted Rotors, Recon L.E.D. tail lights
Performance:
Superchips Cortex, Airraid Intake, Magnaflow Muffler, DMH 3in Exhaust cutout, Soon to be 4.56 gears front and rear
Interior:
Doubledin Radio Bezel with Pioneer 4300dvd touchscreen headunit, 2 Jl12w6 subs powered by Hifonics 2000Watt Amp, 0 Gauge Wire Upgrade from alternator to battery and all grounds, Power locks and Windows (finally)
steev0 is offline
post #4 of 10 Old 08-01-2011, 04:40 PM
HEMISith
HEMISith's Avatar
www.heatertreater.net
2004 Dodge Ram 1500 4X4 QC 5.7L 345 HEMI
GONE!
HEMISith is offline
post #5 of 10 Old 08-01-2011, 04:44 PM Thread Starter
340dartswinger
Quoted: 12 Post(s)
Thanks for the link dmcelhannon, that gives me some good pics.
SteevO, thats what I was hoping to hear. It only took me about 10 min to pull the broke door out, now I just need to go get the new one. How did you make sure the motor/door were in the right position? I noticed that the motor with no door spins 360, I don't want to install the new door and have the motor break it right way because I didn't have it timed right.
Thanks!
Hemi 6spd Auto
post #6 of 10 Old 08-01-2011, 05:41 PM
steev0
steev0's Avatar
honestly i really dont know how i got it right i guess i was lucky haha. i kind of just put it in and its been in for well over a year now and has been fine since then
Performance:
Interior:
steev0 is offline
post #7 of 10 Old 08-01-2011, 06:00 PM Thread Starter
340dartswinger
Quoted: 12 Post(s)
Wow, I just went on the heater treater site and they make a nice product, but it is also $129 plus shiping for the 1 door. But they do have a nice pic on their site of the glove box removed for me to look at
Hemi 6spd Auto
post #8 of 10 Old 08-01-2011, 07:59 PM
Doug D
Quoted: 8 Post(s)
Thanks!
The HVAC computer that controls the doors recalibrates so it knows where the "stop" points (full open and full close) are. Unfortunately, that's how over time all the doors will eventually fail. The stop pins on the doors are plastic and will eventually crack and break. The recirc door and mode 2 door (controls the floor/defrost vents) are broken on mine.
2006 Dodge Ram SLT Quad Cab 1500 4x2 w/Hemi (MDS)
2010 Dodge Journey SXT 3.5L V6
Doug D is offline
post #9 of 10 Old 08-01-2011, 10:00 PM
eaton
The Walt-n-ator
eaton's Avatar
X2 on the heater treater stuff. I had two doors broken on my 06', so i just replaced all of the doors.
07' Ram 1500 QC 5.7L Lonestar Edition
Exterior:
Chrome Tubular Upper Grill - Polished Billet Bumper Grill - Polished Billet Fuel Door - 10" Black Shorty Antenna - Silver Antenna Bezel - Black Painted "B" Pillars - 22x9.5" Chrome Liquid Metal Lithium 5 wheels - 305/40-22 Nitto NT420s Tires - Belltech 2/5 Drop with Street Performance Shocks (#810SP) - Retrofit Morimoto Mini D2S 2.0 Headlight Projectors - Gatling Gun Shrouds - D2S 6000k HID Bulbs - AMP bulb adaptors - Color-Matched Headlight Bezels - Smoked Turn Signal Reflectors - Chrome Turn Signal Stealth Bulbs - 9006 HID Foglights 6000k - Smoked LED 3rd Brake Light - Smoked LED Tail Lights - 6k LED reverse Lights (3157) - LINE-X Bedliner - Street Scene Gen 2 Steel Roll Pan - Mopar Rear Wheel Well Liners
Interior:
Factory Infinity System...Gone, Finally! - Kenwood KDC-MP2035 Head Unit - Kenwood iPhone Interface - Peripheral CHYAH05 CANbus Interface (No More DTC's) - Infinity Reference 6-1/2" Components (2 Pair) - Infinity Kappa Perfect 10.1 Subwoofers (2) - Profile AP1040 80x4 RMS - Profile AP2000 320x2 RMS - Tsunami 2-Farad Capacitor - SteetWires Wiring w/ 200-Amp Main Fuse - Custom Fiberglass Subwoofer Enclosure - 100 sq./ft. FatMat - Billet Technology Satin HVAC Knobs - Billet Technology Satin Headlight Knob - Polished Billet Ribbed Cigarette Lighter - Chrome HVAC Vent Covers - Window Tint (35% Front Doors / 5% Windshield Strip, Rear Doors, & Rear window) - Silver Center Dash Bezel - Silver Door Panel Spears - Silver Front Door Window Switch Bezels - Silver Rear Window Switch Bezels - Silver Steering Wheel Bezels - Silver Overhead Console Bezel - Silver Dome Light Bezel - Silver Door Lock Bezels - Smoked Door Reflectors
Performance:
AirAid MIT - K&N Drop-in Filter - Superchips Flashpaq (#3865) w/ Trans Tuning - BBK Headers (#4009) - Mopar Header Gaskets - 2.5" Custom Tubing from Cats to Magnaflow Y - Magnaflow Y-Pipe 2.5" DI/3" SO (#10778) - Magnaflow 6" Round Muffler 3" SI/SO (#12619) - Jet 180* Thermostat (#10183) - Motive 4.56 Gears LSD - PowerStop Cross-Drilled/Slotted Rotors F/R & Powerstop Evolution Z16 Ceramic Pads F/R (#2164) - Black Painted Calipers/Brackets
eaton is offline
post #10 of 10 Old 08-01-2011, 11:08 PM
04 1500
04 1500
Quoted: 1 Post(s)
I just ened a self taper screw and screwed the door to the plastic where it closes. its 100 + down here in Tx and my ac was warm. removed motor and found door just laying there. I screwed it in the close position and ac is cold again.
04 1500 is offline
    Recirculation Door Issue eranmk1 Dodge Nitro (07 - 11) Forum 1 04-24-2011 11:47 PM
    Recirculation door problems CESRam 3G Dodge RAM - General Talk 10 04-13-2011 10:51 PM
    Is it the recirculation or blend door? Braves299 3G Dodge RAM - General Talk 5 09-23-2010 09:03 AM
    AC recirculation door? kp2quik4u 3G Dodge RAM - Interior/Exterior Talk 18 05-17-2010 09:12 PM
    Broken door handles purplesage Dodge Caravan General Talk 0 10-24-2009 07:00 PM
