radio keyless entry problems - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 06-23-2011, 10:45 AM Thread Starter
mytdrummerman
Question radio keyless entry problems
Hi, my first post here. I have a 2004 Dodge Ram 2500 quad cab 4x4 Laramie with the Hemi engine. My problem is that the radio quit, won't come on at all. At the same time the keyless entry and the interior cab lights don't come on until I put the key into the ignition and turn the accessory power on or start the truck. The power door lock on the drivers side door doesn't work either until you turn the ignition on. Once the accessory is turned on or truck is started the keyless entry works fine but still no radio. Seems it's the constant live feed isn't getting to the needed systems. Power seats still work without key in ignition. Would this be a security problem? Ignition switch problem? Checked all fuses, all the grounds I could see...unplugged and plugged in all kinds of plugs, no go. Any Ideas?
thanks
ac, power seats, power heated mirrors.
mytdrummerman is offline
post #2 of 10 Old 06-23-2011, 11:12 AM
MonsoonMike
Site Administrator
MonsoonMike's Avatar
Quoted: 228 Post(s)
Welcome to Dodgetalk. Dodge didn't put a Hemi in any trucks until 2008. So not sure why you think you have a Hemi.
JUST KIDDING.
Do this, take your drivers door panel off. Seach on here on how to do that. It's a very easy task. 4 philips and a 10mm bolt. Pull up on the door panel.
Remove the main harness off the door lock/window buttons. Clean all terminals and reconnect the connection making sure it makes good contact and CLICKS into place.
Then try again..
::2014 Ram 2500 CTD Crew Cab Granite Crystal Metallic::
My Vehicle Build =
MonsoonMike is offline
post #3 of 10 Old 06-23-2011, 12:43 PM Thread Starter
mytdrummerman
Thanks...if your talking about the plugs that go directly into the controls for the windows and locks I have already tried that, or is there another main plug in the door?
post #4 of 10 Old 06-23-2011, 01:07 PM
MonsoonMike
Site Administrator
Quoted: 228 Post(s)
No, that is it.
My Vehicle Build =
post #5 of 10 Old 06-27-2011, 08:04 PM Thread Starter
mytdrummerman
I now tried replacing the ignition switch as well. No luck. Could it be something with the security system? The remote mirrors and power seats still work without the key in the ignition...has me totally stumped.
post #6 of 10 Old 06-28-2011, 07:15 PM Thread Starter
mytdrummerman
Well I finally broke down and brought it to a dealership.$158.00 later it works. Seems there was a faulty wire between the PDC and DLC/radio.lights RKE etc. Says here they traced back and found green part of wire, cut out green section and wired in a new piece and it then worked. Thanks for the replies I received..
post #7 of 10 Old 08-08-2011, 07:32 PM
boricua65x
need some help. Have a 2003 ram 1500 both of my keyless remotes stop working the same day, change batteries and nothing
boricua65x is offline
post #8 of 10 Old 08-08-2011, 09:33 PM
mattferd
Defender of Mattness
mattferd's Avatar
Interior lights work with the key off? Does your radio work?
I blew a fuse.. think it's 58 or 59... it's a mini fuse in a black clip all the way to the fender side of the fuse box in my 05, and it messed up all kinds of junk.
2005 Ram 1500 SLT Quad Cab 4x4 5.7 Hemi
-Stock 20 Flower Petals mounted with 275/60R20 Cooper Zeons
-Silverstar Lights in Heads, Fogs, and Hellas
-Hella 500's Behind the Grill
-LED Reverse Lights
-Pyle DVD Headunit with 7" motorized screen and 7" headrest monitors and Back up Camera
Next projects: Sub/Amp, Upgrade Door Speakers, Raptor Bedliner
God Squad 1988-Eternity
mattferd is offline
post #9 of 10 Old 08-08-2011, 10:39 PM
crasher76
Im wired!!!
crasher76's Avatar
Imo the wires will go before the fuses on the dash wiring.
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, 260 cam, 6.1 Rods/Springs, Home Ported/Polished Heads, Psc1, 04 Map sensor and Fuel pump assembly, Oil pressure guage, Amsoil, Champs, MSD 8.5MM Full length Wires, Transgo HD w/out resistor, Superchip, 180 T-Stat, K/N 77 Series, Ceramic Flowtech headers with Y-Pipe, Stage 8 locks, Ditched the cat, O2 sensor mod, Jack Rabbit bed cover, Sprayed bed liner, Big Mouth Grill-Black, Blackend Headlights/Tails, Silverstar ultras, Ditched all chrome, Custom 10's sub enclosure, Upgraded 160 amp alt, Window tint, Relocated purge valve, Energy suspension bushings, Rear spring clamps, Rebuilt front suspension, Ditched Sway Bar, Passport 8500 Radar Detector, Ditched the baby seat- kid wasnt mine, Cigarette burn in the seat mod, Debadged, Custom Rewired/Properly Grounded.
crasher76 is offline
post #10 of 10 Old 08-09-2011, 06:52 PM
boricua65x
check every fuses and no luck
    Keyless Entry Problems tuffguy 4G Dodge RAM - General Talk 12 07-10-2011 08:28 PM
    keyless entry Wetherdad 2G Dodge RAM - General Talk 1 04-02-2010 01:02 PM
    factory keyless entry install on a non-keyless model magnumsgt 2G Dodge RAM - General Talk 2 09-29-2009 10:25 PM
    keyless entry on NON-factory keyless entry truck 79rallysport 3G Dodge RAM - General Talk 9 10-08-2006 11:43 AM
    keyless entry D-rang 1G Dodge Durango General Talk 36 07-14-2004 11:13 PM
