Fuel leak - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 07-18-2011, 01:15 AM Thread Starter
MosersRam
Fuel leak
I'm trying to figure out what is going on with my old Dodge 1500 pickup. It's a '97 with a 5.2 and it seems to have a fuel leak that comes and goes. Sometimes it will leak when you stop after driving it for a while and most of the time it is dry as a bone. Someone said there is a check valve of some sort that is getting hung up occasionally. I had not seen it leak for a while until today when I stopped outside the house and you could smell it. I looked under the truck and it was dripping off the tank. I ran it down to my work garage and in the time it took to go the 2 blocks it had quit.
Anyone know what this is all about?
1997 Ram 1500, 5.2L, auto, 2wd, 170K
Towing package plus second trans cooler, trans temp gauge
Felpro plenum gasket repair
Coming soon JR shift kit
Pulling a 20 foot Forester pontoon boat all around the Raystown Country
MosersRam is offline
post #2 of 7 Old 07-18-2011, 09:03 AM
BigGreenV10
Big Green
BigGreenV10's Avatar
You need to keep a log of when it does it and what you had just done meaning did you put a certain level of fuel or drive so far or sat for a while.
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #3 of 7 Old 07-18-2011, 09:44 AM
Monsta
Monsta's Avatar
Quoted: 3 Post(s)
If it was dripping from your tank, I'd probably figure theres a hole in your tank, or the fuel pump isn't tight on the tank or something, or fuel lines loose or fuel line is cracked or have a hole.
07 ram 1500 hemi 4x4
Monsta is offline
post #4 of 7 Old 07-18-2011, 10:21 AM
Moparite
Moparite's Avatar
Quoted: 310 Post(s)
Check the fuel pressure line and return line on top of the tank. The connector might be leaking also.
Moparite is offline
post #5 of 7 Old 07-18-2011, 11:05 PM
mad 1
mad 1's Avatar
can remove the inner fender well and will be able to see the top of fuel pump and lines to see where leak is from
2011 Ram Power Wagon
1997 Ram 1500 5.2 auto 4x4 ext
SCT tune by Hemifever, Fastman 50mm,14x3 open air cleaner, Magnaflow,4:11,, 265/75/16
1993 Jeep YJ4.6 Stroker,, 5 speed,
Alum. head, roller rocker, Duel header, Magnaflow,,4:56,, 33" MTRS,, 2"' lift, Warn Wench, Nates Bumpers
2007 700 Yahama Grizzly ATV
Maxis Bighorns, Power tip,, Play Ground SE Kentucky
2009 Blast 150 Toybox F/S
mad 1 is offline
post #6 of 7 Old 07-19-2011, 12:56 AM Thread Starter
MosersRam
Thanks for the replies fellows. 99.9% of the time it is dry, one of the guys at work said it has something to do with the evap cannister. The one time that I saw it leaking really bad it was coming from the top of the tank, but quit like you turned a spicket off in about 15 seconds. The truck was idling in park that whole time.
It seems worse with a 1/2+ to full tank, and hot weather, and no it is not expanding and blowing out the top of the tank. It is always running when it leaks. I fill the tank all the time and you can run several tanks without seeing or smelling the leak. I can always smell it when it is leaking. The mileage has not shown significant problems until this last tank when it went WAYYYY down, like to 10 mpg from the usual 15, I blamed it on towing the boat almost the entire tank full, but now I'm not sure.
I guess I'll have to get in there and try to catch it in the act to figure it out.
post #7 of 7 Old 07-31-2011, 11:10 PM Thread Starter
MosersRam
I watched it run for ten minutes today before it started to "perculate" out of the top of the fuel pump. It was coming out of the elbow just to the left of the electrical connection as you look in the left rear wheel well. I took the gas cap off and it quit immediately. I drilled one small hole on the inside and one on the oudside to "vent" the locking cap. I expect to see a check engine light soon but the truck is running fine and not blowing $4 gallon fuel out like a coffee pot.
    '95 3.5 V6 Fuel leak from under the fuel injector uros Dodge Intrepid 1st Gen (93 - 97) 12 03-13-2010 11:49 AM
    Fuel gauge inop, small fuel leak. Daytrepper 2G Dodge RAM - General Talk 0 11-11-2008 11:30 AM
    Fuel leak #2 greenshovel 2G Dodge RAM - General Talk 1 03-03-2008 10:09 AM
    Fuel leak at the fuel filter case mikehuggi 3G Dodge RAM Diesel Talk 2 10-27-2007 09:06 PM
    Fuel Leak.....Help! AirForceGuy Dodge Dakota 1st Gen (87 -96) Forum 3 08-14-2006 06:12 PM
