2005 dodge ram 4x4 running hot - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 05-13-2011, 10:27 AM Thread Starter
newguy05
i need some help guys i am new to this site so if this is already on here i'm sorry in advance i have a 2005 ram with the 4.7 and i can't get it to stop running hot on me i have changed the water pump, theromostat, fan clutch, new fluid i am stuck any suggestions the truck usually only gets hot running down the road or in stop and go traffic sitting still it does fine
newguy05 is offline
post #2 of 13 Old 05-13-2011, 10:35 AM
mysilver04
mysilver04's Avatar
Quoted: 1 Post(s)
i had the same problem at one point, actually ended up being a plugged radiator that wouldn't unplug doing flush after flush. Changed the radiator and all was good with the universe.
06 mega cab dually cummins. 7" flipout monitor, ranch hand grill guard. 265/70/17 falken rocky mountain ats's.
mysilver04 is offline
post #3 of 13 Old 05-13-2011, 11:09 AM Thread Starter
newguy05
since you have fixed it where does the gauge usually stay at i have only had this truck about a month now and it hasent been right since i bought it and i dont really know what normal is for this truck mine right now runs about 3 to four tick marks past half way sometimes lower and what kind of cost did you run into with the new radiator
newguy05 is offline
post #4 of 13 Old 05-13-2011, 11:21 AM
zaxpw
zaxpw's Avatar
i work at a carquest parts store in colorado. a new radiator for you truck is $183.99 from us for a brand spankin' new spectra brand. hope that will get you in the ball park
zaxpw is offline
post #5 of 13 Old 05-13-2011, 12:17 PM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
4.7's have a bad habit of warping and cracking heads or bad head gaskets after running hot.
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #6 of 13 Old 05-13-2011, 12:19 PM
mysilver04
mysilver04's Avatar
Quoted: 1 Post(s)
mine sits below halfway by a few clicks and i am running a stock t-stat right now. my guage stays there no matter how hard i romp on it.
post #7 of 13 Old 05-13-2011, 12:28 PM Thread Starter
newguy05
mine has never gotten to the last big mark before red i seem to catch it before it gets to hot no dummy lights have ever come on i have checked the oil no signs of coolant in the oil or anything like that i am going to try a new radiator cap today if no luck i guess i will change the rad. out if this doesnt fix it i guess to the shop it goes i purged the air out of the system would it be wise to maybe try that one more time
newguy05 is offline
post #8 of 13 Old 05-13-2011, 12:49 PM Thread Starter
newguy05
also so i just wanted to mention i live in north centeral alabama and we are already having about 85 to 90 degree temps. outside i dont know how much this would effect this just wanted to throw it out there and the t-stat is a 195
newguy05 is offline
post #9 of 13 Old 05-13-2011, 12:51 PM
TheSatinPumpkin
Low N Slow
TheSatinPumpkin's Avatar
I think the CHECK GAUGE does not come on until the coolant temp is 252F. Got that on mine the day after putting in my e-fan. Turned out to be a air pocket.
_- under construction -_
TheSatinPumpkin is offline
post #10 of 13 Old 05-13-2011, 02:23 PM
mysilver04
mysilver04's Avatar
Quoted: 1 Post(s)
I ran mine like this for quite awhile before i got it figured out and i have no warped heads or blown gaskets.
post #11 of 13 Old 05-13-2011, 11:03 PM
TwinStick
My last 3 Dodge trucks all ran about a tick below the halfway mark. It's an 05, replace the radiator. It's cheap insurance. Redline Water Wetter also works, but not on a plugged radiator. It helps the fluid absorb & dissapate heat faster by reducing the surface tension of the water.
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
post #12 of 13 Old 05-14-2011, 01:39 PM
07blueram
07blueram's Avatar
i had this probelm last week and found out it that my radiator was pluged and replace it along with a new fan clutch and thermostat and now it stays in the middle or below.
2013 ram 1500 "black express edition" stock for now
07blueram is offline
post #13 of 13 Old 05-16-2011, 03:14 PM Thread Starter
newguy05
well i replaced the radiator cap saturday as a last ditch effort just to see if it would work and so far so good it hasnt got above half way but temps have been a bit cooler outside so i guess i will have to wait and see when it warms up outside what it is going to do but thanks for all the help on this guys i have found this web site really helpful
newguy05 is offline
    96 Dodge Ram 1500 5.9 running hot?! LawnDawg1 2G Dodge RAM - General Talk 4 03-26-2011 02:44 PM
    (4) Dodge Ram 1500 Wheels from a 2005 Dodge Ram- $150 OBO joshsbetterhalf For Sale - Truck Parts 2 11-05-2010 09:26 PM
    89 dodge ram 100 running bad IceBoX1392 Dodge Ram Truck 1st Gen (88 - 93) Forum 5 07-31-2009 09:58 AM
    Dodge Pumps American Iron with All-New 2005 Dodge Magnum RAM MAN Rumor Mill & Gossip Talk 0 03-03-2004 08:43 AM
