4X4 Fluid Change Intervals - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 07-23-2011, 08:48 PM Thread Starter
djlaf22
DJLAF22
djlaf22's Avatar
At 34k miles was told by dealer for the second time that I should change transfer case and front/rear diff fluids...
Is this a line of crap or should I really be doing this every 30k? They quoted me $450 total for the job which is sick. I'll do it myself if this is necessary.
Any input would hopefully help my decision. Keep going back and forth on whether or not to do it.
Thanks!
2009 RAM 1500 SLT Crew Cab
Big Horn/Onyx Liner/Tubular Side Steps/Kicker Speakers and Sub/HID Headlamps and Foglights
djlaf22 is offline
post #2 of 18 Old 07-23-2011, 09:42 PM
sbarbs
sbarbs's Avatar
Im sure he is just going by the recomended interval chart which I believe is 30k miles. Personally, I would change it. I did mine at 15k and replaced with Amsoil Synthetics. I will change it again at 60,000k. I do it myself and can be done if you have basic mechanical knowledge. Fluids and RTV silicone should only be about $50-60 per axle. Good luck.
2009 Dodge Ram 1500 QC - 5.7L, Superchips Tuner, Mufflex 14 inch Magnaflow Muffler with Factory Duals, Volant CAI, Catch Can, NGK plugs,180 stat, Transgo Reprogramming kit, Trans. line pressure booster, V6 Electric Fan,Amsoil Synthetics front to back, 5100 Bilstein leveling shocks, Powertrax Limited Slip, XD Spy wheels, Falken Wildpeak A/T tires, Pioneer AVH-P4400DVD, Infinity Component speakers, JL Audio Sub in Q Logic Enclosure, Kenwood 5 channel Amp, Stinger 1.2 Farad Cap, Weathertech floor liners, Debadged.....and more to come....
Future mods: AR Headers, Circle D converter, and 4" Superlift!!
sbarbs is offline
post #3 of 18 Old 07-23-2011, 09:54 PM Thread Starter
djlaf22
DJLAF22
djlaf22's Avatar
Thanks for the reply. It's pretty straight forward to do anyway, and probably worth the peace of mind.
Although I have to drive to my parents house so I can do this on a level driveway, still looking at a couple of hours worth of work to do everything. Much better than $400!
djlaf22 is offline
post #4 of 18 Old 07-24-2011, 08:26 PM Thread Starter
djlaf22
DJLAF22
djlaf22's Avatar
I changed out the fluids today. Took about 3 hours. Everything looked good anyway but at least I have peace of mind. Still better this way than spending $400 at the dealer.
Cost me $100 total.
djlaf22 is offline
post #5 of 18 Old 07-25-2011, 08:28 AM
JustinHEMI
JustinHEMI's Avatar
My book says "inspect" the axle fluids, and it has this starting at 18K, should I read that as "replace?" I am coming up on 36K and haven't replaced them yet. For transfer case, it has "inspect" at 30K.
Thanks
Justin
2013 Dodge Ram 1500 Sport, 4x4, Black, Quad Cab, HEMI powered with 8 Speed TorqueFlite.
2015 Dodge Challenger R/T Scat Pack, 392, A8, SGII, Leather interior group, sun roof.
JustinHEMI is offline
post #6 of 18 Old 07-25-2011, 08:43 AM
2014LaramieCrew
2014LaramieCrew's Avatar
Quoted: 9 Post(s)
Do you have limited slip? How much clutch plate material (soot) was in the rear pumpkin?
2014 Laramie 4x4 CC 6.5' bed
2014LaramieCrew is offline
post #7 of 18 Old 07-25-2011, 09:57 AM Thread Starter
djlaf22
DJLAF22
djlaf22's Avatar
Yeah, my book says the same which is why I was fighting the need to do this. After calling multiple dealerships and stopping by a few automotive stores it came down to a preventative maintenance measure.
Glad I did it, but probably wasn't necessary. Diff fluid was a little brownish grey and it was clean. Didn't see any soot really. Transfer case fluid looked brand new, but I did have very little shavings in the oil.
I have 3:55's with open differentials so I didn't put the additive. I used Royal Purple which is supposedly formulated for LS anyway, which I was told would do no harm.
djlaf22 is offline
post #8 of 18 Old 07-27-2011, 09:48 AM
SnowDogs
SnowDogs's Avatar
Did you guys use a pump to remove the fluids or drop the pan on the trans and open the covers on the diffs? Also for you guys who changed to synthetic, how did you get the fluid out of the torque converter? I'm thinking about changing mine over to all synthetic in the next month but I used to wind up dropping the pan and taking a fluid bath.
I Love my fur-wheel-drive !!!
4th Gen Truck Club member #28
Orange Truck Club member #25
2009 Dodge Ram 1500 QC sunburst Orange
2010 Dodge Nitro Detonator Stone White (wife's ride)
3 Siberian Huskies 2, 3 and 4 years old and a good ole dogsled. Much more fun than any vehicle!
SnowDogs is offline
post #9 of 18 Old 07-27-2011, 08:17 PM Thread Starter
djlaf22
DJLAF22
djlaf22's Avatar
No pumps, just opened the cases for the differentials which was pretty straight forward and wasn't messy. Just make sure you use something wide enough to catch the oil.
Scraping the RTV off the case and body was more of a PITA than anything. I didn't change the transmission fluid. Just took care of transfer case and differentials.
Transfer case was a breeze, thankfully to having a drain and fill plug. If you are going to change out the fluid in the transfer case, make sure you can loosen the fill plug first. This is so you don't get stuck if you manage to drain it, but can't get the plug out to fill it.
djlaf22 is offline
post #10 of 18 Old 07-27-2011, 11:04 PM
boostjunkie1
boostjunkie1's Avatar
....... Great Advice!!!!
AMSOIL TANK 2008 White, HEMI, 4X4, 3.92 Gears, Mickey T Classic III's w/FALKEN ATZ's 295/70/17E, Curt Front Hitch, Jason's EXTREME Topper.. Loaded...
boostjunkie1 is offline
post #11 of 18 Old 07-28-2011, 08:30 AM
SnowDogs
SnowDogs's Avatar
That is an understatement!!! That is something I never thought of but I'm sure if it would happen to anyone it would be me!
SnowDogs is offline
post #12 of 18 Old 07-29-2011, 10:48 PM
boostjunkie1
........... That is what I was thinking!
post #13 of 18 Old 08-01-2011, 03:07 AM
OregonTRX4
I would change the fluids. If you do it your self it is much cheaper and good insurance.
OregonTRX4 is offline
post #14 of 18 Old 08-03-2011, 05:08 AM
hounddogg
hounddogg's Avatar
Auto trans if you want all fliud swapped use a fliud exchange machine. Not a flush machine. You'll need about 17 quarts of fliud.
2009 Quad Cab SLT White,Hemi,2WD,20 inch wheels,3.92 gear.2003 Quad Dually 4x4,6 speed,4.10 gears,diesel.Banks 4 inch exhaust,Afe Pro Guard filter,Rottech crank sensor mod.Amsoil fliuds front to back.08 Corvette Convertible.
hounddogg is offline
post #15 of 18 Old 08-03-2011, 06:55 PM
huntergreen
hey hounddog!
for the unknowing, "me" whats the difference, and are these machines available to the home owner? tks
huntergreen is offline
post #16 of 18 Old 08-03-2011, 07:00 PM
dodge-2004
$450? Oahallelly shit! I do it myself! I make $350.00 in my pocket and spend 100.00 to buy stuffs what I need!
dodge-2004 is offline
post #17 of 18 Old 08-03-2011, 07:54 PM
hounddogg
hounddogg's Avatar
Most all shops are fliud exchange. Just ask them. No its not a homeowner thing. There is a way to kinda do it yourself. You may do a search and find out how. Basically it involves two people,a big bucket,fliud,funnel,remove a trans line at the radiator and while vehicle is idling and as fliud comes out pouring fliud in. As the old fliud changes color to new fliud you stop. I'd rather pay to get it done. Tire store near me last few times I did such charged me $35.00 bucks I supplied the fliud. Dealer near me wanted $100 and I supplied fliud. Full they do it was $189.95. Chevy dealer thats a Corvette super center did my vette with Dexron 6 synthetic for $129.95! Cheaper then the Dodge store using ATF+4. Tire store I used Amsoil trans fliud in a Marquis and a older Dodge Ram. Tire store was the best buy. Did it while I waited of course. All three places used same machine. A BG fliud exchange machine.
post #18 of 18 Old 08-03-2011, 08:08 PM
MiamiDave
MiamiDave's Avatar
Quoted: 1 Post(s)
GMC is running a sale on 4x4 service, just make sure they have the proper fluids on hand $275-at least around here in VA
MD Quote: "A Power Wagon is never stuck, just occasionally, and briefly, stopped."
2011 Silver PW, red stripe delete and rear PW sticker option (by me), Diamondback Heavy Duty bed cover, Carli front diff protector/Purple Cranium full Spider Guard real diff protector, 315/70 Goodyear Duratracs all around (including spare in stock location)
MiamiDave is offline
    Diff/tcase fluid intervals sabre364 4G Dodge RAM - General Talk 3 03-29-2010 09:36 AM
    Oil change intervals dodgetech1 2G Dodge Ram Diesel Talk 23 10-26-2008 11:29 PM
    oil change intervals?? cummins one 3G Dodge RAM Diesel Talk 6 08-20-2007 11:20 PM
    Fluid Change Intervals -Hoss1959- 2G Dodge Durango - Drivetrain Talk 3 10-03-2005 11:35 AM
