Thread Tools |
trouble programming the truck garage remotes?
- Posted: 06-19-2011, 02:51 PM
Post #1
Just got this 2010 ram 35oo and have tried to get the truck to take my garage remote code but it won't. It say's its learning and transmitting afterwards but it won't open the door. Tried new battery's no help. Any suggestion?
Gtarpco |
| Sponsored Links | |
Advertisement |
Posted: 06-19-2011, 04:58 PM
Post #2
If you have rolling code on your garage door opener you probably have to enable your garage door opener unit during the syncing?
Posted: 06-20-2011, 02:40 PM
Post #3
Man I had that same issue.....you have to do the learning thing with the remote close to the truck and then also do the rolling code thing.
You have to do both....and do not clear it out in between....that is the trouble I had, but got it to work eventually.
Thanks, Greggo 2010 TRX: Leveled, Airaid CAI, Magnaflow dumped, 6K HID heads/fogs, Painted headlights, Smittybilt Light Bar with Hella 700ff driving lights, black lo-pro toolbox, spray-in bedliner, stubby antenna, 295/70-17 Nittos
Posted: 06-20-2011, 02:44 PM
Post #4
And, if you have multiple types, you have to do the rolling code ones first.
Phil Jungels North Aurora, IL 2011 Laramie Crew |
rolling door code
- Posted: 06-20-2011, 03:55 PM
Post #5
Yea I was clearing between codes, Got to go to work but will try again in a couple of days when I get back in town. Thanks gtarpco
Posted: 06-20-2011, 03:56 PM
Post #6
I had trouble too. If I am not mistaken there is a phone number in the owners manual. I had to call that number and was talked through it. Turned out I was pressing the wrong button on the remote control... the instructions didn't say WHICH button to press...anyway, they talked me through it and it worked great.
Posted: 06-21-2011, 08:03 PM
Post #7
I had a heck of a time setting mine. I had to program the truck with my garage door opener held close to it. Then I had to press a button on the garage door opener to allow it to learn new remotes. I had to do it while the truck was outside and only had about 10-15 seconds to press the button in the truck. I must have ran back and forth a dozen times before I finally got it.
-Rob '09 Ram 1500 Crew Cab Sport 5.7L Hemi 4x4 Inferno Red |
Posted: 06-22-2011, 08:25 AM
Post #8
I tried the learn button on the garage door opener several times. I cleared the codes in the truck, took the actual garage door remote and held it close to the buttons in the truck and pressed the open button and the first button in my truck until it said transmitting in the EVIC and then stopped. I realized you have to actually press and hold the button in the truck for a second before the garage door goes either way, instead of just a quick press.
2011 Ram 1500 CC Sport 4x4 Deep Water Blue Pearlcoat Mopar Molded Mud Flaps | WeatherTech Floor Mats | 2013 Sport Rims | 14" Magnaflow DIDO | Magnaflow 5" Tips | Y-Pipe Deleted | Tailgate Light Bar & LED Tails | BT Catch Can & Under Hood Kit | Tint Future Mods: Color Matched Tailgate Handle, Antenna Base, JBA Short Tubes, Roll-Bak Tonneau Cover |
Posted: 06-22-2011, 12:09 PM
Post #9
Hey thanks for the info will give it another try. GTARPCO
| Thread Tools | |
| Garage Door programming | Adam Dukoff | Dodge Magnum - General Talk | 2 | 09-05-2009 04:27 PM |
| How Do You Programming the Durango Garage Door Opener. | HEMI5PNTSVN | 2G Dodge Durango - Interior/Exterior | 18 | 07-22-2009 10:23 AM |
| programming new keyless remotes? | korn9613 | 1G Dodge Durango General Talk | 1 | 03-17-2008 08:05 PM |
| Programming my overhead garage thing to my GARAGE!? | MonsterStyleCom | 1G Dodge Durango General Talk | 6 | 08-20-2007 09:43 PM |
| Garage Door Opener Programming | richml3 | Dodge Magnum - General Talk | 7 | 04-30-2006 08:54 AM |
Privacy Statement | |
