99 Ram1500, 5.2 Fuel Inj. Crossover Hose leaking, Help needed - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 07-19-2011, 11:24 PM Thread Starter
mikestoyshop
Hello,
My fuel rail "crossover hose" (aka "connecting hose" according to my Haynes manual) is leaking. This hose has a rubber covering on the outside, and plastic (nylon) tubing inside. Haynes manual doesn't show this crossover hose as something that can be removed and replaced. It just shows a diagram that looks to be one assembly - the crossover that is attached to each fuel rail. I found a post on the forum that says the crossover hose is replaceable but the post didn't mention how to do it or where to get one.
The entire assembly is over 400.00 to buy new, kinda crazy, and I haven't yet found one used.
Does anyone have an idea how I can repair this line? I have already cut out a 3/4" section that had the leak and planned on using a brass barb in between to reconnect the crossover line. I'm not sure of the exact inside diameter size of the crossover hose so I can buy the proper barb fitting online.
If the crossover hose is actually a replaceable part, I'd rather replace it instead of using a brass barb. Does anyone know how the crossover actually can be removed from each fuel rail? and where to purchase one? I've searched online and have only come across entire fuel rail assemblies.
Any help is appreciated
99 Dodge Ram 1500, 5.2 motor
Mike
mikestoyshop is offline
post #2 of 2 Old 07-20-2011, 07:06 AM
Moparite
Moparite's Avatar
Quoted: 318 Post(s)
Dorman products makes the tube and fitting that goes from the fuel tank/pump to the metal fuel line. I think it is the same stuff just with the fitting. Check the size that you need. Napa has the same product with their name on it.
Moparite is offline
    Is rubber fuel line hose ok to use for this small radiator hose? Rocco1005 3G Dodge RAM - General Talk 2 06-12-2011 11:12 PM
    fuel leaking form fuel line at fuel rail CduB 2G Dodge RAM - General Talk 12 06-16-2010 10:48 PM
    Power steering hose leaking, what is the fix? Stampede4.7 3G Dodge RAM - General Talk 3 04-08-2010 02:40 PM
    Coolant leaking from hose - best fix? adamkn 3G Dodge RAM Diesel Talk 0 01-23-2008 09:33 PM
    Power Steering Hydraulic Hose Leaking The Stever Dodge Dakota 1st Gen (87 -96) Forum 2 02-21-2005 01:09 PM
