2005 Dodge Ram Tranny codes P0700 and P0841 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - Drivetrain Talk
tetdepth
  2005 Dodge Ram Tranny codes P0700 and P0841 - Posted: 06-04-2011, 06:25 PM
State: GA
Post #1
2005 Dodge Ram 1500 SLT 4x4 HEMI 5.7 Automatic with 57000 miles. Check engine light came on for the first time today and threw both of these codes. My tranny guy reset the code and it has not come back (yet). The truck gives no indication of having any problem other than the engine light came on.
I am sure this isn't the first one. According to my tranny guy with over 30yrs of experience these things typically fail between 40000 and 70000 miles. My truck has 57000. Dodge bad engineering strikes again. Placing plastic electrical parts inside the transmission in a bath of hot tranny oil. Thanx Dodge!! Jerks!!
My guy says I need a Solenoid Pack and Govenor Pressure. He also recommended changing the low and high filter while it's open.
Where is the best place to buy these parts? Is this a DIY project?
I have several years of backyard mechanic experience to include tranny builds, engine builds etc etc.
JD
05Ramhendrix
 Posted: 06-04-2011, 07:51 PM
05Ramhendrix's Avatar
Ramistered User
City: Estero
State: FL
Post #2
Your tranny guy has 30 years experience with 5-45RFE's??????
I don't hear about these parts failing on a regular basis around here, I'd get a second opinion before you just dive in and replace parts. Have you changed the filters of fluid lately or have anything done to the trans that would help diagnosis the real issues? Check harness connectors for good connect etc.
Scott
2005 QC HEMI * 2wd * Viper PSB Bright Silver * AEM Brute Force Intake * Powerwire * Jetstream Scoop * Stant 14168 180* T-stat * Superchip Flashpaq 3865 w/ Trans Tuning * BBK Ceramic Shorty Headers * Magnaflow Y Pipe * Magnaflow Catback * Motive 4.56 Gears LSD * Rough Country 6" Lift *Moto Metal 951 20x10 *Nitto Terra Grapplers 305/55/20 * Alpine Audio
tetdepth
 Posted: 06-04-2011, 08:42 PM
State: GA
Post #3
30yrs working on all transmissions and the owner of a private and not chain store transmission shop. I bought this truck 6/10 from a National Auto Dealer and it had 46000 miles on it. Everything was serviced before I picked it up. I have not done any transmission work to it at all, especially after only putting 10000 miles on this truck. I do not offroad or pull anything with it and it is mainly used to drive back and forth to the military base where I work about 12 miles one way. The fluid is clean, full and looks like it was put in yesterday. I will check the electrical connections tomorrow. I did have one other problem with a mouse or a squirrel chewing my coil wire almost in two.
I am being told that if I do not fix this soon I run the risk of ruining this transmission and that would be about $3000 to fix.
According to the print out for error code P0841 it states: Low/Reverse pressure switch rationality fault.
Probable Cause: Open or short circuit condition, Poor electrical condition, Failed trans solenoid/pressure switch, Faulty TCM/ECM.
irishmedic
 Posted: 06-05-2011, 10:42 AM
irishmedic's Avatar
Daytona 8398
City: Southampton
State: PA
Status: Online
Post #4
Back in Nov I had the same codes pop up plus an additional one. What they found on mine was a plastic clip that help the pump hose in place came loose. Unfortunately for me the only way to get to the clip was to drop the trans and tear it down. I have had zero issues since (knock on wood). I thought at first as well as everyone else I talked to, it was a solenoid pack that went bad. Mine was a factory defect because the clip was not put in right and it was replace with a stainless steal clip. So it is possible you might have the same issue, I am just throwing that out there. Oh and my tranny guy told me that my trans looked brand new on the inside, zero wear marks on everything in the trans.
Jon
2005 Dodge Ram 1500 Daytona #8398
Silver Truck Number 212
Quad Cab Number 40
SuperChips 3865
Spectre CAI
E3 Spark Plugs
Taylor Wires Blue Full Length 8.2 Thunder Volts
85mm Ported TB
Sonnax Transmission Line Pressure Booster
AirRam PowerWire
AirRam Jet Stream Scoop
Jet 180 TStat
Borla Exhaust
Magnaflow Y Pipe
RP in motor/differentials/transmission/radiator/power steering/transfer case
Bilstien Shocks
Painted calipers
Drilled and slotted rotors x 4
Sirius Sat Radio
WeatherTech Window Vents and floor mats
Access Tonnosport
Dupli-color bedliner with kevlar
2003 Jeep Wrangler Sport (wife's vehicle)
Spectre drop in filter
Jet 180 TStat
Drilled and slotted rotors (fronts only)
General Grabber AT2 tires
Blacked out rims
Skyjacker Nitro 8000 shocks/Skyjacker Hydro 7000 steering stabilizer
Painted calipers
Sirius Sat Radio
tetdepth
 Posted: 06-05-2011, 07:42 PM
State: GA
Post #5
I hate easter egging when troubleshooting a problem. The codes really do not point to anything specific. The tranny guy I spoke to said he had just repaired this very same thing on another guys truck 2 weeks ago and in order to fix the problem and clear all of the codes he replaced the solenoid pack and the governor pressure switch. Where I live the guy I went to is the most experienced and honest tech there is. Unfortunately when you speak to 10 different techs you get 10 different answers and they all start with "well it could be this or it could be that". Basically start replacing parts one at a time until the problem goes away.
At this point I am not sure because he reset the check engine light and it has not came back on. If it was a true failure wouldn't it come back on? Is it possible this was just a computer glitch?
05Ramhendrix
 Posted: 06-05-2011, 07:53 PM
Ramistered User
City: Estero
State: FL
Post #6
One Trip Fault for those codes, three good trips to turn off the MIL. Could be numerous things that trips the fault, anything from low fluid level to low line pressure to oil filter seal etc... If the code hasn't come back yet then just leave well enough alone for now. If there truly is a problem then the code will come back.
Scott
tetdepth
 Posted: 06-06-2011, 04:21 PM
State: GA
Post #7
After reading several posts from different websites about this problem I have a few more symptoms that I did not realize were related. The engine light came on for the first and only time on 6/4/11. Prior to that my truck would stall every once in awhile. After my truck had sat for a few hours or overnight and I backup and then place the truck in drive and roll a few feet the truck would stall. It restarts right away. Then I received the engine light and trans code P0700 and P0841.
I was able to find a couple of TSBs about this problem and Dodge clearly knows about it. Some of the posts I read involved the 45RFE engine on 2003 Dodge Rams and others. The one guys truck was still under warranty and Dodge actually replaced his transmission with a 545RFE. This is the same transmission I have a problem with.
TSB 21-007-06 applies to vehicles with 45RFE and 545RFE transmissions with specific build date codes. This describes my problem and my transmission falls within the build dates. It states the transmission cooler return filter may cause the sump filter to split where the plastic and metal crimp are. It says one or more of the DTCs may occur which P0841 is mine.
I called Dodge customer service and they said they would not warrant it or help fix it.
This is the first Dodge vehicl I have ever owned and it will be my last. 2005 Dodge truck with 57000 miles and already has transmission problems that Dodge refuses to stand behind. I rank this up there with my wife's old Mitsubishi Expo where the transmission failed at 103000 miles. The bottom line is that Dodge knows they have a faulty transmission and they refuse to repair them!!
crasher76
 Posted: 06-06-2011, 06:40 PM
crasher76's Avatar
Im wired!!!
City: K-TOWN
State: WI
Post #8
So try replacing the sump filter and o ring. Unhook all connectors, clean, use electric grease, then button the bitch back up.
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, SRT CAM, 6.1 Rods/Springs, Home Ported/Polished Heads, Psc1, 04 Map sensor and Fuel pump assembly, Oil pressure guage, Amsoil, Champs, MSD 8.5MM Full length Wires, Transgo HD w/out resistor, Superchip, 180 T-Stat, K/N 77 Series, Ceramic Flowtech headers with Y-Pipe, Stage 8 locks, Ditched the cat, O2 sensor mod, Jack Rabbit bed cover, Sprayed bed liner, Big Mouth Grill-Black, Blackend Headlights/Tails, Silverstars, Ditched all chrome, Custom 10's sub enclosure, Upgraded 160 amp alt, Window tint, Relocated purge valve, Energy suspension bushings, Rear spring clamps, Passport 8500 Radar Detector, Ditched the baby seat- kid wasnt mine, Cigarette burn in the seat mod, Debadged, Custom Rewired/Properly Grounded.
whoamioitsme
 Posted: 07-26-2011, 08:41 PM
whoamioitsme's Avatar
State: ON
Post #9
Hope this information is helpful. Let me know if you need more help with this.
Chris
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-016-05, DATED
SEPTEMBER 01, 2005, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS
A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT
REVISIONS.
SUBJECT:
RFE Transmission Filters - Delayed Engagement And Related Transmission DTC'S
OVERVIEW:
This bulletin involves verifying the build date of the transmission, and if necessary, the
replacement of both the cooler return and sump filters in the transmission.
MODELS:
2005 - 2006 (DR) Ram Truck
2005 - 2006 (HB) Durango
2005 - 2006 (KJ) Liberty / Cherokee
2005 - 2006 (ND) Dakota
2005 - 2006 (WK / WH) Grand Cherokee
2006 (XK) Commander
NOTE: This bulletin applies to vehicles equipped with the a 45RFE or a 545RFE
automatic transmission (sales code DG4 or DGQ respectively) having a
specific transmission build date code (see the below DIAGNOSIS section for
further details).
SYMPTOM/CONDITION:
The customer may experience an initial delayed shift engagement following an extended
off (not running) period of time, generally after being parked overnight. The initial shift
engagement may feel like a delay or slip when a transmission gear (reverse or drive) is
first selected after engine start.
The customer may also experience a MIL illumination. Investigation may determine that
the MIL is due to one or more of the following Diagnostic Trouble Codes (DTC's):
P0868 - Line Pressure Low. This DTC will be the most frequently occurring DTC for
the delayed shift condition.
P0944 - Loss Of Hydraulic Pump Prime.
NUMBER: 21-007-06
GROUP: Transmission
DATE: April 07, 2006
P0731 - Gear Ratio Error In 1st.
P0736 - Gear Ratio Error In Reverse.
P0841 - LR Pressure Switch Rationality.
P0876 - UD Pressure Switch Rationality.
The delayed engagement and MIL condition (DTC's) may be caused by a suspect
transmission cooler return filter with a part number of 04799662AB. A suspect
04799662AB cooler return filter may cause the transmission sump filter to split at its
plastic-to-metal crimp. If the transmission sump filter becomes split at the crimp, then one
or more of the above DTC's may also occur.
DIAGNOSIS:
1. Turn the ignition to the "OFF" position.
2. Raise the vehicle on a suitable lift.
Fig. 1 TRANS IDENTIFICATION NUMBER
1 - TRANSMISSION IDENTIFICATION (SERIAL AND PART) NUMBER - 20 DIGIT
3. Inspect for the transmission build date (Julian date) (Fig. 1). The transmission build
date can be determined by inspection of the 20 digit transmission identification number
(DDDYxxxxxPpartnumber). The transmission identification number is XXXXX on the
left side (driver side) of the transmission oil pan flange. The first four (4) digits of the
transmission identification number are the transmission build date, in Julian date
format. An example of a transmission identification number would be :
101510492P52119684AA. The first three digits ( 101 ) of the identification number
equal the day of the year, in this case 101 equals April 11. The fourth digit ( 5 ) of the
identification number equals the calendar year, in this case 5 equals 2005. So 1015
equals April 11, 2005.
21-007-06 -2-
4. Determine if the vehicle's transmission was built on or between one of the two sets of
Julian date build ranges listed below:
a. Julian date 0425 (February 11, 2005) to Julian date 0455 (February 15, 2005). 0425
to 0455.
b. Julian date 1015 (April 11, 2005) to Julian date 2345 (August 22, 2005). 1015 to
2345.
5. If the vehicle has the above condition, and if the transmission Julian build date is on or
between the range of dates listed above, perform the Repair Procedure.
NOTE: Both the transmission cooler return filter and the transmission sump filter
MUST BE replaced at the same time.
PARTS REQUIRED:
NOTE: DO NOT use a replacement cooler return filter with a part number of
04799662AB. This filter is suspect of causing the above condition. The cooler
return filter part number is XXXXX on the side of the filter's metal case.
Qty. Part No. Description
1 04799662 Filter, Transmission Cooler Return
(AR) 1 05015267AC Kit, Transmission Sump Filter - 4x2 (verify p/n
for specific vehicle)
(AR) 1 05013470AC Kit, Transmission Sump Filter - 4x4 (verify p/n
4 05013457AA Fluid, Automatic Transmission, MS-9602
ATF+4, Quart
1 05010884AA Mopar ATF-RTV
SPECIAL TOOLS/EQUIPMENT REQUIRED:
8321 Oil Filter Wrench
REPAIR PROCEDURE:
NOTE: All cooler return filters with the "AB" suffix (04799662AB) are suspect. The
above condition may be corrected by replacing a suspect "AB" filter with a
new cooler return filter whose part number is XXXXX (with no suffix or with
a suffix that is other than the "AB" level), and a new sump filter.
NOTE: BOTH the sump oil filter and the cooler return filter MUST BE replaced in the
transmission at the same time. Do not replace one filter without also
replacing the other filter.
-3- 21-007-06
NOTE: A replacement 04799662 cooler return filter may come packaged with a
separate threaded adapter stud. The threaded adapter stud is used to attach
the cooler return filter to the transmission. Inspect the stud and note end
without threads. Install the stud end without the threads into the cooler
return filter and tighten the stud-to-filter connection to 18.6 Nm (165 in. lbs.).
Once the threaded adapter stud has been installed to the cooler return filter,
install the assembled cooler return filter to the transmission and tighten the
filter to 14.1 Nm (125 in. lbs.)
Fig. 2 Transmission Filters - 4X4 Shown
1 - SUMP OIL FILTER
2 - COOLER RETURN FILTER
3 - COOLER RETURN FILTER BYPASS VALVE
4 - VALVE BODY
Use the procedures outlined in TechCONNECT® ( Service Information Tab / 21 -
Transmission Transaxle / Automatic - 45RFE 545RFE / Fluid / Standard Procedure / Fluid
and Filter Replacement) to replace BOTH the transmission cooler return filter and the
transmission sump oil filter.
NOTE: Always install the sump filter seal to the bottom of the transmission oil pump
first, then install the sump filter to the oil pump and previously installed seal.
DO NOT install the sump filter seal to the sump filter and then attempt to
install both to the oil pump.
Hope that is some good info for someone
trad444
 Posted: 08-03-2011, 08:29 PM
State: SD
Post #10
JD
If he is telling you that you need Solenoid pack and Governor pressure solenoid his ripping you off its all contained in the Solenoid pack. Whats with the low and high filter that's not what they are called at all.
JD
Ummm not really
dodgemastertech
 Posted: 08-04-2011, 11:31 PM
dodgemastertech's Avatar
dodgemastertech
City: California
State: CA
Post #11
If you perform the TSB and still get code P0841, then you will need to replace the solenoid pack. And the valve body assy would need to be removed to replace the solenoid pack.
HemiTyler
 Posted: 08-07-2011, 08:53 PM
HemiTyler's Avatar
City: NB, Canada
State: NB
Post #12
i threw the p0700 code the other day and from everything i could find it told me to change my tranny fluid.. so i flushed my trans.. new oil and changed the pan and return filter.. no more p0700 codes since
Black 2005 Dodge Ram 1500 QC 4x4, Laramie
Leveled 2.5"
35x12.50r17 Dunlop Radial Mud Rovers
3" exhaust with 3" glasspack to a 3 1/2" tip, pass side exit
K&N intake
... much more to come....
Sponsors:
Pro X Sports, Go Fast Energy,
Scott Bikes, Dakine, Sugarloaf Bike Park
P0700 & P0841 Codes Sky God 2G Dodge Dakota - Drivetrain Talk 8 01-20-2010 06:48 PM
need info P0700 & P0841 Codes Cainlord 2G Dodge Durango - Drivetrain Talk 3 12-21-2009 01:40 PM
Help Tranny Codes P0700 and P0841!!! BGRTHNURHEMI 3G Dodge RAM - Drivetrain Talk 21 12-20-2008 07:01 PM
2003 Dodge Neon Codes P0700 and P0731 jcdavis43 Dodge Neon - General Talk 2 08-24-2008 11:55 AM
2001 Dodge caravan w/3.8L tranny codes p0700 & p0740 Caravan-N-Sand Dodge Caravan/Grand Caravan Talk 11 01-14-2008 11:52 AM
