Cost to replace Main Rear Seal - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 05-31-2011, 09:59 AM Thread Starter
mindtrip
mindtrip's Avatar
Hey Fellas... My Main Rear Seal has a slow leak. The dealership said it would run me $1000 to replace since they have to remove the tranny. Does this seem high? I don't have a regular mechanic that I go to, but definitely don't want to drop a grand to fix. What should this cost if I were to take it somewhere else?
Also, what would be the consequences of not getting it fixed? The leak seems to be very slow. Oil is collecting under the truck, but not dripping onto the driveway. I first noticed it about 15k miles ago. Thanks
2011 SLT Big Horn QC 1500 4x4 5.7L Mineral Gray
Factory Options: Spray-in bed liner, 430N w/ Alpine Sound, Backup Camera, Protection Group, 3.92 Anti-Spin, Tow Package, Bucket Seats
Mods: Magnaflow Cat-Back w/ 5" Tips, Bilstein 5100's @ 2.8", Moto Metal 951 18x9, Nitto Trail Grapplers, Sonnax
Wish List: JBA Headers - FastmanTB - S&B Intake - Amp PowerSteps - Pure Performance Triple Threat - Circle D TC
mindtrip is offline
post #2 of 10 Old 05-31-2011, 11:20 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
Well the rear seal doesnt cost but about $12
http://www.hensonmotorsports.com/mer...tem.php?id=630
I would do mine myself if it were me.
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #3 of 10 Old 06-02-2011, 08:21 AM
!05RAM05!
Previously Micash21
!05RAM05!'s Avatar
I don't have the labor time in front of me, and I am sure someone here has access to that. Most shops charge 85 - 95 an hr for labor. You figure with removing a transmission that the labor time is going to be high. Do you have the quote from the dealer??
New: 2005 Dodge Ram 1500 QCSB 4x4 Hemi Laramie Bright Silver
Flowmaster SI/DO 40 Series. Superchips 3865 - 91 Tune, 2/4 drop, More to come............
::GONE BUT NOT FORGOTTEN::2005 Dodge Ram 1500 QCSB 4x4 Hemi Sport Black
5.5" Rough Country Lift, Dick Cepek DC2 20x9, 325/60R20 Nitto Terra Grappler's, Superchips 3865 - 91 Tune, Extang Tonneau Cover, K&N Cold Air Intake, Bosch Platinum 4 plugs, Magnaflow Y-Pipe, SI/DO Flowmaster Original 40 Series, Synthetic Everything, 7000K Headlights, Foglights and Hellas..
1998 Dodge Durango SLT 4x4 Black
Hypertech 87 Tune, K&N Cold Air Intake, Bosch Platinum 4 plugs, Bosch 8.5mm Wires. Ported Throttle Body, SI/DO Flowmaster Original 40 Series Muffler, Headman Headers, 3" PA BL, 2" T/S Lift, 33x12.50R15 Firestone Destination M/T's, 15x8 Eagle Alloy Wheels.
BTC Member 211 - Steel Reserve
!05RAM05! is offline
post #4 of 10 Old 06-02-2011, 08:44 AM
jerry cole
about $500. should be to price
jerry cole is offline
post #5 of 10 Old 06-02-2011, 10:45 AM
Rich 2500
Rich 2500's Avatar
I'll probably get burned at the stake for even mentioning this, but you could try some Z Max to see if you can put some life back into that seal, make sure the engine is fully warmed up before putting it in then be sure to drive it for 30 min or more.
Leaving now changing my name and address, don't bother looking for me.
Elec. Blue 07 2500 Thunderoad QC Hemi 4X4
BTC #181
Mopar Cai, Mopar SS Nerf Bars, Mopar Tow Mirrors, Mopar Wheel Well Liners, EGR In Channel Window Vents, Tinted Windows 30%, Hella 500's behind the grill, Gibson Dual Sport Catback Exhaust, Magna Flow "Y" Pipe, Jet Stream Scoop, Power Wire, LineX Bedliner, Flexalite 180 Efan (shrouldless), Jet 180 Thermostat, Edge Evolution (used as monitor) DiabloSport Predator, Solid Steel Industries-Steering Stabilizer, Carli Starter Suspension System, Carli Adj. Track Bar, Toyo 35/12.50/17 MT on Stock Wheels, Carli Anti Sway Bar, Xeon Fogs 6000K
Rich 2500 is offline
post #6 of 10 Old 06-02-2011, 11:28 AM Thread Starter
mindtrip
mindtrip's Avatar
Damn.. a $12 part and the dealer want a grand to put it in.
The quote from the dealer was over the phone. They said about $1000
Thanks Jerry. I'm gonna call a few shops recommended by some co-workers to see what they charge.
mindtrip is offline
post #7 of 10 Old 06-02-2011, 05:40 PM
Redtruck-VA
Redtruck-VA
Redtruck-VA's Avatar
Quoted: 4 Post(s)
In my area the trans drop including service and TC replacement was $625. This does not include the cost of the TC. maybe take some of the pain away by replacing the TC at the same time.
Greg
2003 RCSB SXT-Hemi - OEM Durango rims/275/60-18 tires, AeroForce-w/wideband, Trans 46RH, PPP Track Warrior, 6.1 dual coil ignition, 05 fuel pump, w/external reg, K&N -77 CAI, 90 BBK TB, 20% U/D, eFan, TCI FastGate shifter, AutoMeter Shiftlite, 180 thermostat, 2500HD OEM Trans Cooler, 3000 stall Edge Converter, 2500 manual PCM, DTT 4:10, LT's, Magnaflow SI/DO, duals cats, Mcgaughys 3/6 spindle kit, Caltracs traction bars, Aeon springs for bump stops Frt/Rear, 04 Laramie leather SLT 10 way seat and SLT leather steering wheel, CD/radio, stand alone OEM foglights, billet grille inserts, painted cowl (shaved) and upper bumper cover, Shaved tailgate w/EZdown, Shaved Antenna, Amplified hidden antenna, sliding rear window, welded steel Roll Pan, Hidden hitch, Sport mirrors, Painted Front bumper, Fiberglass tonneau cover, OEM bed liner, Triple gage pillar, billet gas door, de-badged, tint strip. With 89' D250 Diesel support vehicle.
Redtruck-VA is offline
post #8 of 10 Old 06-03-2011, 03:51 PM Thread Starter
mindtrip
mindtrip's Avatar
Great idea.. I like the way you think. That would definitely take some of the sting away
mindtrip is offline
post #9 of 10 Old 06-03-2011, 07:15 PM
angusdevil
They call me Radio
angusdevil's Avatar
about 10-15 bucks, a case of beer, a buddy, a floor jack, some tools and an afternoon. It's not hard to do, just a lot of steps.
If it's a slow leak, just wait on replacing it until it becomes more apparent.
1973 RCLB Stroker SB
REBUILD BLOG - radio1973dodge.blogspot.com
- Longtravel suspension still being built, Grabber 35" MT's, Method Wheels, 4.10's.
- Custom dash/gauge cluster, Corbeau seats, dual electric fans, most of the wiring replaced, 7" HID's, lots of other flashy and bright lights
- Fuel cell, aluminum rad, rear tranny cooler, front and rear tube bumpers, cut rear rockers and cage work ready to get started on.
angusdevil is offline
post #10 of 10 Old 06-03-2011, 07:56 PM
rootkit
Jeremy
rootkit's Avatar
Quoted: 1 Post(s)
Dealer.... Eh... Check out B & I Frame & Axle Service they are on Burbank Blvd. They owner drives a 2500. Rates are pretty good and nice to talk to.
Now... I have no idea how to change it out... But I have the Haynes manual floor jacks and stands and most of the tools just a thought...
06 2500 4x4 5.9l Laramie Quad Cab Atlantic Blue
rootkit is offline
    rear main seal spun360 2G Dodge RAM - Drivetrain Talk 0 10-22-2009 06:12 PM
    Replace rear main seal on 318 V8? Elajten Dodge B-Series Vans 1971 - 2003 6 01-27-2009 09:20 AM
    5.2 rear main seal 44inchram Mopar Vehicle Talk 5 01-01-2009 08:22 PM
    rear main seal.. demon217 1972-1987 Dodge Ram Trucks (D, W-series) 8 10-01-2007 10:15 AM
    Rear main seal ?'s dodgeneonACR98 Dodge Neon - Performance Talk 11 07-17-2005 06:15 AM
