Cooling system issues, How to purge air? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 14 Old 05-28-2011, 07:52 PM Thread Starter
Hughes
Hughes's Avatar
It's been awhile since I last visited but never needed because my truck has been great with zero issues.
My truck is a 2006 Ram 1500 2wd with 4.7 L engine. 110,000 miles. Here's my issue, my truck started running a warmer than normal so I say heck the coolant is pass due for changing and the thermostat also. When I went to remove the lower bolt on the thermostat cover it came about 1/4 of the way out and stopped. It would not retigthen either, it felt like it was cross threaded. I tried to work it back and forth and then it just broke off into the alumn. housing. I tried to drill the bolt out, but a few hours later I broke a drill bit off into the bolt so that ended that.
I'm not sure what that housing is called that the plastic thermostat cover mounts to. I not sure where I can get one either.
I bought this truck new and it has never had the thermostat changed so the bolt came cross threaded but that not big deal at this time as I need parts.
Made In U.S.A
2006 White Ram 1500 2wd Quad Cab 4.7L
Modifications
Tinted Windows
K&N Drop In Air Filter
Slash Guards
Hella's Behind the grille
265/70/17 Nexen Tires
Hughes is offline
post #2 of 14 Old 05-28-2011, 09:01 PM Thread Starter
Hughes
Hughes's Avatar
I think it's called a timing chain cover. Any how to tips?
Made In U.S.A
Modifications
Tinted Windows
Slash Guards
Hughes is offline
post #3 of 14 Old 05-28-2011, 09:05 PM
big guy
big guy's Avatar
Quoted: 12 Post(s)
Definite Bummer! I would be looking locally for some help. I remember in school. If you broke an easy out off. You need a machine shop with an EDM to remove it. I think it is called a EDM? You may end up having to pull you timing chain cover off to get it removed? Then get a heli coil to repair the thread.
Working on rusted shit has never been my speciality. I usually will use my torch if safe to heat. I dread the situation your in !
You can get a new t/stat housing at the dealer. I have also seen them on Rock Auto. I would really be looking locally for somebody with experience to a get hands on opinion. Hopefully they can get it out without removing the cover. Good Luck.
2003 Ram 1500 SLT, 4.7,4x4 L.B. 4.10 motive gears, auburn LSD, PML rear diff cover, 3715 super chip, airaid M.I.T. & E.A.A. dry air filter, flexalite electric fan B.M. 180 extreme with moe's fan shroud delete kit, jet 180* stat, hemi radiator (spectra CU 2813). JBA shorty headers, homebrew power wire, aeroforce interceptor scan gauge, sonnex line pressure booster.
big guy is offline
post #4 of 14 Old 05-28-2011, 09:12 PM Thread Starter
Hughes
Hughes's Avatar
Thanks, Yep once that drill bit broke off I knew it was over. I think if I can get the cover off I might be able to get the broken bolt out and heli coil it. Problem I have found is the cover is a dealer item and I need this to be up and running by end day monday. Thanks.
Made In U.S.A
Modifications
Tinted Windows
Slash Guards
Hughes is offline
post #5 of 14 Old 05-28-2011, 09:16 PM
big guy
big guy's Avatar
Quoted: 12 Post(s)
If you get it out. Go to Home Depot or Lowes and get some grade 8 bolts. Use some anti seize on them as well.
big guy is offline
post #6 of 14 Old 05-29-2011, 08:09 PM Thread Starter
Hughes
Hughes's Avatar
Got the timing chain cover off and removed the broken bolt and installed heli coil, got everything back together and just can't get the cooling system purged of air.
I took pictures of the belt before I removed and have confirmed serveral times that I have the belt for the water pump routed correctly. Confirmed also with service manul for truck.
Top radiator hose is hot and lower hose going to the thermostat is cool and also the radiator cap is cool. I also confirmed with service for proper install of the thermostat.
What's the trick to getting this cooling system purged and working?? Thanks.
Made In U.S.A
Modifications
Tinted Windows
Slash Guards
Hughes is offline
post #7 of 14 Old 05-29-2011, 09:09 PM Thread Starter
Hughes
Hughes's Avatar
No external leaks, no water in oil, lower rad hose seems to not have coolant in it.
Made In U.S.A
Modifications
Tinted Windows
Slash Guards
Hughes is offline
post #8 of 14 Old 05-29-2011, 09:54 PM Thread Starter
Hughes
Hughes's Avatar
Sorry guy's I just need this truck running. Once the truck is up to temp shouldn't I be able to remove the rad cap and see coolant flowing through the rad if the thermostat is opening? I got nothing. New thermostat also.
Made In U.S.A
Modifications
Tinted Windows
Slash Guards
Hughes is offline
post #9 of 14 Old 05-29-2011, 11:07 PM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 234 Post(s)
Did you remember to open and run the heater while you check the system?
dmcelhannon is offline
post #10 of 14 Old 05-29-2011, 11:11 PM
mirada80
2005 Hemi Ram
mirada80's Avatar
Quoted: 2 Post(s)
You might have gotten a bad thermostat. I think on the 4.7s theres a plug you can take out on the motor where the upper hose goes in to bleed the system. Pull this and let it reun for a bit see if it helps. If not you might have to replace the thermostat again,
2004.5 2500 QC SB 4x4 5.9 H.O.
MODS | Studded | Cold Air | 5" Turbo Back | Fass Fuel | Tinted Windows | HIDS
03 Silver Dodge Ram 1500 4x2 5.7 Hemi
MODS | Home Brew Ram Air CAI | Superchips 3815 | Comp Custom Grind Cam | 6.1 Springs And Pushrods | 06+ Coil Conversion | High Idle Mod | Summit Racing 25% Underdrive | Circle D 3200 245mm converter l TMR Mod | Sonnax Line Pressure Booster | Pacesetter Longtubes l Matching Off Road Y-Pipe l Magnaflow 14" SI/SO muffler | Electric Fan | 180 Stat | Walbro 255 With 05 Sending Unit | Auburn Limited Slip| B&M ProStick Ratchet Shifter | Custom Gauges | Custom Shifter Surrond | Ventvisors | Debadged | Tinted Tails | Tinted Third Brake Light | Smoked Headlights | 5000k HIDS in heads | 3000k HIDS in fogs | Roll Pan | Shorty Antenna | Custom Painted Grill | Street Scene Bumper | Poor mans 2/4 Drop | Dipped 17" Ram SS/T Wheels With Radials | 2009+ Chrome 20's | And A Little Bit of ZEX
BEST 1/8-Motor-8.43@80.52__Spray-7.85@89.12
BEST 1/4-Motor-13.38@98.9_Spray-12.27@110.42
BEST 60'-1.75
SOLD05 Patriot Blue Pearl Dodge Ram 1500 4x4 5.7 Hemi
mirada80 is offline
post #11 of 14 Old 05-29-2011, 11:35 PM
tmerritt530
Busted Knuckle Garage
tmerritt530's Avatar
How long are you running the motor? It can take a little while to get the thermostat to crack open.
Tanner 04 RCSB 4.7 4x4
OEM Off-Road 17" by 8" wheels - Goodyear Wrangler AT/S 275/70R17 tires - H/O cams
H/O cylinder heads -
OEM fog light kit - Hitch receiver kit - Self wired Tow Package
Tekonsha Prodigy trailer brake control - dumped Magnaflow 12468 DIDO
Rockford Fosgate Punch P1S410 subwoofer -Mineral Grey Truck Club #89
Experience:
tmerritt530 is offline
post #12 of 14 Old 05-29-2011, 11:53 PM
ceri
'11 5.7L R/T Classic
ceri's Avatar
Quoted: 3 Post(s)
When I have to purge air from my hemi I uncap the radiator, start the truck, turn on the heater, and give it about 15 minutes. It has to reach closed loop before it even engages the t-stat, so you've got to get it up to operating temperature before it can even begin to purge air.
Another added tip is to tilt the truck on a slant so that the front is nose up. Be sure to set the parking brake.
2002 Dodge Ram 1500 QC SB 4.7L V8 2WD SOLD!
2004 Dodge Ram 1500 QC SB 5.7L V8 2WD SOLD!
2011 Dodge Challenger R/T Classic 5.7L V8 RWD SELLING!
2005 Dodge Ram 1500 QC SB Laramie 5.7L V8 4WD
ceri is offline
post #13 of 14 Old 05-30-2011, 12:13 AM
dmcelhannon
Admin - David Mack
Quoted: 234 Post(s)
OK ... second question ...
Did you make sure the bleeder hole on the t-stat was at the 12-o'clock?
post #14 of 14 Old 05-30-2011, 11:04 AM
Brianmc
Brianmc's Avatar
On the last engine I rebuilt ( 355 chevy ) I drilled a super small hole in the thermostat before I installed it, and so ran the truck for a while with the rad cap off with the heater on. Drilling the small hole in the t-stat let's the air pockets get around the closed t-stat and escape threw the open rad cap
2004 DODGE RAM 2500 QC/SB HEMI
-295/70/17 nitto trail grap's
-MOTO METAL 951 BLACK
-DUAL FLOWMASTER 40 + K&N FILTER
-2" Leveling Kit
Brianmc is offline
    Thermostat housing bolts. comingapart 1972-1987 Dodge Ram Trucks (D, W-series) 9 09-16-2010 07:20 AM
    Thermostat Housing cover- where to get abacus Dodge Caravan General Talk 2 07-16-2010 04:20 PM
    thermostat housing flh79 2G Dodge RAM - General Talk 6 11-13-2008 09:17 AM
    thermostat housing flh79 2G Dodge Ram Performance Talk 1 10-08-2008 02:56 PM
    '91 thermostat housing help. buckyxj Dodge Dakota 1st Gen (87 -96) Forum 1 02-21-2005 09:08 PM
