2500 Front Axle Nut socket size - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 04-28-2011, 08:49 AM Thread Starter
firecadet613
What size socket do I need to remove the front axle nut on my '06 2500? Going to change my front axle u-joints and I heard its a 1-11/16" but I can't find one that big.
2006 Ram 2500 QC 4x4 Hemi
firecadet613 is offline
post #2 of 11 Old 04-28-2011, 12:28 PM
!05RAM05!
Previously Micash21
!05RAM05!'s Avatar
I think its a 36MM
New: 2005 Dodge Ram 1500 QCSB 4x4 Hemi Laramie Bright Silver
Flowmaster SI/DO 40 Series. Superchips 3865 - 91 Tune, 2/4 drop, More to come............
::GONE BUT NOT FORGOTTEN::2005 Dodge Ram 1500 QCSB 4x4 Hemi Sport Black
5.5" Rough Country Lift, Dick Cepek DC2 20x9, 325/60R20 Nitto Terra Grappler's, Superchips 3865 - 91 Tune, Extang Tonneau Cover, K&N Cold Air Intake, Bosch Platinum 4 plugs, Magnaflow Y-Pipe, SI/DO Flowmaster Original 40 Series, Synthetic Everything, 7000K Headlights, Foglights and Hellas..
1998 Dodge Durango SLT 4x4 Black
Hypertech 87 Tune, K&N Cold Air Intake, Bosch Platinum 4 plugs, Bosch 8.5mm Wires. Ported Throttle Body, SI/DO Flowmaster Original 40 Series Muffler, Headman Headers, 3" PA BL, 2" T/S Lift, 33x12.50R15 Firestone Destination M/T's, 15x8 Eagle Alloy Wheels.
BTC Member 211 - Steel Reserve
!05RAM05! is offline
post #3 of 11 Old 04-28-2011, 12:35 PM
angusdevil
They call me Radio
angusdevil's Avatar
You can use a 1 11/16ths. Did it just last weekend.
1973 RCLB Stroker SB
REBUILD BLOG - radio1973dodge.blogspot.com
- Longtravel suspension still being built, Grabber 35" MT's, Method Wheels, 4.10's.
- Custom dash/gauge cluster, Corbeau seats, dual electric fans, most of the wiring replaced, 7" HID's, lots of other flashy and bright lights
- Fuel cell, aluminum rad, rear tranny cooler, front and rear tube bumpers, cut rear rockers and cage work ready to get started on.
angusdevil is offline
post #4 of 11 Old 04-28-2011, 12:43 PM Thread Starter
firecadet613
Thanks. Finally found a 1-11/16 at Napa.
post #5 of 11 Old 04-28-2011, 12:43 PM
99Slobra
Biggin
99Slobra's Avatar
I bought mine at sears.
20-30 bucks I think
2004 2500 Hemi R/C 4x4 on 35's
K&N CAI
Bilstein 5100's
Black Magic 183
SC 3865
Not loud enough
99Slobra is offline
post #6 of 11 Old 04-30-2011, 06:35 PM
rootkit
Jeremy
rootkit's Avatar
Quoted: 1 Post(s)
99Slobra - Did you find it in the 6pnt or 12pnt?
I cant find the Craftsman 1-11/16 in 6pnt online and in store... Was thinking about this socket set... but its a 12pnt not a total fan for the price.
06 2500 4x4 5.9l Laramie Quad Cab Atlantic Blue
rootkit is offline
post #7 of 11 Old 04-30-2011, 07:40 PM
angusdevil
They call me Radio
angusdevil's Avatar
You don't need a 6 pt. for this application. Because of the way the crown nut is cut, you'll find that a 12pt will work quite nicely with PLENTY of grip. Check out farm supply stores as they'll carry a socket that size as its quite common with tractors.
Don't mind hump it, just get a 12pt, make sure you have the 3/4" adapter and knock the nut off. If you're not using airtools, take the nut off first before you jack up the truck or take off the tire. If you don't, you'll just spin the shafts. If the tires are already off, just zap it with an decent airgun and it will come off. I believe the torque spec on them is 240 ftlbs
post #8 of 11 Old 04-30-2011, 08:04 PM
07cumminsqc4x4
I got a large socket set from harbor freight for ~$40 FYI.
I need to do my front axle ujoints, but cant get the danged hubs off.
2007 2500 HD 5.9L CTD Lonestar Edition
LT 305 65 R 17 BFG allterrains on stock wheels
4x4 6 spd manual
bushwacker fender flares, roll bak tonneau cover
purchased on 3/27/2007
139,000 miles and counting
07cumminsqc4x4 is offline
post #9 of 11 Old 04-30-2011, 08:16 PM
angusdevil
They call me Radio
angusdevil's Avatar
Don't have the to take the hub off the short shaft to do U-joints... just makes it a lot easier. Pull the whole shaft and hub assembly out of the housing and go about taking out the u-joint. If the hub is seized to the spindle, put a pry bar between the long shaft and housing and press outwards. You can also put a bolt for the hub about halfway screwed in... along with a 18mm socket and an extension and beat it out that way.
post #10 of 11 Old 04-30-2011, 08:17 PM
rootkit
Jeremy
rootkit's Avatar
Quoted: 1 Post(s)
reminds me i need a new torque wrench for 240 ftlbs haha...
07cumminsqc4x4 - watch this set of videos to get the hub off.
rootkit is offline
post #11 of 11 Old 04-30-2011, 09:01 PM
07cumminsqc4x4
thanks ill try that way. I took everything off, removed the bolts to the hub, and couldnt get it off. Put a 2 jaw puller on it and still didnt get it off. Ill try this way tomorrow, sick of my front u joints popping
4x4 6 spd manual
    What size are the front & rear axle/ring & pinion on ata3001 3G Dodge RAM - Drivetrain Talk 3 08-04-2009 07:59 PM
    left front axle seal leak 2500 dana m60 axle FIREMANJEFF 2G Dodge RAM - Drivetrain Talk 1 04-20-2008 12:22 AM
    Axle nut socket? dwh4784 2G Dodge RAM - Drivetrain Talk 6 03-15-2007 10:08 PM
    Axle Nut size on 2500 dodge ram 4x4 MudViper 2G Dodge RAM - Drivetrain Talk 1 08-06-2005 01:12 PM
    2500 Front Axle dragonslayer1 3G Dodge RAM - Drivetrain Talk 3 01-16-2005 11:18 PM
