Electronic Throttle Control Light - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 06-20-2011, 11:10 PM Thread Starter
04HemiHD
-Nick-
04HemiHD's Avatar
Not sure if this is the right place for it but i figured it would work....
Has anyone had their ETC warning light come on while driving then go out and not come back on after shutting it off and then starting it back up? Today it came on while on when i was accelerating to get on the interstate it it started to act really weird and bog down when i pressed on the accelerator and was flashing the whole time.... and when i stopped at a red light, it acted like it wanted to stall on me, so I pulled off on the side of the road, shut off the engine, then started it back up and the light went off. Also, the engine light came on with the ETC light and that has since turned off too. Could it be because it is electronic & when I restarted the engine it reset or corrected itself? I assume this is something i should get fixed right away?
Exterrior: Ultra Motorsports Gauntlet +27mm on 35" BFG Mud Terrains, Smoked third brake light, Black painted headlights
Interrior: All pillars painted black, 5% rear windows and eyebrow
Performance: Superchips 3865, straight piped
2005 Dodge Ram 1500 QC Hemi SLT - Current
2004 Dodge Ram 2500 QC Hemi SLT many mods - Sold
2007 Chevy Silverado 1500 5" lift and many other mods - Sold
2007 Ford F-150 Lariat - Sold
2004 Dodge Dakota SLT - Sold
04HemiHD is offline
post #2 of 9 Old 06-22-2011, 08:03 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
There are a few threads on this. What year is your truck?
It could be the TB itself, maybe the APPS sensor also
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #3 of 9 Old 06-22-2011, 11:49 AM Thread Starter
04HemiHD
-Nick-
04HemiHD's Avatar
its an 04... i searched but not very hard i guess then if there are a few threads.
is it something bad? cause my local dealership ran the diognostics and they found nothing because the light turned off, so what should i do about it if they cant find what is wrong with it?
04HemiHD is offline
post #4 of 9 Old 06-23-2011, 08:53 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
As long as the light is off, nothing would be flagged unless the CEL came on and an OBDii code was logged and retained in the PCM.
Best you can do at this point is hold out and see if the issue comes back and then try to isolate and repair the condition from there
Next projects:
- Custom CAI
weedahoe is offline
post #5 of 9 Old 06-23-2011, 09:09 AM
mongongo
mongongo's Avatar
Do a search on "red lightning bolt" Or "ETC"
There will be some good reads foryou..
I had the same problem this winter.. And it has not came back.
However extreeme cold temps can cause it.. so dodge says. However since its june.. I know thats not your problem
2005 Ram 1500 LT 4X4 HEMI REG.CAB
mongongo is offline
post #6 of 9 Old 06-23-2011, 02:47 PM Thread Starter
04HemiHD
-Nick-
04HemiHD's Avatar
ok thanks for the help guys
04HemiHD is offline
post #7 of 9 Old 06-23-2011, 06:55 PM
orvtenn
+ Hemi Addict +
orvtenn's Avatar
Quoted: 9 Post(s)
I had that light come on twice on my 04. The first time was this past winter, i think the temp got down to 2° that morning and the second time was during a burnout on my old tires...a key-cycle fixed it the first time and the 2nd time the light turned off on its own. I haven't had any further probs.
2004 1500 SLT RC/SB 4x4 Hemi 5.7
2001 Jeep Cherokee Sport 4.0HO
orvtenn is offline
post #8 of 9 Old 07-02-2011, 10:24 PM
SPK-Hemi
I had the same warning light start about 3months ago. Slowly increased over a month until it one morning would no go away Was able to get the error code by flipping the ignition on/off 3 times. Not sure if there are other codes for that warning light but my was 2175. Did a search and found a TB cleaning how-to in the tech write-ups. I cleaned the TB and had the had the fuel system cleaned (by a shop, not just the fuel add) and have not had an issue since, about 2k miles.
2175
'03 Ram 2500 Quad Cab 4x4, Hemi, auto,
295/70/17 Nitto Terra Grappler
SPK-Hemi is offline
post #9 of 9 Old 07-02-2011, 10:57 PM
SPK-Hemi
Here is the TB cleaning how-to
http://www.dodgetalk.com/forums/showthread.php?t=166641
SPK-Hemi is offline
    Electronic Throttle Control Light Drummer Girl 3G Dodge Ram Performance Talk 11 06-28-2010 03:08 PM
    HELP: electronic throttle control light dearlysinned 3G Dodge RAM - General Talk 13 01-02-2010 11:53 AM
    Electronic Throttle Control Light DSflyer05 3G Dodge RAM - General Talk 4 04-13-2009 11:34 AM
    check engine light/electronic throttle control light bobrocks25 3G Dodge RAM - Drivetrain Talk 7 07-17-2007 05:41 PM
    Electronic Throttle Control Light !?!?!?!?! TitansFan 3G Dodge RAM - General Talk 11 01-17-2007 12:42 AM
