power window problem - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 06-18-2011, 05:28 PM Thread Starter
myod
myod's Avatar
04 regular cab ,both power windows work from drivers side switch ,but not from passenger side ,put new switch in right side still didnt work ,and there is no window lock, anyone have an idea or a wiring diagram
04 dodge ram 5.7 hemi,,,,,,, tinted front windows ,,,,, kool vue cai with a green high performace air filter,,,, 3rd strike egr baffle,,, cooper zeon ltz tires,,,, reflex shocks,,,,superbee hood scoop,,,,a.r.e. bed cover ,,,, rhino lining,,,, step tubes,, ventshade step shields,,, air ram jet stream scoop,,,MBRP cat back SI/SO exhaust,,,air-ram performance power wire
myod is offline
post #2 of 7 Old 06-18-2011, 05:47 PM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 54 Post(s)
Common problem and here is the fix: Remove the driver's side switch module and open it up (takes a bit of wrestling). Touch up the window lock-out switch solder connections with a soldering iron. Fixed mine right up!
'03 1500 QCSB Hemi
Vent shades/15% tint
A.R.E. Tonneau/Bed Rug
Nerf step bars
Rear LED light bar/LED frt. turn signals
LED tails & 3d brake light/White Night backup lamps & LED interior lights
Halos/projector headlights KC HiLites Titanium Driving lights
Tailgate Easy Lift & EZ Down
E&G Classics mesh grill
WeatherTech Floor Liners
Overhead console with HomeLink
JVC KD-AR780 Receiver & CH-X1500 Changer
Jensen 6x9 3-way up frt., 5 1/4" 2-way rear
GenTex auto-dimming mirror & Towing mirrors
Fender liners & Ram splash guards
Silver Truck Club Member #140
S.N.A.T.C.H. Club Member 666-666
2 1/2" level kit
Jetstream Scoop/Power Wire
MagnaFlow Stainless Cat-back SI/DO
TrueFlow intake kit
Hellwig 7651 sway bar
Flex-a-lite Black Magic Extr. 180 Elect. Fan
Dick Cepek Chrome DC-1s/Bridgestone Revo2 285/70
MikeHTally is offline
post #3 of 7 Old 06-18-2011, 05:49 PM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 54 Post(s)
Whoops, no window lock-out? How is that? Anyway, try the repair. I bet those connections are there anyway. Left front of the module.
post #4 of 7 Old 06-18-2011, 08:21 PM Thread Starter
myod
myod's Avatar
thanks for the reply,, but its only a 2 door it doesnt have a window lock out switch,,, ha ha i see your other post , i will try it though
myod is offline
post #5 of 7 Old 06-18-2011, 09:34 PM Thread Starter
myod
myod's Avatar
it must be the problem , cause i took the switch out and after messing with it ,,the passenger window started to work with the passenger switch,, but how in the hell do you get that apart to fix it ,,,i am afraid its gonna break
myod is offline
post #6 of 7 Old 06-19-2011, 09:04 AM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 54 Post(s)
It's a bear to take apart. The housing is like an upside-down box, held together by tiny snap-clips. Work a small screwdriver in to get the clips around the rim to release. You'll have to get the buttons off, too. They're rather stubborn, but they'll release. The circuit board is held to the inverted box by four screws (IIRC). Take those out to get to the solder connections. At the front left of the circuit board should be two stout solder connections. If you look closely, you'll see tiny (TINY!) cracks running around the solder connection. Touch those up with a soldering iron and a bit more solder. If you're not familiar with soldering, a little goes a long way and heat the connection, NOT the solder.
While you're in there, you'll probably notice some carbon deposits on the switch contacts. You might as well clean those while it's apart. Use an emery board or fine sand paper and some spray electrical contact cleaner. The contacts in mine were pretty black from all the arcing over time.
Put the board back in, reattach the buttons and pop the box back together. Before you reconnect the wiring harness, a bit of dielectric grease on the pins should make it last longer. Make sure the harness connectors click in firmly.
'03 1500 QCSB Hemi
Nerf step bars
2 1/2" level kit
TrueFlow intake kit
post #7 of 7 Old 06-19-2011, 09:08 AM Thread Starter
myod
myod's Avatar
i did get it apart then ,,, where the window lock button would be there was two solder points that were cracked around the wire, i fixed those and cleaned the contacts too ,,,thanks for your help saved me from buying a new one,,thats why i love this forum ,,very helpful
myod is offline
    Power window problem DodgeHemi345 3G Dodge RAM - General Talk 25 01-19-2007 10:09 AM
    2001 Power Window Problem Todd Gerber Dodge Caravan General Talk 5 01-05-2007 10:16 PM
    power window problem gmando 3G Dodge RAM - General Talk 1 08-30-2005 06:06 PM
    Power Window Problem flahunter 2G Dodge RAM - General Talk 4 03-09-2005 06:50 AM
    power window problem duketter 2G Dodge Dakota - Interior/Exterior 3 03-04-2004 08:08 AM
