How to replace key fob battery? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 07-23-2011, 08:47 AM Thread Starter
2011_Ram_RT
2011_Ram_RT's Avatar
My g/f used my spare key to start my R/T last nite and the message "key battery low" came up on the EVIC...............can I replace the key fob battery or does a stealership have to do it?
2011 Flame Red Ram RT (mine):
Mods: Bedrug
2010 Brilliant Black Mustang GT coupe (Wendy's):
2011_Ram_RT is offline
post #2 of 3 Old 07-23-2011, 08:54 AM
mr.nobody
mr.nobody's Avatar
Quoted: 3 Post(s)
Transmitter Battery Replacement
The recommended replacement battery is one CR2032
battery.
NOTE:
• Perchlorate Material — special handling may apply.
See www.dtsc.ca.gov/hazardouswaste/perchlorate
• Do not touch the battery terminals that are on the back
housing or the printed circuit board.
1. With the RKE transmitter buttons facing down, use a
flat blade screwdriver to pry the two halves of the RKE
transmitter apart. Make sure not to damage the seal
during removal.
2. Remove and replace the battery. Avoid touching the
new battery with your fingers. Skin oils may cause
battery deterioration. If you touch a battery, clean it with
rubbing alcohol.
3. To assemble the RKE transmitter case, snap the two
halves together.
mr.nobody is offline
post #3 of 3 Old 07-23-2011, 08:58 AM Thread Starter
2011_Ram_RT
Cool, thank you.
Mods: Bedrug
    How hard is it to replace hard-to-replace battery clamps? lightninboy Vintage Dodge Car Forum 2 08-04-2009 09:30 PM
    Anyone added another battery tray and battery up front weedahoe 3G Dodge RAM - General Talk 42 05-22-2009 10:20 AM
    2000 intrepid timing belt....when to replace, what to replace? shelbyzman 2G Dodge Intrepid - General Talk 1 11-25-2008 04:27 AM
    When to replace 2001 battery? MonsterStyleCom 1G Dodge Durango General Talk 14 09-29-2007 07:58 AM
    how often to replace battery? bradleykavin 3G Dodge RAM - General Talk 7 09-15-2005 09:12 AM
