How much should a Tie rod replacement cost? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 04-18-2011, 11:38 AM Thread Starter
stunta666
stunta666's Avatar
I just had a new tie rod replaced at a new mechanic shop and He charged me $200 for parts and labor for one side. Does this sound right? I'm only asking because i'm gonna need some other parts changed soon and need a mechanic I can trust.
Bright White 06 Ram 1500 4x4 Laramie
Mopar hood scoop
Aries bull bar and side steps
White Bushwacker pocket flares
Flowmaster 50HD dumped
Hellas in the grill
Undercover tonneau
20" black steelies with hankook ipikes for winter
20" black/machined hostages with 295/60/20(34.5x12.4)Terra Grapps for summer
Levelled on Bilstiens
stunta666 is offline
post #2 of 8 Old 04-18-2011, 12:14 PM
06trxhemi
ASE approved
06trxhemi's Avatar
sounds about right if an alignment was done as well. (that can run anywhere from 60-80 alone) then figure on 30 or so for the parts and the rest in labor. But you should have done both. It would probably have been about 300 total. Now if the other one goes you will have to drop 200 again. Make sure to check the boots on your rack and pinion. Alot of times when an alignment is done they get twisted up and if you don't fix it right away they can get torn and then the need to be replaced.
Originally Posted by PCP View Post
if it doesn't put a smile on your face, youre in the wrong shop..
follow along with the CNC Plasma cut parts on a 41 Plymouth rat rod build
(i have the capability to do the cutting)
06trxhemi is offline
post #3 of 8 Old 04-18-2011, 12:18 PM
2006RAMHEMI1979
2006RAMHEMI1979's Avatar
I was just quoted 220$ CDN for Parts, Labour, and an alignment.
2006RAMHEMI1979 is offline
post #4 of 8 Old 04-18-2011, 12:57 PM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
I think it sounds about right also but you could have changed that out yourself you know.
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #5 of 8 Old 04-18-2011, 02:31 PM Thread Starter
stunta666
stunta666's Avatar
I paid $260 canadian including an alignment. He was originally just supposed to remove my stuck shocks and do an alignment but he called me near the end of the day saying he couldn't get the alignment done properly because of it so i just said do it(i was truckless for 3 days because of the stupid shocks and just wanted her back). I guess it was a good price because i heard he spent quite a bit of time cutting my shocks out which im not sure if he included in the $200, all my buddy said was its gonna cost $200 to replace it so i'm gonna assume it was $200 for the tie rod, labor for tie rod, labor for removal of siezed shocks and alignment. When i went to pick up my truck he took me back and showed me the bad tie rod and his $40k alignment system which was pretty cool, i'm probably gonna use him for anything i cant do myself now(it's so hard finding a good mechanic) There was an article recently in our local paper where they had an undercover investigation on our local mechanics and it was pretty surprising http://www.ctv.ca/generic/WebSpecial...veyresults.pdf
http://www.ctv.ca/CTVNews/TopStories...chanic-110409/
Mopar hood scoop
Hellas in the grill
Undercover tonneau
post #6 of 8 Old 04-18-2011, 04:53 PM
ceri
'11 5.7L R/T Classic
ceri's Avatar
Quoted: 3 Post(s)
Good deal. It's not a hard job, but it sounds like about an hour of labor plus parts and alignment. I wouldn't have a problem going back to him. The trickier part that I've found is when you get one mechanic that you use regularly, sometimes they start thinking they can take advantage and look at you like a cash cow.
2002 Dodge Ram 1500 QC SB 4.7L V8 2WD SOLD!
2004 Dodge Ram 1500 QC SB 5.7L V8 2WD SOLD!
2011 Dodge Challenger R/T Classic 5.7L V8 RWD SELLING!
2005 Dodge Ram 1500 QC SB Laramie 5.7L V8 4WD
ceri is offline
post #7 of 8 Old 04-18-2011, 05:01 PM Thread Starter
stunta666
stunta666's Avatar
It's sad but true, I was paying $1700 a yr insurance for my truck and after 3 years with no tickets or accidents they send me a renewal letter stating it would be $1900 a yr. I called about 4 places and even the highest was only $1740 and now im only paying $1500 a yr. ****IN Insurance!!!!
Mopar hood scoop
Hellas in the grill
Undercover tonneau
post #8 of 8 Old 04-18-2011, 05:20 PM
V2Rider
V2Rider's Avatar
Quoted: 10 Post(s)
Not always, my well used mechanic charged me 300 bucks for Front end steering upgrade, steering stabalizer, 4 ball joints, and 2 U joints installed. Of course I have to pay another 65 for an alignment, but I doubt that other than doing it myself, it could be found cheaper
Previous:2003 Ram 2500 HD 4X4, Sold but not forgotten
Current: 2015 Dodge Ram 1500 Laramie CC Black on Black, FULLY loaded
AMSOIL
V2Rider is offline
    Transmission repair / replacement cost RAM MAN 2G Dodge RAM - Drivetrain Talk 10 12-07-2009 09:19 PM
    4wd clutch replacement cost? opposite locker 3G Dodge RAM - Drivetrain Talk 6 11-12-2009 07:25 AM
    Replacement Key's cost 200 a piece ? pepsi71ocean 3G Dodge RAM - General Talk 30 09-21-2009 11:43 AM
    '99 2.4L stratus evaporator replacement cost eric888 Dodge Stratus 1st Gen (95 - 00) 0 08-12-2009 11:04 PM
    Fuel Pump Replacement cost...? marcclover Dodge B-Series Vans 1971 - 2003 3 06-24-2009 02:23 PM
